Question about Brother IntelliFAX 4100 Laser Fax
Time/date My fax time and date are never accurate Gains time Power drop and it has to be reset all the time. Is there any battary back up for this??
  • Anonymous Jan 03, 2009
    date and time changes automatically
  • 215 Answers
This is a known problem with some of these 4100's. you have to have the firmware/flash rom upgraded via brother. upgrade to flash rom version M. best done by an authorized service center. contact brother customer support and see if they can help or if you have an authorized service center around close, i would call and speak to a tech.
razors
Posted on Jan 28, 2009
How do I reset the time on the fax machine. The time showing is not correct its out about 15 minutes
Faxes are more than 15 minutes out of date. More like a decade plus.
But if you insist, go back to menu, setup, station, then reset date and time.
Oct 31, 2017 | The Office Equipment & Supplies
Cloc gains time
well without the make and model number I can only answer generally , most clock radios use the power line to sync the time base (60 hertz=60 seconds = 1 minute=60 minutes=1 hour) , but they use a internal time base generator when running on battery back-up (that's not so accurate) , I had one some time back that a customer plugged into a switched outlet (unknown to them) in there room and it did exactly the same thing it gained about seven minutes every day , me id check the outlet its plugged into to see if its on all the time (a quick test 4 this is to remove battery back up ) clock will then flash to be reset if you come back later to see it when the power was shut off
Jul 26, 2016 | Audio Players & Recorders
How do I change the time on the Brother 2820 fax?
This was taken directly from the Brother 2820 Manual:
Setting the Time
When the machine is not in use it will display the date and time. If you set up the Station ID the date and time displayed by your machine will be printed on every fax you send. If there is a power failure, you may have to reset the date and time. No other settings will be affected.
1 Press Menu/Set, 0, 2.
[2. Date/Time]
2 Enter the last two digits of the year.
Press Menu/Set.
3 Enter two digits for the month.
Press Menu/Set.
(For example, enter 09 for September,
or 10 for October.)
4 Enter two digits for the day.
Press Menu/Set.
(For example, enter 06 for 6th.)
5 Enter the time in 24-Hour format.
Press Menu/Set.
(For example, enter 15:25 for 3:25 P.M.)
6 Press Stop/Exit.
The LCD now shows the date and time
whenever the machine is idle in Fax
mode.
When the machine is in Sleep mode, the
LCD shows Sleep. (See Sleep Time on
page 2-8.)
Turning on Automatic Daylight Savings Time
You can set the machine to change automatically for Daylight Savings Time. It will reset itself forward one hour in the Spring and backward one hour in the Fall. Make sure you have set the correct date and time in the Date/Time setting.
1 Press Menu/Set, 1, 5.
[5. Auto Daylight]
2 Press Up Arrow or Down Arrow to select On (or Off).
Press Menu/Set.
3 Press Stop/Exit.
May 03, 2011 | Brother IntelliFax-2820 Laser Fax
How do i set the date on Brother intellifax 2820?
Setting the Date and Time
Your FAX/MFC displays the date and time and prints it on every fax you send.
In the event of a power failure, you may have to reset the date and time. All other settings remain unaffected.
1 Press Menu/Set, 1, 2.
2 Enter the last two digits of the year, and then press Menu/Set.
3 Enter two digits for the month (for example, enter 09 for September, or 10
for October), and then press Menu/Set.
4 Enter two digits for the day (for example, 06), and then press Menu/Set.
5 Enter the time in 24-hour format (for example, enter 15:25 for 3:25 PM),
6 Press Stop/Exit.
The LCD now shows the date and time.
Dec 02, 2010 | Brother IntelliFax-2820 Laser Fax
How do i set the time and date
Hi
Note If you press Start Fax Color but the sender sent the fax in black and
white, the HP all-in-one prints the fax in black and white.
Set the date and time
You can set the date and time from the control panel. When a fax is transmitted, the
current date and time are printed along with the fax header. The date and time format
is based on the language and country/region setting.
Note If your HP all-in-one loses power, you will need to reset the date and time.
1 Press Setup.
2 Press 4, and then press 1.
This selects Basic Fax Setup and then selects Date and Time.
3 Enter the month, day, and year by pressing the appropriate numbers on the
keypad. Depending on your country/region setting, you might enter the date in a
different order.
The underline cursor is presented initially beneath the first digit; it automatically
advances to the next digit when you press a button. The time prompt
automatically appears after you enter the last digit of the date.
4 Enter the hours and minutes.
5 If your time is displayed in the 12-hour format, press 1 for AM, or 2 for PM.
The new date and time settings appear on the control panel display.
All The Best: Pineworks
Jan 28, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Hi, Power surge knocked out power briefly, but now we are getting no printed confirmation sheets that fax was transmitted. How to reset??
Press
Function
74
set
12
set
set
stop
To reset date and time press'
function
71
set
enter date and military time
set
stop
Oct 22, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
Date and time wrong on the journal
to reset the time and date on the machine you need to hit
Time/date
Function-7-1-start- then adjust the time and date and hit start then stop
Com journal after every fax
Function7-4-start-1-2-start-2"should says always" then start stop
receive time print." puts the time and date of your machine of the fax..example if your receiving a fax from new york and your in california it will put your time and date at the bottom.
Function7-4-start-9-start-2"should say valid" start then stop.
as for why your losing your time and date all the time is because the battery if dead on the machine.
hope this helps.
Jan 07, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
Problem with time staying
From Brother Support Website.....
PPF4100 (Clock Gains ½ hour)
The LCD clock on the PPF4100 gains a half hour every 24 hours. Units affected were manufactured between January 2004 and April 2004. The machines manufactured after s/n D4J419125 have the new firmware already installed from the factory.
Machine will need to be taken to a service center and have a firmware upgrade done.
Inkworks
866-381-0541
Nov 04, 2008 | Brother IntelliFAX 4100 Laser Fax
Panafax UF-755e
Sometimes when this machine loses power it goes to a default setting (flashing time and date) You will need to got to the user parameters and reset the time and date. If you refer to your user manual it will tell you how to do this.
Hope this helps...
Jun 16, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Brother IntelliFAX 4100 Laser Fax Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
