Question about Ovens
I AM TRYING TO FIX A EB378610 SINGLE OVEN THAT HAS NO POWER WHEN YOU TRY TO BAKE. IT HAS 220V INTO IT. LIGHTS AND EVERYTHING ELSE WORKS. CANYOU HELP
  • whiteappy77 Dec 23, 2008
    while the element maybe correct there is no control board on this model.
    Sergeant:
    Champion:
  • 338 Answers
If you test Bake (Yellow Wire) to L2 (Red Wire if your oven has it) and you read 240 volts while the oven is on and baking you need a new element. If you take the bake wire off and test the tab coming off the board to ground if you read 0v while the bake is on then you need a new control board
Posted on Dec 18, 2008
  • Robert Artiaco Dec 23, 2008
    how was that inappropriate?
  • Robert Artiaco Dec 24, 2008
    roughly how old is the stove?
Maytag precision touch control 500
Either both bake and broil elements are burnt out (highly unlikely) or your control / clock may be bad. Also check to be sure you have 220v going to unit.
Oct 02, 2017 | Ovens
Turned on oven, waiting for it to heat up and saw a bright flash of light and now nothing works control panel doesn't even light up
the bake element shorted out turn of the power to the unit and replace the bake element or bottom cooking element that will fix it
Apr 03, 2010 | Whirlpool RBS275PD Electric Single Oven
My Maytag Performa oven and stove top will not turn on (heat up)
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
My oven has power but it does not work. When I
Your control panel is faulty and will need to be replaced. You can get another one at repairclinic.com or partselect.com
Jan 13, 2010 | GE JKP15 Electric Single Oven
Kenmore electric oven will not heat, broiler and stove work fine
I also have the exact same problem, is ther a possible fix-it-yourself solution for this???????????? if not what should a repair cost?????
Sep 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Nothing comes on
If the breaker won't reset, then you have a fault with your oven,probably an element blown.
If it does reset o/k, and still does not go, then I suspect that you have no power at the oven.
You will need to gain access to the cable entry at the rear of the oven and check the wiring and connections
Plz leave feedback.
Thanks.
Dec 10, 2008 | Kenmore 47783 Electric Single Oven
I ran the self-clean mode this morning. After it finished this process, I preheated the oven to do some baking, and now the oven won't heat at all.
I am going to assume that you selected bake as you normally would and there are no faults (error code) reported. - this would mean there would not be a problem with the controller or the temperature sensor. The problem may be with only the bake circuit - so try the broil function - If the broil works then you may have a problem with the bake element or the connections to it or the relay on the controller - check the connections first then the element - If the broil does not work also then you may have a problem with the relay on the controller or the connection of the other leg of the 220v supply.
Make a check or have someone check it and wrte me back a post here
Regards
Oct 04, 2008 | Whirlpool RBS275PD Electric Single Oven
Maytag gas oven mgr5770abb Does not light when I try to use oven. Broiler works fine. When I try to turn on the oven, the broiler igniter does not glow. If the bottom igniter was bad, wouldn't the top one...
first I would check to see if you have power (120v) at the bake igniter..when you set in to bake...use a multmeter..(when you turn on the oven to bake only the bottom igniter will come )
good luck be safe
let me know if I can help
Aug 15, 2008 | Maytag CWG3100A Gas Single Oven
Maytag oven will not light
Have you tried to broil or bake? if only one of them work you have a bad ignitor. let me know and we can go deeper
Aug 23, 2007 | Maytag CWG3100A Gas Single Oven
Electric Oven Won't Heat
Rob, sounds like it was just installed. You need 240V on this unit. On the terminal block in back where the power hooks up, it should read 240V across the two outer terminals and 120V from each end to center terminal. Im ruling out the thermal cut out because you never used it. I would start with the power source first. The display sounds like it's getting the 120V it needs to funtion, but I don't think your making the loop for the 240V needed for the bake and broil. Catriver.
Jul 12, 2007 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
