The water runs through the april air when the heating unit is either on or off. Help
Thanks for your questions,
what you will want do first, disconnect one lead off of your Humidistat, or at the Solenoid, to see if that stops the water, if it does, you will need a new Humidistat, if not, then you have a bad Solenoid, that will need replaced, you should be able to purchase one or both of these either online, or through an appliance store, or your local Heating and A/C shop, hope that helped ya, let us know how we did, thanks again,
mr.grzz
At first wasn't getting any water through the valve, now it free flows through. I here a click that should indicate that the valve is working, but the water continues to flow. Can the valve be serviced or cleaned?
Water runs continuously unless the humidity level is lowered on the controller.
when my humidifier turns on it runs continuasly. it is not a slow trickle . it is overflowing and leaking out of the bottom tray.when i turn the humidistat on i can here a click and you can feel the solinoid energize.the water does not always start running right away is that normal? i replaced the shut off and filter .water lines and drain lines are all clear. could this be a bad humidistat?
I have two very similar but not necessarily the same problems.
On one unit, water flows through the solenoid water valve when ever I turn the humidistat knob above a certain level, whether or not the furnace is running. Any suggestiions?
On a second unit, the solenoid vater valve opens when the furnace runs, assuming the humidistat is set high enough, but does not shut off when the furnace stops. Is this a stuck solenoid water value which should be replaced?
Thank you.
