Question about Pioneer VSX-D514 Receiver
Digital Audio moved from TV/SAT to DVD/LD
My 1yr old son touched it today, my wife has no idea what he did... I have my Dish Network PVR running optical into the stereo, my dvd runs analog into the stereo, the stereo acts as a switch for all components and uses S-Video. My stereo has a switch (Analog/Digital/Auto). It has always been on auto. When tuned to TV/SAT, I used to use the Digital signal from the dish PVR. When I switched to DVD, I was using Analog. Now, if I watch TV/SAT I get no audio and I cannot change it from Analog (there is a button on the front). If I watch a DVD and it is set to Auto, I get the dish Digital signal. On the back it clearly says TV/SAT Optical input, and has a DVD Coax input for digital. If I change to Analog, I get the DVD audio. Somehow the TV/SAT audio moved over to DVD/LD. I have no idea what he could have done. Please help.
    Problem Solver:
  • 6 Answers
Using the remote control, push the left arrow until display shows Coax1 (or 2, depending on your setup), then push the up arrow to set it to TV/SAT.
Conversely, depending on your setup, you can push the left arrow to display Comp1 (or2) then push the up arrow to set the correct video setting-- DVD/LD I assume.
Posted on Aug 05, 2008
How do I hook up a Pioneer VSX-918V receiver to Sat.Dish box?
For the audio portion, you must have either a digital coax, optical connection or analog L/R composite RCA jacks plugged into the "Sat.audio in" on the rear panel of the chassis. The other end of THAT connection must come from the "audio out/ variable out" from the T.V. or from the Sat.Dish box.
Sep 12, 2014 | Pioneer VSX-918V Receiver
Today, while watching tv on the Dish, tv suddenly started powercycling. I unplugged it, waited, and then tried a DVD -- worked fine. Tried Dish again, power cycled again -- on off on off, 1/2 second of...
If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities.
Daniel Busa
DISH Network
Customer Service
May 16, 2011 | LG 47LD520 47 in. HD-Ready LCD TV
After programming my NEW Harmony One Logitech remote I can't get it to change channels on the Dish HDTV DVR along with a bunch of other problems.
To control a Dish Network PVR/Satellite, it needs to be set to respond to the default Remote Address (1).
To reset your Dish Network PVR/Satellite to the default Remote Address:
1. Press SYSTEM INFO on the receiver's front panel. The System Information screen displays on the nearby TV and shows the Remote Address.
2. Using the original Dish Network remote, press and hold SAT on your remote control for about three seconds, until all of the mode buttons light up, and then release SAT.
3. Using the NUMBER PAD, press the 1 button
4. Press POUND (#). If you entered the address correctly, SAT will flash three times.
5. Press RECORD. Make sure the Remote Address you see on the System Information screen is 1.
6. Press the SELECT button on the front panel to close the System Information screen.
7. Your Harmony remote should now control your Dish Network PVR/Satellite box
NOTE: Dish Network PVR/Satellite receivers sometimes have two tuners, allowing them to be used in more than one room on different TVs. Harmony remotes can only control a Dish Network receiver's main tuner while still in the same room with direct line of sight to the device.
What other issues are you having with the remote?
Dec 25, 2009 | Logitech Harmony One Advanced Universal...
Problem connecting DVD/VCR to DISH
Dish dvr can only output so you have to connect your dish dvr to your dvd/vcr and then connect your dvd/vcr to your tv and im sure it should work
Dec 19, 2009 | Televison & Video
When i watch dish network my theater system wont work ,only if i watch dvd it works
I run my s video from the dish reciever to the tv/satillite s video input and the digital audio to the digital audio input on my reciever. The reciever is a sony V333ES and have no problems at all.
May 30, 2009 | Coby DVD-958 Theater System
Can you connect an archos 605 to a bell 9142 pvr
Archos Dish Network Plug-In says:
  •  Quickly transfer hours of your favorite TV programming from select DISH Network DVR receivers and enjoy the shows you watch every day- on the go.
  •  DISH Network customers with ViP622TM and ViP722 TM DVR receivers can enjoy this next generation of PocketDISH service with Archos 605 WiFi and Archos 705 WiFi models
  •  This plug-in is free for DISH Network Customers.
  •  Not a DISH Network customer? Find out more at www.dishnetwork.com and get the most out of your Archos player today
  • Jan 24, 2009 | Archos 605 WiFi Digital Media Player
    Connecting DVD to cable only TV and Modulator box and Dish Networ
    Without knowing the actual ports on each of these devices, all I can suggest is that have you tried connecting your DVD to the Dish box (thru VCR scart connection at the back of the Dish box) and then the Dish box into your modulator (and then modulator into your tv.
    I have a similar system set up but we have a Sky Digital box here, no idea if its the same as a Dish box but im assuming so.
    Jan 01, 2009 | GPX D1816 DVD Player
    Programing dish network remote control for aiwa av-x220
    You will have to call Dish Network.
    800-825-2557
    Feb 22, 2008 | Aiwa AV-X220
    Optical inputs
    In short yes!
    If you have two optical inputs and two equipment (PS3 and HDVD) then you shouldnt have a problem at all. Just make sure you change the mode of the receiver to TV/SAT when you want to use the HDDVD. Your problem may be the video out put.
    If i was you i would do the following:
    1. Get rid of all your optical cables as you won't need it.
    2. If your receiver support HDMI then by default HDMI will send both video and digital sound.
    3. Plug the HDMI of the PS3 to the HDMI input of the receiver, plug the HDMI of the HDDVD player into the HDMI 2 of the receiver and plug 1 HDMI cable from the receiver to the tv/monitor you have.
    That is the best set up so when you play PS3 you select dvd/ld and when you watch hddvd you select tv/sat.
    However having said all that the fact that you have dvd/ld suggests you actually don't have HDMI at all on the receiver(...i just checked the specs of the receiver). Which means you will need to have 2 hdmi inputs for your tv and you will need to have the 2 optical connections.
    But in short yes to your question.
    hope this is not too confusing.
    good luck
    smeags.
    Feb 05, 2008 | Sony STR-DE595 Receiver
    Onkyo HT-SR750
    Check out Onkyo's website: The HT-SR 800 description says "a separate audio connection is necessary" Maybe it is true for the --750 too.
    Jan 01, 2008 | Onkyo TX-SR605 Receiver
    Pioneer VSX-D514 Receiver Logo
    232 people viewed this question
    Top Pioneer Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Ian Summerfield
    Ian Summerfield
    Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
