Question about Car Audio & Video
Car radio problem
When driving with the radio switched off, it will suddenly switch itself on and omitt a high pitched squealling sound.
  • martina ohar Dec 19, 2008
    Thanks
    I will try that.
    martina
  • martina ohar Dec 21, 2008
    Hi
    I had to take the car to someone in the end - it turned out our child was using the radio as a money box!
Possibly take the radio out and see if theres any loose wireing.
Posted on Dec 18, 2008
High pitch droning sound
There is a metal tab on some pads that contacts the rotor to make hideous noises telling the driver they need to replace the brake pads. It's in your owner's manual.
May 05, 2015 | Cars & Trucks
High Pitched ear ringing sound coming thru somewhere up front by navigator system
Some things I would check are do you have blue tooth in operation. Do you have any form of michrophone in the cab as it sounds like a feed back problem coming through your speakers. Talk to a radio techie to see what he thinks
Feb 23, 2013 | 2008 Jeep Grand Cherokee
Opel corsa 1.6 Sport 2005 model. When driving 120 km/h the car runs at 3700rpm. Is this normal or is it to high and if it is how can this be fixed? your assistance is highly appreciated!
I have a Opel Astra 1.6 2005 , when I switch off the car , switch off the radio the power or radio comes on by itself , the dash lights up the cabin light comes on including the radio , then i switch it off 20 minutes later all comes on by them selves leaving me with a flat battery in the morning , while driving I drive switch off the radio then 15 minutes later radio comes on by itself why anyone know how to fix
Thanks kelly
Oct 28, 2010 | Chevrolet Corsica Cars & Trucks
My Braun 7570 has suddenly stopped working, but there is a high pitched whine when I switch it on.
This sounds like a battery problem. The likely remedy is to replace them. You will find batteries for your shaver at shaveroutlet.com
Jan 17, 2010 | Braun Syncro 7570 Electric Shaver
It's screaming at me ~ squealling loudly.
the cutter wheels in side the machine needs to be lubricated. use a silicone lube. like tri-flo. Spray the lube where you put the paper
Jan 23, 2009 | Achiever SCS-6 Strip-Cut Shredder
NO PIC HIGH PITCH SQUEAL COMING FORM BACK BOTTEM PART OF TV?
Squealing sound means you have something shorted in high voltage area around FBT on Power/deflection board.UED has replacement boards & Misc Parts for these sets if in stock call them1- 800-648-6657
Dec 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
High-pitched sound when using surround sound
THANK YOU Guest (4/10/08)!!!
That was exactly what I needed! We have had our system for 4.5 years and suddenly, the FM feedback on everything, but DVD and Radio! Your fix helped. Once I set all my presets (at least the current one) to a clear station, the feedback stopped. Hallelujah!! We can enjoy this piece of junk once again! ;)
Amanda - San Antonio, TX
Mar 02, 2008 | Sony DAV-FC7 System
High pitch sound in background
A high pitch sound while connected in the house is either a problem with the reciever or you are picking up interference from somewhere. However, the high pitched noise when using the unit in a car (especially through an aux. connection), is caused by the alternator of the car. This can be eliminated by connecting a filter in-line with the aux wire (much like filters are installed on the radio power line). The filter is essentially a low pass filter that filters out noise above a certain frequency. You may have to get creative and modify your aux. input cable (i.e. - splice it into the aux cable) in order for this to work, or you can just turn the volume down a bit - it should be less noticeable at lower volumes.
Nov 26, 2007 | Delphi Roady2 SA10085 XM Radio Receiver...
Please Help - Set "Dead" Euro 7 vp chassis
This sounds like a line timebase failure. The line timebase works at about 15 thousand cycles per second (15KHz) which may be audible to some people due to the iron-ferrite materials used (magnetostrictive). The line output transformer is highly stressed and also has the rectifier diodes in the outside if the windings. It is all very well insulated to guard against moisture and dust but if it breaks down due to the high voltages (25Kv) the arc produced makes this squealing noise, and of course it burns out, and breaks down. This may not blow the fuse if there is not a short circuit. So get an engineer if you are not sure about changing the line output transformer.
Oct 14, 2006 | Panasonic TX-42PT10 42" TV
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
