Question about RIM BlackBerry Curve 8310 Smartphone
Blackberry wont turn on just shows red line through battery
Two weeks ago my blackberry went blank, will not charge up and the only sympbol is a battery with a line through it. I have replaced battery and it still shows the same symbol. I have the same problem, anyone know how to fix?
  • quack_simon Dec 18, 2008
    I just had the same problem, but i had gotten batteries switched and i switched back to other one and it seems to work fine, so make sure you have correct battery and make sure it contacts right!! hope this works!!
  • 90236ak Dec 25, 2008
    I had the same problem. At first I was able to change the battery with another old battery I owned and that worked fine. But then it happened again and changing the battery again would not help. I tried calling T-mobile and they said I needed to bring it in to a T-mobile store for them to see it first hand and for them to try a new battery. The tech at the store was not shocked to see the symbol and contacted T-mobile support who quickly agreed to replace the device at their cost.
  • 2,794 Answers
Sounds like the display. There is a warranty on the unit. Contact your provider to find out what your service and replacement options are.
Posted on Dec 18, 2008
2 Suggested Answers
SOURCE: blackberry wont turn on just shows red line through battery
just put a piece of paper on the top of the battery (the part where u push it down) it shows the battery with a red line slashed across because its too loose...
it worked for me!
Posted on Nov 01, 2009
My blackberry curve 8520 is at low battery and wont charge or show the charge lightning bolt
King, many times this happen, don't worry, put your device on charge 2 to 5hours it will solved, if problem persist, change battery, because this sounds me a only battery problem. there is one another way (if you are not sure don't try this) we call that direct charging
first take one charger who has light on head and then cut the charging connector of charger and then you will see two colours of wires separate the black and red wires (red wire is positive line and black is negative line) and then connect to current supply but make sure there wire are separated otherwise it will have a short circuit and then take battery and search + and - connector and then red wire connect on battery positive connector and black on negative connector if you connect properly you will see the charging light are getting dim. that mean it is charging, do direct charge for 10 min and then switch on your device with battery and put in charge normally. this will solve your problem. if my sugetion was helpful please rate it.
Jul 02, 2012 | RIM BlackBerry Curve 8520 Smartphone
MY BLACKBERRY BOLD 9000 WON'T TURN ON!!! My friend gave me her Blackberry Bold 9000. It's battery was replaced a few months ago but it hasn't been used since then. When I plug it into the wall charger,...
Ok...don't panic. The charger you are using is not compatible. Verizon only works with verizon blackberry's. Non verizon will not work with blackberry and vice versa. This is what will happen. you plug it in and it will boot for a few seconds and then the lightning bolt you see is the charge icon and then a red line in it means that charger is not compatable. Blackberry does make its own charger but there is a "pin" on the plug in that will tell it it is not the right one. Am I confusing you?
Jan 06, 2011 | RIM BlackBerry Bold 9000 Smartphone
My blackberry just stopped working on me a few weeks ago it wont turn on or even charge its just dead what do i do ?
someone should help :) because i just had the same issue! (starting yesterday). i went to the tmobile store and had them look at my phone. they tried my battery in someone else's phone and it worked, so it isn't the battery. the red light doesn't come on when it's supposed to be "charging" -- which it's not doing that either. but all the people at tmobile told me was that it's the actual phone.. yet they didn't tell me how to solve the issue or if i could get a new one or what.. all they said was that i was eligible for a 2 year upgrade.
what do i do with my phone and how can i get it to work?! i need the numbers out of it. thanks.
Oct 13, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
Been on charge all night. wont turn on and has rotating black clock in centre of a blank screen
my blackberry curve went dead and when i placed it to charge for the entire night i tried to turn on the phone and it wont turn on but there is a red light on the phone for a few minutes .... what can i do?
Nov 05, 2009 | RIM BlackBerry Curve 8520 Smartphone
I dropped my blackberry bold and screen is white with red line
That means no battery, your lucky. Just go to a phone place and try a new battery. I am assuming you already took the battery out and tried reinserting it. Does the battery have red xx's on the bottom, if so it probably fell on grass and the moisture got to the battery some how.
Aug 24, 2009 | RIM BlackBerry Bold 9000 Smartphone
I can't turn my blackberry on.
The battery has been drained too much. You'll need to get a new battery or the battery needs to be externally charged to at least 50% externally
Jun 18, 2017 | RIM BlackBerry Bold Smartphone
The battery on my blackberry 8310 went dead. I
ok so what u basically do is just keep the charger in the usb port. then take the battery out then plug it back in. this totally works!
Apr 01, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
MMS PICS DONT SHOW UP
I started having the same problem about 2 weeks ago. Found out that my photo went to my photo album online because whatever was sent was too large for the phone. I went in and went to the recent photos and there it was. Carrier doesn't know either. I also went to the Browser, menu, options and browser configuration and checked the appropriate boxes to allow certain media files.
Mar 21, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
it worked for me!
Nov 24, 2008 | RIM BlackBerry Pearl Smartphone
Blacberry pearl niot charging
I have a new blackberry pearl, have had it two weeks and today it will not charge no matter which charger I use so I don't know what the deal is.
Jun 10, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry Curve 8310 Smartphone Logo
1,283 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
