Question about Motorola Mobility RAZR V3
No any sign that the phone is working
I dropped my phone but it was just low impact about 12 inches below the floor. i tried to check evrything to see if something's wrong but everything was fine there we're no problems. i was able to use it for the next few hours approximately 5 hrs then it shut off. i tried to turn it on but nothing happened. i thought i just drained my battery but when i connected the charger there was not a single sign that the battery is charging. no light blinking and no matter hom many times i turned it on still it didn't turn on. i had it repair in a phone repair shop but until now it's still there and it's almost 4 mos since i left it there. i keep visithing the shop but then they always say that they haven't fix my phoone yet because the problem of my phone is very unusual. my phone is just new i had been using it for 4 moths. please help me. im loosing hope that those people can fix my phone. thanks!
  • 62 Answers
I'm not sure it's unusual alright but perhaps if you open it up there may be some wires loose but if they snaped youed half to solder them and if somethin broke I dunno. sorry bu i'd half to advise replaceing your phone.
Posted on Mar 27, 2007
2006 pt cruiser oil leak three small drops all with in a foot and a half of each other
When the head was removed to replace the head gasket, likely oil was 'spilled' down the sides of the engine block. If it wasn't completely cleaned, it may have accumulated on the frame cross member or other components below the engine. I would clean up the drops on the floor and watch for additional evidence for a couple of days. If they keep appearing, take your car to the shop that did the work and have them check it out for you.
Aug 26, 2017 | Cars & Trucks
Not working, I have to push hard with my open hand on top of the Verbatim and hold it there to work
you have probably dropped it to the floor and has received a good impact.
try to repair the case, or better still, get a new one, more than probably won't last long
Nov 18, 2015 | Verbatim 47672 3.5 inch USB 3.0 Desktop...
How to adjust rifle scope
You need to sight in the scope and rifle to 100 yards then reset the dial making sure the knob as the manual says
do a check sight in
Then you turn on the electronics
the drop number you input is 112 and the BC is 55
as you haven't given an altitude for sight in or shoot site I have allowed for them being equal
you now shoot at a target at 400 yards and for each inch below or above the aim point add or subtract 6 from the drop number
drop number entered is 112 and your shot is 4 inches low
4x6=24 so your new drop number is 136
and if 4 inches high the drop number is 4x-6=-24 new drop number 88 so you now change the inputted drop number to the ones you have and shoot a few groups at 400 to confirm point of impact and aim point and adjust accordingly
Forgot to explain that the 112 drop number is the calculated drop for your round at 750 yards and that you are changing it by confirming the actual drop at 400 and the scope is calculating internally for 750
Apr 10, 2017 | Burris Optics
I dropped my LG impact in to a pool and pulled it right out immediatly and pulled out battery and sim card and put it under the hair dryer on low, but it still not coming on and it been 2 days, is their...
Hello
Well, you an try placing the phone in a sealed container filled with a cup of rice for about 24 hours. No guarantees, just a last resort. This sometimes work.
Kind regards
Andrea
Aug 16, 2010 | Cell Phones
P0102 maf or vaf A low circiut input is the code what are the possible solutions I have recently replaced the fuel pump, fuel filter and air filter. When i start the van refs high if i slightly push on the...
You have also tried replacing the Mass air flow sensor. How does it run with it unplugged? You can also get all your symptoms and the MAF code from a plugged catalytic converter.
Jul 13, 2010 | 2001 Pontiac Montana
Eljer Flushmate Floor Mount Floor Discharge 1.6gpf rim impaction
try putting KLR or even vinegar down the tubes. also using a stiff brush and klr or vinegar, scrub the jets from inside the bowl to help remove and soften it up. your coat hanger may only be compounding the problem by packing it in harder and tighter. when you get it running again, and it is a good one, make sure and put a bowl cleaner that also softens the water. can't say brand names..... but there are several good ones.
Feb 03, 2010 | Eljer Aqua-Saver 12" Two-Piece...
We self cleaned and the 2 days ago and the door is still locked. Help
The lock is operated by a solenoid and may have stuck due to friction or goo around the magnet core. Try bumping the stove or lifting it 2 inches in front and dropping to the floor. 2 inches will not break anything. There may be a mechanical timer in the self-cleaning circuit... is your gas stove still plugged in and showing signs of power such as ability to ignite top burners electrically? If the timer has failed the door lock solenoid is still activated and there could be a slight hum. Try unplugging the range and see if the door can be opened. The thermal interlock should be free to let the lock retract. If that works replace the timer motor. If solid state (no timer motor) replace circuit board with timer relay.
Dec 12, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
325i not starting
Generally that means the battery is to low or the starter draw is too high.
Try a different batter or charging the one you have. Put a volt meter on the battery next time you try it.
It should read 12.5 volts about, with everything off. When you try to start, it should drop to about 10 volts. When you stop trying, it should come back to 12 at least. If it drops below 10, something is wrong. If it does not come back to 12, it is probably the battery. It is drops below 10 and does not come back to 12, it is probably the starter.
Oh, and make sure the engine can turn over by hand, just to ensure it is not locked up.
Oct 03, 2009 | 2001 BMW 325
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
