Question about Lexmark I3 InkJet Printer
I ran out of ink and did not replace the cartridge for a few week
Now when I try printing it does not seem to except the ink - - it does not seem to transfer the ink - I just get blank pages
does this need some type of cleaning or something to get it going??
  • Lexmark Master
  • 5,568 Answers
In the software you installed when you first got the printer is a maintenance section that will attempt to clear dried ink from the printhead. Unless used every second day, in my experience, the routine doesn't work if the head is clogged.
Your printhead is actually part of the cartridge, one of the reasons cartridge replacement is costlier than some others using an installed printhead.
If you have installed it properly, about the only thing you might try is to remove the cartridge, use a porcelain saucer, spray a puddle of window cleaner (works best, tried many) and position the head with the printhead surface submerged in the puddle and let it sit overnight.
Use a paper towel with little lint and gently wipe the printhead surface clean. You should have clear ink traces on the paper.
Pressing the printhead onto the towel for a couple of seconds should produce an ink blot in the shape of the active area of the printhead.
Then, do the cleaning routine and you might have a working unit again.
(I'm sorry - I really miss dot-matrix printers!)
Posted on Dec 18, 2008
  • 54 Answers
I'm not too sure if I am understanding correctly, if you did NOT replace the ink (as per your title) you will not get any ink out of the printer, you will need to purchase a new ink cartridge and install it correctly.
However if that was a typo and you did already replace the cartridge, did you replace it with an original or an aftermarket, or even a refill? Also, you can try telling any software on your PC that it has a new cartridge, I'm not too familiar with the Lexmark software, but if there is an ink level monitor you should be able to tell it that you've replaced the cartridge.
Bought a Workforce 1100 Epson printer and it came with ink cartridges. Those worked fine but, once one of the inks ran out, I bought the whole series (at Costco) of all 5 inks and replaced the magenta. The...
if it is still under warranty , call for a technician to do a warranty check
there are some printer manufacturers that have an inbuilt program that will cut out the machine if anything but genuine cartridges are used
under warranty or not , there is a clause in consumer law that states , the unit has be be replaced or money refunded it the machine is not fit for the purpose or the unit fails before a reasonable of period of time in use
one round of cartridges is not a reasonable expectation of the time in use not is it fit for the purpose if it will not work after one round of cartridges
Mar 10, 2017 | Office Equipment & Supplies
Have changed all cartridges on epson nx400. test shows 3 ink cartridges printing, except for the black ink. have run clean head utility, ink has charged. downloaded and installed printer driver. Found an...
Hi
The ink reservoir doesnt have to be completely empty to fail. Replace the cartridges. Some of the jets or all of them may be clogged especially if you have not used your printer in a while. If there are cleaning instructions in the manual clean the jets and then try to print from the printer's self test
Goodluck
Mar 09, 2011 | Epson Stylus NX400 InkJet Printer
Poor printing quality
Dear friend,
Just few tipe.
1. Try to use glossy photo quality paper for photo print out. which is look good and not so expence of ink.
2 Use good quality glossy type normal paper for text print out. that can not **** much ink from the cartriges.
3. try to cover your printer always.
4. clean the head via tst print oftenly.
Thnks & waiting for your feedback.
Jan 30, 2010 | Canon Office Equipment & Supplies
Printing issues TX400
That is basically true. You have a clog. You can try to save the printer by continually running through the black ink cleaning process. Might as well, you already replaced the cartridge, and you won't be able to use the cartridge in another printer since cartridges are now electronically tagged.
Aug 25, 2009 | Epson Office Equipment & Supplies
Prints purple instead of black on photos only
My Canon printer has TWO slots for black ink cartridges. I assumed one was extra and didn't replace it when I ran out. Text printed just fine with only one installed, but my photos were printing with purple instead of black. I looked into it, and the two cartridges are different: one holds dye-based ink, the other has pigment based. Photos must require both kinds. If your printer is the same as mine, use both!
Jul 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Remove mfc 5440cn print head
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
Apr 30, 2008 | Brother MFC-5440CN All-In-One InkJet...
Black ink not printing
Fix ink cartridge
Apr 20, 2008 | Brother MFC-5440CN All-In-One InkJet...
The yellow ink doesn't print although the ink shows full
Hi there! are you using original canon ink cartridges? if so, your cartridge might have defects, try to replace your cartridge with a new one. If you're using compatible ink cartridges try to replace it with an original canon ink cartridge. Have a good day!
Apr 09, 2008 | Canon i860 InkJet Photo Printer
Replaced empt 3E cartridge. Now it won't print
Kind of an X-file situation there. You should try an other cartridge, maybe that one is defective
Feb 03, 2008 | Canon PIXMA iP4000R InkJet Printer
Dell 922 All In One Printer wont print
did you remove the seal of new catridge. bye
Sep 24, 2007 | Dell 922 All-In-One InkJet Printer
Lexmark I3 InkJet Printer Logo
46 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
