Question about Go Ped GSR Sport Gas Powered City Scooter
My son has a goped sport and the engine isnt pivoting very much and the spindle isnt touching the wheel. I replaced the spindle and same problem. Do the springs get weak and/or do the tires wear enough to where this will occur?
  • 161 Answers
Yes to all three questions, the tire wear will be obvious this will cause the drive spindle not to hit the tire, also the drive spindle if you look at it , it should have a very ruff surface to it that is what drives the tire that can be worn, and lastly the return spring to lower the motor onto the tire does wear out, but this might be a cable problem, see if you can adjust the cable that lowers the motor onto the tire by loosening it at the point where it connects to the motor bracket then see if you can push tyhe motor down onto tire let me know how you make out, write to me at this e mail, drummerboy843033@wmconnect.com
Posted on Mar 20, 2009
My goped sport engine shut off and wont start again, what I can do?
Try the steps on this website. http://goped.8m.com/racingpages/troubleshooting.html
May 30, 2014 | Go Ped GSR Sport Gas Powered City Scooter
Steering knuckle needs replacing
A steering knuckle is a forging that usually includes the spindle and steering arm, and allows the front wheel to pivot. The knuckle is mounted between the upper and lower ball joints on a SLA suspension.
Original Universal MST-3 Diagnostic Scan Tool MASTER
Dec 21, 2012 | 2000 Dodge Durango
I'm looking for an exploded view diagram for my Goped CY46 engine. Do you know where I can obtain one?
You should contact GoPed at www.goped.com. They don't show that engine number or photo on the website so you may want to call 1-755-782-3202 or email walshj@goped.com.. They are located in Minden Nevada, mountain time zone. Below is a diagram of a G23LH engine. Yours will be very similar. Please rate my answer. Thanks. tombones49_220.gif
Aug 05, 2011 | California X280R Motorcycles
I just bought my 9 year old son Heelys that were discounted at Sports Authority. The wheels that were put into the shoes do not belong to this type. Sports Authority would gladly take them back but my...
HI
THE ONLY SOLUTION WHICH I THINK WILL HELP YOU PLEASE APPROACH ANY OTHER SHOEDEALER NOT THE BRAND ONES BUT THE ONE WHO MAKE AND REPAIR SHOE ,THOSE TYPE OF PERSON WILL NOT ONLY REPLACE THE WHEEL WITH SUITABLEONE BUT WLL BE DONE CHEAP. SINCE THE AUTHORIZED DEALER CANT DONT ANYTHING ABT IT OTHER THAN REPLACING IT ,IT BETTER YOU APPROACH THIS COBBLER WHO CAN FIXT IT
THANK YOU
Dec 28, 2010 | Heelys Heely's Chazz Skate Shoes for Boy
My scooter starts runs good then dies
Replace the battery, after sometime the battery starts to lose it's initial capacity.
For battery replacement go to Goped.com, select your scooter model, then click replacement parts and find the batteries on the part list.
Aug 02, 2010 | Go Ped Know Ped Goped Push Scooter
My sons goped starts and runs well with no weight on it. As soon as a person starts to ride it, it won't go and sputters. I took the engine off and looked at the clutch, and everything looks OK. Where else...
Sounds to me like you have a direct drive model with no clutch. With the direct drive model you just warm up the motor with no rider and wheel off the ground then turn it off and push start it "push and Go". The trick to push staring is stomping your weight down near the back tire as you push forward to get the rear tire turning. Once it turns so will the motor and it will start and your off and running. Do the push start without applying throttle and make sure you have the rear wheel adjusted against the drive roller correctly..
Jun 04, 2010 | Go Ped GSR Sport Gas Powered City Scooter
The cahin came off on my sons Kawasaki KLX 110, how do I put it back on?
loosing off the rear wheel spindle and adjusters push wheel forwards, re fit chain and pull wheel back wards using adjusters on each side of wheel ensuring they are even on both sides (count notches on each side) then tighten wheel spindle
Apr 26, 2010 | 2005 kawasaki KLX 110
I have a 1985 Honda Shadow 500 -- the rear brake has begun sticking. I have taken it as far apart as I can, following the Clymer manual, but can't figure out how to compress the return spring to get it...
i drilled a 1/8th dia hole in the top of the pivot where the brake pedal slips on to the spline.now i put a couple of drops of oil in the hole and work the brake pedal by hand. till it loosens up. i also installed a 2nd return spring on the brake lever at the wheel anchored to the brake pivot at the swingarm pivot. it works for me. kr
Jul 15, 2009 | 1985 Honda VT 500 C Shadow
Just bought a used goped for my nephew, runs
i hve a MOB n73... \r\nand my seriaL NUMBER is 353548024388283
Can sum one tell me da license key of this serial number..... SMAR MOVIE 4.01
plz plz plz plz..... i Shall be thnk ful 2 all
Jul 06, 2009 | Go Ped Toys
Once i Turn the throttle my goped turns off
it may be over fueling if you have turned the jet id sugest hold at full throttle and adjust jet whilst running it on full power
Jan 25, 2009 | Go Ped Know Ped Goped Push Scooter
Go Ped GSR Sport Gas Powered City Scooter Logo
220 people viewed this question
Top Go Ped Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Go Ped Toy Expert? Answer questions, earn points and help others
