Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Refuses to print from the computer,
Can type a document and it says print and page comes out with no print. Have had trouble with not working for last few months.. Ican place a memory card in printer and run pictures off, or copy print from within machine. This Vista is only 1 month old and and don't have an icon showing for running printer. just home center and tutoral.
  • dondomom Dec 18, 2008
    I can print 4"x 6" pictures. However, it will not print documents from the computer.
  • 45 Answers
Call Kodak for a new printhead.
Posted on Dec 22, 2008
I have a inpiron 530 with a Photo 926 printer. It will only print the last page of a print job.
Hello randy,
This is going to take some troubleshooting.
Please try the following, and test after each change. Hopefully we can get this working for you quickly Verify that when you hit print it under print range that only the last page is selected.
Try printing a different document, this is assuming you've been only having the issue with one document. Try printing a different type of document, using a different program such as word, notepad, or even a multi-page website.
If any of these has worked for you then it has either narrowed it down to the specific document, or the program, re install the program in question.
If none of the following has helped.
go to start/run type cmd to open the command prompt type following net stop spooler net start spooler this will restart the print spooler service.
If none of the above worked, delete the printer and reinstall. If problem persists install printer on a separate computer to verify that it works correctly.
Good luck, and I hope i was helpful.
Aug 14, 2011 | Dell 946 All-In-One InkJet Printer
HP Color LaserJet CM1312nfi MFP printer leaves a 2 inch area unprinted using any programs. So basically it doesnt print the entire page.
turn on/off, unplug, plug in2_bing.gif, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are preventing printing
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome website for this type os trouble shooting
hope this helps and good luck
Apr 29, 2010 | HP Color LaserJet 2600n Printer
My Samsung CLP 315w refuses to print a whole A4 page. Stops half way then message comes up paper jam but when I open back / front, paper not jammed and when I close it document continues printing then...
most likly hood is your exit sensor is faulty. The printer work in this way. if it does not print out all the document. it will print again. that is why you kept getting this same issue after a jam open and close door it will print again.
replace the exit sensor it will help.
Apr 16, 2010 | Samsung CLP-315W Laser Color Printer
HP photosmart C5280 document stuck in print que
Delete document manually from the path mentioned below:
1) Press windows + R an then type spool
2) Go to PRINTERS folder.
3) Delete the files present in there.
If not able to delete then
1) Open command prompt.
2) type "net stop spooler" and then delete the files
3)Again type "net start spooler"
Your stuck document is now cleaned. You can start printing your document again.
Mar 30, 2009 | HP Office Equipment & Supplies
Can't print envelopes
is this the first time you use word ?
if it is any of the newer version 2003, 2007. the printing of envelope is as follow:
open the word, elect tools>>envelopes and labels. type in the delivery address and return address. click add to document.
completed you letter.
whenyou want ot pin the envelope, hig light the delivery address on the document, file, pirnt, type in 0 (zero) in the pages box under the page range (in the middle of the popup, under the "curent page button).
Mar 26, 2009 | Samsung ML-2510 Laser Printer
I need to change printing pages from last to first page first
the last printed page is always on top. For a long document, it takes a while to resort and place the first page first! This is how you can get Microsoft Word to reverse the print order and save all the trouble.
I have spent so much time resorting documents after printing. On my printer, the last page printed is always on top. By printing the last page first (reverse order), the document is already correctly sorted.
Here is how to do it:
1. Open Microsoft Word
2. Open the document to be printed
3. Click the Tools menu
4. Select Options
5. Click the Print tab
6. Check the Reverse Print Order option
7. Select OK
Now, all your documents will prevent in reverse order. What a lifesaver!!!
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 30, 2008 | Lexmark Office Equipment & Supplies
Printing blank page at the end of every printing job
Hi Keren,
1) Are you sure it is the printer, not the software application ?
Try printing a single "Hello World" message from "Notepad"
If there is no blank page at the end of it, the problem is in
the specific software app: Office, Word, Excel, etc...
2) What application are you printing from?
a) Check the page and print setup.
b) Make sure the application's "page size" and the printer's
paper size are consistent. Pay special attention to
metric paper sizes vs English:
E.g. A4 vs Letter
If the page with margins is bigger than the paper, it will
generate a new page, even though there are no visible
characters on it.
c) Check the print margins within the page setup:
In MS-Office: File ---> Page Setup --->
d) Add a single character to the very bottom of your
document, and see if it wraps around onto the last page.
Microsoft office applications are notorious for wrapping
the last PARAGRAPH character onto the next page if
it does not quite fit onto the paper.
e) if you are using MS WinWord, go into options and set it
to display all special characters:
Check to make sure that there are no page-breaks at
the end of the document.
Also look for extra paragraph marks/ carriage returns,
and check the format settings on the last paragraph
mark in the document:
Page brake before...
Keep lines together ....
Widow and orphan control ...
which can cause the last paragraph mark to generate a
new page. If the last paragraph mark is not formatted
the way you want it, make sure that you save the
TEMPLATE after you change it, since this is the
DEFAULT setting for all new documents.
Finally it is also possible for Windows applications to look
different on the screen than the final print due to small
(but cumulative) True Type Font (TTF) computation erros,
such that a 10 page document on the screen can actually
page-split in weird places printing as 11 pages.
I have the identical model of printer, and it does NOT seem
to have any settings for printing banners or adding separator
pages, at least not in my printer driver, but this is NOT to say
that the applications you are using are not causing this
problem.
I hope this gets you started.
Please rate my answers.
Martin
Jul 01, 2008 | Brother HL-2070N Laser Printer
Only prints last page or least few pages of a ulti page document
if your taskbar displays printer icon on system tray double click on that & delete all privious prints.
select the text or area which you want to print. & give print command, & Click on print selection button & then Print.
Jan 17, 2008 | Lexmark X7170 All-In-One InkJet Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
41 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
