Question about Hitachi 51UWX20B 51" Rear Projection Television
Loss of picture
When tv is turned on picture has curved lines then turns green and shuts down
    President:
  • 3,130 Answers
First thing to do is look at the boards at the bottom of this TV set. If you see a puddle of liquid, or see any eveidence of liquid on the printed circuit boards, you will need to install new "O" rings in the picture tubes as well as new collent, as the collent is leaking onto the boards and the boards will need to be cleaned or replaced. another possiblity is that you have a bad DM module. The DM module has three capacitors that will be all around each other and will be 1000MFD @ 16VDC. You will see if they are bad as the tops of them will look swollen. Good Luck
Posted on Mar 27, 2007
Turn tv on,picture good for 4 seconds,then green curved line like a rainbow all green,then 4 green sequence flashes,picture goes out theN volume continues for 2 seconds then out front red power light then...
This is a set with bad picture tubes-not available except on rebuild basis.
Are you seeing bright green screen and then set shuts off?
Let me know so I can help--8 blinks is AKB error.
SD TECH
Sep 15, 2010 | Sony KP-51HW40 51" Rear Projection...
TV turns on with a green screen with curved horizontal lines.
It seems you may have a serious problem with your video board. That's why you are getting those symptoms. It's better if you replace it asap!
Aug 04, 2009 | Mitsubishi WS-48315 48" Rear Projection...
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
Sony KP-51WS500 projection tv. Screen is green with curved lines
The green picture tube has an internal short. Happened a lot with that model. The tubes are no longer availible. But a reputable company called Video Display will rebuild the tube completely. But the tube must be pulled and shipped to them. Most repair shops would charge around $400 to $500 for the complete job.
Jul 09, 2009 | Sony KP-57WS500 57" Rear Projection...
Distorted picture,After power loss
Replace both STKs covergence chips 392-56or 570s use same STK numbers.
Dec 12, 2008 | Mitsubishi VS-50805 50" Rear Projection...
Tv problem
bias on green is too high or current is too high^^^turn bias down on focus block^^^--curved lines(not retrace lines) convergance IC`s going or resistor(s) out of range^^^replace them^^^
Sep 10, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Sony 2002, kpws500
Minium is the green picture tube need to be replaced, if you can take the front cover and access panel off there is a control with 3 focus and screen controls.
you can adjust the 3 screen controls to possibly get a little more time out of it before the crt's need to be replaced. careful if you turn them down too much there will be no picture, and if you turn them too high the tv will go bright and shut off
Apr 13, 2008 | Sony KP-57WS500 57" Rear Projection...
Problem with picture and sound
A board (signal) bad ? or possible B board.....proof is by
substituion = can get expensive.................T.
Oct 13, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
RCA 52inch TV
If the screen control for the green picture tube is set too high, then the colors will be greenish, there will be green where there should be black and there will be fine curved lines (retrace lines) in the picture. If you feel confident then you can open the set and look for the focus block which has the 3 focus and 3 screen controls. One row is labeled Screen and the green control will be the center one. Try turning that control down a little and see is the green background and curved lines go away. If they do not go away then there is something more serious wrong. If you do not have experience working on projection sets then allow a qualified tech to handle it for you.
Jul 13, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitachi 51UWX20B 51" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
