SOURCE: MAGIC CHEF TIME SAVOR GLASS TOP
Got to this address http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=MCF
And enter the model number
SOURCE: magic chef manual
You can download it here but you need the right model #.
As for the temp adjust it is best if you get an repair man out to do that.
Good Luck
SOURCE: I just cleaned by hand by magic chef wall oven and now I can't
Pilotless ignition means that a hot surface ignitor lights the oven burner. It does take a little bit of time to light the burner. Maybe 30 seconds. If you want to make sure it lights take the bottom panel out from the oven and observe the hot surface glow and the burners light. No real danger as the gas valve will only open after the hot surface ignitor has satisfied the gas valve. Let me know how it goes. ken
SOURCE: My Magic Chef 21MS Natural Gas Oven will not heat
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
SOURCE: Our magic chef oven starts beeping and gives us a
f1 indicates a shorted touch pad ,if you want to make sure ,unplug unit ,disconnect touch pad from computer board ,if f1 goes away touch pad is bad.if not replace board
