Cd drive door will not open. when opened manually and disc inserted door will not close automatically and will not read a disc
  • Kaj Bjorlin
    Kaj Bjorlin May 11, 2010
    What kind of "door" is on your CD drive? Is it a tray that slides out? Is a somekind of slot in? Is there any lights on the CD? Does it open/close by itself?
    Thanks,
    Kaj
  • 54 Answers
Is there any power to the drive? IE is there a green light on the front when trying to read the disk?
It may not have the power in, or may have blown a power circuit.
IF it was just the door not opening and the unit has power, i would suggest the little rubber band is having issues and not opening or closing the door.
Posted on Dec 18, 2008
My bang & olefson cd 50 will not play. hear "spinning" sound when disc inserted.
THE CD50 DOOR MECH IS BELT DRIVEN IF THE BELT IS WORN THE DOOR OPEN/CLOSE SWITCH WHICH IS TRIGGERED BY THE MAIN CAM UNDER THE MECH MAY NOT BE FULLY CLOSED OR THE SWITCH MAY NEED CLEANING,ITS A LEAF SWITCH.THE MOST COMMON REASON FOR THE DISC TO SPIN BUT NOT READING DISC IS DISC MOTOR NOT GETTING UP TO CORRECT SPEED.IT CAN BE REMOVED,DISMANTLED AND LUBRICATED BUT CARE MUST BE TAKEN TO MEASURE THE TURNTABLE HEIGHT,BEST MEASURED FROM THE BASE OF TURNTABLE TO CHASSIS WITH FEELER GAUGE,CAUTION THE MOTOR SHAFT HAS SEVERAL VERY FINE WASHERS INSTALLED DONT LOSE THEM.
May 21, 2014 | Bang and Olufsen Beocenter 9300 Shelf...
How to turn on rca cd player
Hello
1. Press 'SOURCE' repetedely to select 'CD' mode.
2. Press "Open/Close" button to open the drawer.
3. Insert disce and press 'Open/Close' again, and the inserted CD will play automatically. OK.
Jul 29, 2011 | RCA RS2635 CD Shelf System
Dreamcast is not reading disk says please put in disk
There can be 1 or 3 problems with this
1 The laser lens needs to be replaced
2 The motor that spins the disc needs replacing
3 The motor that drives the laser carriage needs replacing.
90% of the time its the laser lens
Jan 25, 2010 | Sega Dreamcast Console
CD tray not opeing
Perhaps it didn't fully latch so the CD drive doesn't think it's closed? Try opening and closing the door manually by straightening out a paperclip, then inserting it into the little hole in the front of the CD door. That should open it. Once open, close it and see if it will now open when you press the Open/Close button.
Aug 26, 2009 | Acer (KV.16X04.007) DVD Drive
DVD tray won't open.
Opening a CD or DVD drive to retrieve a disc
  • Use Windows to open the drive door:
    1. Double-click the My Computer icon on the desktop (or click Start and My Computer in Microsoft Windows XP).
    2. Right-click the CD, CD-RW, or DVD drive , and then click Eject .
  • Restart the computer and press the EJECT button on the front of the drive when the first screen appears (before Windows launches). If the drive door opens this way but does not open in Windows, another software program is taking control of the CD drive. Try shutting down or configuring any programs that write discs or monitor the CD drive.
  • If the door still will not open, do the following:
    1. Close all programs and shut down the computer.
    2. Unplug the PC from the power outlet and remove the battery.
    3. Locate the manual release hole in the front faceplate of the optical drive tray. This is a small hole under the door that is a little bigger than the diameter of a paper clip. The location of the manual eject hole will vary.
    4. Insert a straightened paperclip into the manual release hole until resistance is felt.
    5. Once the resistance is felt, keep pushing the paper clip until the drawer comes out about a quarter of an inch.
    6. Remove the paper clip and gently pull out the drawer until the disc is accessible.
    7. Remove the CD and turn on the computer.
May 21, 2009 | Daewoo DVG-3000N DVD Player
Will Not reconise Cd or DVD in the Drive
Yes, this drive is basically dead. You can find pretty cheap prices for new drives at www.pricewatch.com
If the drive door closes on a cd or dvd that you want and it will not open back up, use a straightened paperclip and push it into the little hole near the door on the drive, the door will pop open then.
Mar 29, 2009 | Sony DW-G120A DVD RW Dual Layer Burner
My DCD3000 door closes automatically and won't read discs right
Hi....
If the transport inside is like the NAD players, it's the drawer belt that's the problem.
Belts are cheap but someone technical needs to change it.
Mar 24, 2009 | Audio Players & Recorders
CD/DVD drive stuck CLOSED and NO pin hole
Use my computer and select the drive (eg drive E:). From pull down menu "File" select "eject". While the disk door attempts to open (hear slight movement of tray) massage the door with your fingers. This is done by smoothing out the across front door panel with your finger tips and pushing in and releasing pressure from door. Door should slide open partially and close again. Repeat. The eject button nearside the disc tray doesn't seem to work as well as selecting "File" and "Eject" from the menu. Something to do with the door cycle is less with the direct eject button.
Jan 28, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
CD drine issue
To manually open the CD Drive, straighten a paper clip and insert it into a tiny hole in the front of your CD drive and push the paper clip gently into the drive and the tray should then pop open.
Open and close this several times, then insert a disc into the drive and see if it will read the disc.
If not the drive is dead and needs to be replaced.
Nov 18, 2008 | Acer (KV.16X04.007) DVD Drive
Computers & Internet Logo
204 people viewed this question
Alun Cox
David Payne
David Payne
