Question about LG WM0642H Front Load
Door swing on a LG WM0642HW
Does anyone know if the door swing can be reversed? I know it's not as simple as on a dryer, but can it be done?
  • 8,197 Answers
Sorry on that model you can not reverse the door.
Posted on Dec 18, 2008
I have an LG front loader washer Model VM4270HVA and I want to know if I can reverse the door to swing open to the right as opposed to the left?
Some washing machines are available with the reversible doors, but only a few of them do (and they are expensive). Most times, you would have to order the machine with the specific door opening. You can probably check with LG support for a definite answer.
Jul 13, 2017 | LG Washing Machines
Reverse the dryer door
can not be done
Jun 24, 2016 | Dryers
How do I reverse the door swing?
Sorry but you can't - only the dryer allows you to reverse the door on these type of appliances...
Jun 15, 2014 | Bosch Nexxt Premium WFMC6400UC Front Load...
How to switch door side on dryer
Not that simple like it is on a modern refrigerator. The electrical wiring is set up for a door safety switch. That switch can probably work either door swing. The door would need to be reversed and holes cut in the dryer for the latch. The old latch would need to sealed up. It is uncertain that the metal on both sides is capable of supporting the door hinge. In any case it seems like a difficult and doomed task.
Jan 03, 2014 | Maytag Centennial White Gas Front Load...
How to change doors from right to left on Whirlpool Duet
Duet dryer doors cannot be reversed for the swing. They wil only open one way. Depending on your model of washer the newers ones will allow you to reverse the door swing without a kit. The older units require a kit to reverse the washer door.
Apr 22, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
REVERSING DOOR SWING
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
Door swing
yes any door swing can be reversed.take a good look and you will see the screws covered up with plastic covers .the door has to be removed first but check it out and you will see its not a big job get everything ready and it can be done within 10 minutes.adrian,,,,
Jun 29, 2010 | True 19 cu. ft. / 538 liter Commercial...
The door on my dryer and washer open the wrong way
Are you planning to reverse the door swing direction on your
DUET®dryer? To do so, you will need to purchase a Door
Reversal Kit.
To order, call the dealer from whom you purchased your dryer or
refer to the "Assistance or Service" section of this manual. Ask
for Part Number 8530069 (Shield Blue), 8530070 (Shield
Platinum), 8530071 (Biscuit) or 8530072 (Pewter).
Door Reversal and Stack Combination Kit
® ® DUET dryer and stack your DUET washer and dryer? To do so,
you can purchase a Door Reversal and Stack Combination Kit.
for Part Number 8530073 (Shield Blue), 8530074 (Shield
Platinum), 8530075 (Biscuit) or 8530076 (Pewter).
From the manual, Page 4. Hope this helps
Eric
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0802161.pdf
May 24, 2009 | Whirlpool Dryers
On these model you can only reverse the door swing on the dryer but not the washer.
Alternatively, you can switch places with the washer and dryer provided the washer fill and drain hoses are long enough and there is enough room without obstructing the dryer exhaust vent .
If you want to know how to reverse the door swing on the dryer, post your model number and I will try to assist you further.
Apr 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer door opens with hinges on the left
nope sorry but all front load washers are built with a locking system on the door and that makes them impossible to change the door swing.
the only thing you can do is move the washer and dryer position by getting longer hoses and venting so you can have the washer on the left and the dryer on the right.
Dec 28, 2008 | LG Washing Machines
LG WM0642H Front Load Logo
884 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
