Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Power cord will not retract on my Electrolux UltraLux 2000
Power Cord over extended and will not retract
    Scholar:
  • 44 Answers
You will need to take the machine apart to correct this. Open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl covered strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl separates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come off relatively easily, and everything will be exposed. Now, assuming that the cordwinder isn't damaged, you should be able to wind the cord in by hand. Once it gets started it may start to retract automatically. Usually the spring just gets in a bind against the housing when it's over extended, and rolling it in by hand a little will free it up. Good Luck!!
Posted on Jan 05, 2009
Bissell momentum canister vacuum retractable electrical cord not retracting
Either the cord inside is caught on something or the retraction spring is broken.
Try to pull it out further, if you can feel any spring-back then most likely the cord is caught, maybe on itself.
Either way, the canister will probably have to be disassembled to fix the problem.
Sep 17, 2016 | Bissell Vacuums
Ultralux vacuum 2000
Several possible problems can cause it not to run. The cord reel often gets lint in side and fails to conduct. Carbon brushes in the motor could have worn out. One of the interlocks that keeps it from working with the bag out can be broken. You need to take this to a local vac shop.
Aug 12, 2014 | Electrolux UltraLux 2000 Bagged Canister...
360 manual
With all that's involved in replacing the cord and potential cord reel damage, it's more cost effective to just have the entire cord reel, complete with new cord, replaced. Less time consuming thus less costly to you. Hope it helps!
May 26, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
Why electrolux pwr cord will not stay out?
The locking mechanism inside the cord winder is defective and needs repaired or replaced. Hope that helps!
Apr 23, 2014 | Electrolux UltraLux 2000 Bagged Canister...
I have a Hoover Legacy model S3592 and the cord will not retract, it is fully extended. How can I fix this problem? Patty Lester
You may have to dis-assemble the machine to the point where you can gain access to the mechanism that retracts the cord. Then see if it can be fixed or needs replacement. Just don't lose any parts when dis-assembly, and make sure everything is put back together correctly.
Oct 14, 2013 | Hoover Elite & Legacy Vacuum Cleaner Belt...
The power cord does not retract or rewind when the button is pushed. How can I repair this?
Sometimes you can help get the springs working again, by gently pulling the cord out a little further and then let it slowly in while pushing the cord retract button.
Nov 08, 2012 | Kenmore 25512/ 25513 Progressive Canister...
The plug in cord will not retract. How do you take the end off to repair?
You can usually get it to rewind by tipping the front up and gently tugging and releasing the cord.
The back doesn't come off unless the top is separated from the bottom first. Do to difficulty in disassembly without breaking something, and reassembling correctly, I strongly recomment taking it to an authorized Aerus Electrolux store for repair.
http://www.aerushome.com/storelocator/
Apr 05, 2011 | Electrolux UltraLux 2000 Bagged Canister...
The power cord is fully extended and will not retract in Miele LUNA vacuum cleaner model s4580
Keep playing with it, it will go if you are careful. The alternative is to disassemble the device and get involved with the retractor system. This is not always a simple task with springs under tansion, reassembly required about 8 hands ... which MAY be a small exageration.
Thanks for your question @ FixYa.com
Mar 23, 2011 | Vacuums
CORD SPOOL WILL NOT PULL BACK
Try tilting the vacuum to about a 45 degree angle. Gently tug and release the cord a few times. This usually will release the cord. If not, the cord winder may have broken, or the spring came loose, and it needs replaced/repaired. Take it to the nearest Aerus Electrolux store for help/repair.
Jan 19, 2011 | Electrolux UltraLux 2000 Bagged Canister...
The power chord on the 2100 electrolux will not retract
Try standing the vacuum on end, or at a near vertical position, and gently tugging on the cord a few times. This will usually cause it to retract. The problem is usually caused by pulling the cord out too far. Avoid doing this as it can result in disconnecting or breaking terminals and/or wiring.
Jan 12, 2011 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
753 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
