I replaced fan motor and coolant conrtol module but coolant fan still does'nt work
Try checking the fuse box under the hood. It should have a fuse marked cooling fan or cooling system. If the car does start, that means the computer isn't out, but maybe there is a bad relay by the fan or in the circuit or even the temp sensor may be bad. The fan won't run until the temp is high enough; usually by the time the thermostat opens.
SOURCE: I need a diagram for serpentine belt replacement on a 1999 For Escort ZX2
the diagram is located in the engine compartment under the hood.
Clean off the surfaces and it is one of the stickers there.
SOURCE: routing of serpentine belt for ford escort zx2
Click on the link below, Enter the year,make,model, and engine. You will get a page with a link to the diagram you need under the part number.
Greg
http://www.mvreader.com/multiview/dayco/index.php?autoCatalogSearch=0&catalog=auto&l=n&year=2000&year_from=&year_to=&make=FORD
SOURCE: 2002 ford escort zx2 camshaft sensor fit a 99 zx2?
Yes, All the years of the ZX2 utilize the same engine. 1998-2003 are all the same except for ECU programing and the MAF wiring. You should not have a problem.
SOURCE: I have a 2002 Ford Escort ZX2. The Auto store
This CODE is Indicating that ENGINE COOLANT TEMP is NOT Reaching TEMP HOT Enough to >CLOSE LOOP < This is when ECM takes over ALL ELECTRONIC CONTROLS, . It Basicly Points at A Coolant Temp Sensor that is Faulty or Thermostat that is RATED too LOW. Engine Must Reach 200 - 220 degrees
SOURCE: 2002 Ford Escort ZX2 serpinten belt routing & tensioner pulley
go to www.gates.com on the lower right hand side under popular topics, click on timing belts, then on the left hand side click Parts Locator and Interchange, enter your cars info and the first page that comes up will show you a camera icon for a pic of how your belt is routed. The tensioner pulley is the one mounted on a silver arm, usually at the top. Hope this helps let me know.
