Does anyone know how to unlock this prison issued mp3 player?
SOURCE: MP3 Locked...
The lock is a small silver slide switch located on the side of the unit labelled as "HOLD". Slide that back to the right.
SOURCE: Hasbro Made for Me Digital MP3 player
There are 4 batteries in the MP3 Player. 3 operate the larger part of the unit. One runs the Music storage device. Changing out that battery should do the trick!
SOURCE: how do i put music on my mp3 player
if you already have songs in your computer connect your mp3 player it will say open folder answer yes, then click on the corner to lower or move your window drag your song from your computer folder to that window usually e or f. to drag the song you need to click and hold down your left mouse button on your song and move it to your e folder then release button. another way is by click right button on song then choose copy from the list then go to your mp3 folder e and right click then paste.
SOURCE: i lost my software for my mp3 player help me
http://www.rcaaudiovideo.com/product.aspx?product=27&post=6
for software
for pc not recognizing-
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Has anyone figured this out?
brand new AMP'd maxx 4 gb stopped working during fist song. It is now stuck on the loading screen
I have the same player. need a patch or something :'(
The players are locked by Access secure media system to keep us out and you have to send it to them with $25 or $50 to get it unlocked to retrieve music off or put more music on...The company and keefe should all be burned
Call 1-877-760-1118 to get a Return Authorization (RA) number. Then ship to
Access Corrections
10880 Linpage Place
St. Louis, MO 63132
They put a file called FIRMWARE that causes the computer to see it as an empty drive. Please insert disk is the message when I plug it in. Am looking for a way to see drive again and remove it.
