Question about HP PhotoSmart 7960 InkJet Printer
I have a 7960 photosmart printer when i turn it on it goes to a screen which states" Cartridge service is stuck press ok" Ive taken out all jammed paper removed back panel saw no additional paper. it also makes a strange noise as if it were grinding against something in the area of the printer cartridges.
    Scholar:
  • 141 Answers
The automatic cartridges cleaning is stuck, probably a mechanism dead or maybe a bit a dirt from ink splash. open it and try to clean it and check for any weird thing, you can do some cleaning but the mechanism need some greassy spot so do not be too clean. Cleaning with water.
There is also a thin small plastic band as long as the printer that the printer head use as guide, It's like a scale but transparent. Clean that one too. Try to run it when the printer is open, you will have to puch some button to make it run. you might see where the problem come from...
cheers
Posted on Dec 18, 2008
Screen says cartridge cradle is stuck but it moves freely
Ok there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 05, 2010 | HP PhotoSmart 7760 InkJet Printer
Print Cartridge stuck
Look at the pad on the right side of the printer under where the ink cartridges are loaded. It may have ink deposits built up into lumps which interfere with the movement of the cartidges on the rod. Clean the deposits by scraping the lumps and removing all debris. This worked for me.
Jan 23, 2010 | HP PhotoSmart 7550 InkJet Printer
Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
HP photosmart 7960 gives message Cartridge Service station is stuck. Cannot see a jam or obstruction...any suggestions?
Unplug the Power Supply from the Printer.......
Remove both the Catridges from the Printer.........
Just Move the Catridge Carrier which Holds the Catridge Back and Forth for about 20 Times.........
Insert the Catridges back to the Printer.........
Turn the Printer On...........
Good Luck.............
Apr 04, 2009 | HP PhotoSmart 7960 InkJet Printer
Error Message - "Print Cartridge Cradle is Stuck. Clear jam."
open the printer - take out the print cartridge and put it back in
Mar 20, 2009 | HP PhotoSmart 7960 InkJet Printer
Photosmart 7960 Q3020A CN411310FG Red light flashes. Displays: cartridge service station is stuck. Press OK Result: cartridge until moves freely but fault is still ...
unplug the power cord of the printer from the electric outlet and wait for 5 minutes then replug it.it should get resetted and start working.
Nov 20, 2008 | Office Equipment & Supplies
Print cartridge cradle is stuck
solution for...
" CARTRIDGE SEVICE STATION IS STUCK " with a blinking red light...
it's a bit difficult...just fixed it today....
first of all...u have to be sure that your service station is clear from any other old ink that maybe dried....that stuck the movement of the service station...
if it doesn't work again...folow the next step...
1. u have to pull out the service station... ( the difficult one ..!!! )
2. under the service station, there is a small motor....just find a new one and change it..
it works...
.....i found this new motor in an old hp printer's service station that i have...
thank u
Jul 04, 2008 | HP PhotoSmart 7760 InkJet Printer
Print cartridge stuck
Hi please click on the link below to know exactly what you need to do to fix paper jam problem.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09128&lc=en&cc=us&lang=en&rule=1823&product=77146&dlc=en
Please let me know if it fixed the problem or not.
Cheers
Jun 10, 2008 | HP PhotoSmart 7960 InkJet Printer
Make sure the cover that holds the ink cartridge in place is completely closed down on the cartridge. Also make sure there is not a pencil or something under the cover where the ink is , obstructing the print head
Jun 15, 2007 | HP PhotoSmart 7960 InkJet Printer
HP PhotoSmart 7960 InkJet Printer Logo
142 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
