Question about Samsung Digimax S730 Digital Camera
Samsung S750 battery problem
Battery is always low when i replace new batteries in
  • Anonymous Dec 23, 2008
    The batteries often go flat although the camera has not been used much at all. I've tried good quality lithium and rechargeable batteries with the same result.
    Sometimes it will also freeze with the lens out. I know someone else has reported the same problem, and I think the two problems are linked.
  • Anonymous Dec 27, 2008
    I now buy the very best quality batteries,and now only have the camera turned on the absolute minimum of time possible to take a photo and download.
    I have also found the camera red hot once ( so that explained how the battery goes flat) what causes it ????????
    New Friend:
  • 83 Answers
I think you can have a try with LEO Privacy app. It can speed your phone and hide your stuff:
LEO Privacy Applock Hide Safe Android Apps on Google Play
Posted on Jan 17, 2017
5 Suggested Answers
SOURCE: displays "low battery" always
I had exactly this problem and found the solution - I was using the wrong type of batteries.
You might be doing the same so what you need to do is check to see what mAh the batteries you're using. I was using Energizer rechargables with 1300mAh when the camera stopped working and switched to 2500mAh rechargables (on the advice of a friend) as a last desperate attempt to get it to work and it solved my problem. I got 2500mAh Energizer rechargables and would advise the same but you should go for batteries with at least 2100mAh.
I hope this helps some people :)
Posted on Jun 12, 2008
  • 70 Answers
SOURCE: Camera shows low Battery and goes off even if u insert a new one
are you using NiMh rechargeable batteries?
If yes, check that they are fully charged. If that doesn't do the trick, sounds like it might be a power circuit issue. Samsung is in Secaucus, NJ
or SamsungUSA on the web
Posted on Apr 15, 2009
  • 615 Answers
SOURCE: low battery indicator
Dear sir,
Welcome to Fixya Customer Support
By analysing your problem it deffinately due to battery power sensor you can visit nearer canon camera service centre,they replace the sensor.
good luck
Fixya Customer support
Posted on Jul 17, 2009
  • 14 Answers
SOURCE: Erratic Low Battery Warning
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Posted on Aug 21, 2009
Samsung w259 charge battery
Hi prosenjit,
please try with another battery.
i think the new battery is not good.
Jan 08, 2014 | Samsung Cell Phones
Whenever i try to take a photo with my samsung s750 it just turns off andthe only way i can turn it back on is to remove the batteries and put them back in again plz help
It sounds as if your batteries are too low to function and need to be replaced. Batteries will rebuild a small amount of voltage once taken out of the camera, but once you push the button for a picture, the load is too much, so it shuts down.
Rechargeable batteries only recharge so many times.
You can try to clean the ends of both the batteries if they are exposed, as well as attempting to clean the contact they connect with if you see any corrosion. There's not much to do with plug in type batteries.
A pencil erasor is abrasive enough to remove light dirt/dust, then wipe to remove anything remaining.
Good luck.
Mar 25, 2012 | Samsung Digimax S750 Digital Camera
Camera always says low battery even when you put in fresh batteries..will not allow me to take any pictures
Hello. Remove the batteries and use the eraser on the end of a common pencil to clean the contacts. Then replace the batteries and turn it on. J.
Jul 10, 2010 | Samsung Digimax A7 Digital Camera
Camera stoped working and lens is in the out position, i can't get it on again
It seems your camera Lens got stuck in open condition, This will happens due to two reason.
1) Either your camera battery got died or need to be recharged or replace.
2) Your camera is malfunctioning and need service (repair).
To resolve the problem. first check battery indicator on your camera, If battery indicator shows battery low, than you need to charge it or you need to replace your battery.
Follow the instruction to retract camera lens:-
1) Turn on your camera.
2) Press the Playback button on the back of your camera. The lens on your camera should retract.
If problem still not resolved then your device need to be serviced (Repair).
Rating the solution is highly appreciated...Good Luck.
Feb 28, 2010 | Samsung Digimax S750 Digital Camera
Camera is eating batteries
Hi Sparklerose.
i have the same problem, so i thought i would go get a mains adapter to use only when i need to offload the pictures to my PC. problem is, i need to know the polarity of the camera before i can use the adapter. dont know it do you ? as to the battery problem. its annoying i know. do you think batteries these days are just not as good as they used to be ? and they are so expensive to boot ! good luck anyway.
Jul 04, 2009 | Samsung Digimax S750 Digital Camera
Hi i have a samsung s750 but i can't take pictures because the screen is blank so i don't know what i am taking
Hi, I can help you. First, make sure you can see the menu by turning the camera on and pressing the menu button. If you can see the menu, scroll to the right to reach the setup menu.
Then scroll down to Quickview and then scroll right. Then scroll down to 3 sec and hit the Ok button.
That should fix your problem. If I can help you anymore, let me know, and thanks for coming to FixYa. Don't forget to vote my solution a fixya.
To the person with the camera showing low batteries even when they are new, make sure the battery door is on tight. Over time with use, the door can get loose. If it's loose, it will not make a good connection with the batteries and freeze up. Hope that helps. Let me know with a comment if you need more help. And don't forget to vote!
Feb 03, 2009 | Samsung Digimax S750 Digital Camera
Low battery
Your cam has a not so rare battery drain defect, mine had the same problem.
call Samsung and send yours in, they will either fix it or give you a new one.
May 26, 2008 | Samsung Digimax S630 Digital Camera
Samsung Digimax S730 Digital Camera Logo
280 people viewed this question
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
