Question about MTX Ford Explorer/Mercury Mountaineer/Mazda Navajo 1991-2001 Thunderform Loaded with 10 Inch Woofer and ... Car Speaker
2001 Mercury Mnteer Shuts Off 4 min after start.
My 2001 Mercury Mountaineer shuts off 3.5 to 4 minutes after initial start up on cold mornings (25-45 deg.). I want to warm the vehicle up but half to go back out within minutes to restart. Starts again without any problems and runs GREAT. Tried Lucas injector cleaner for three fill-ups, no luck. Was advised on replacing coolant temp sensor, I havn't done it yet though. Any ideas??
  • 27 Answers
Why don't you try replacing the coolant temp sensor?
Posted on Dec 18, 2008
  • Guy Dec 18, 2008
    Also, adding a remote start will keep you from having to go outside in the first place. It will also keep someone from driving off with your car when they see those keys hanging there with the engine running.
2000 Mercury Mountaineer won't start this morning. It's been freezing temperatures lately, what can I do?
Use a product like HEET. Have someone check the water temp sensor for being stuck on hot. Sensor must put vehicle in cold start sequence.
Jan 14, 2017 | 2000 Mercury Mountaineer
My vehicles shuts off after 3 three minutes of use or when its idling after first initial start but starts perfect when the engine is heated up. Can you help me with this problem?
Car starts then dies in a few seconds - CarGurus
www.cargurus.com > Questions > Ford > Crown Victoria
CarGurusFeb 3, 2014 - Engine turns over fine and starts, but stops in a second or 2. ... Good fuel pressure, starts, runs for about 7 seconds, dies after a sudden drop in fuel pressure. ...starts 15 minutes later, runs fine then stumbles and dies again 3 answers ... I drove carhome shut off and next morning would not start, but will turn ...
94 camry le 4cylinder starts when cold, shuts off .
Nov 23, 2015 | Cars & Trucks
Start snow blower runs for 3 min. and starts to over heat checked oil its ok then stats to shut down like its not geting oil
Why do you say its over heating .Runs for 3 minutes the oil is OK .
Do you understand how the choke works .
bacsicly you prime the mechine in cold condutions 3-4 pumps choke to max throttle at 3 /1/4 .
Start backing off the choke after 3-to4 mins .
The choke shuts the fresh flow down to the engine in cold condutions ware it needs more fuel then air to run.
When the engine starts to get hot it can't run with out fresh air to mix with the gas it won't run anymore because there is to much gas and not enough air
Its simple fool prof will work everytime if you adjust it right
Mar 01, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Any suggestions on why my 2004 mercury mountaineer shuts off while driving?
Check fuel filter for blockage,check module in distributor/coil etc.
Jul 25, 2014 | 2004 Mercury Mountaineer
The unit shuts down after using for 4-5 minutes and I smel burnig
Sadly, light duty machines as yours do overheat and shut off. Shredders are rated for run time. An example: 4 min run time with 60 min off to cool down. I could not find your machine's rating. However, given the 10 page volume I would guess the rating close to the 4 min on.
High volume shredders are rated as continuous run. They should never over heat.
Apr 21, 2009 | Cross Infoguard Shredder SX102M
99 mercury cougar wont idol until car is warm p0420 codes came up
Hello, here is a thread I found on this site with from what it looks like, the same problem(with an added solution) that you have. http://www.fixya.com/cars/t1576683-1999_cougar_diagnostic_code_p0430_p0420
Jan 29, 2009 | 1999 Mercury Cougar
2005 Mercury Mountaineer shuts off
Could be a number of things and the information is a little vague. Does it do it when cold, warm, after driving for a distance etc. It might pay to have some one run a diagnostic machine on it. The cost for the test could actually save you money. Just make sure they have a good reputation.
Sep 13, 2008 | 2005 Mercury Mountaineer
No start 2002 Mountaineer
It sounds like a bad solenoid/ bendix or pssibly a bad ground connection.
Aug 22, 2008 | 2007 Mercury Mountaineer
2001 Mercury Mountaineer won't start
Have a load test done on the battery. If it checks out good, take a voltmeter to the battery and have an assistant rotate the engine. If you see more than a 2 volt drop when the car is being started, the starter is heading south.
Jul 02, 2008 | 2001 Mercury Mountaineer
Car Audio & Video Logo
Top MTX Car Audio & Video Experts
hoyzee1
Marvin
Marvin
RegWorts
Level 1 Expert
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
