Question about Roper RAS8445KQ Top Load Washer
Need info on replacing lid switch on Roper Cloths Washer
How do you get the lid off to replace the switch
Posted on Mar 05, 2009
Roper washer agitator won't spin after kids loaded
It sounds like a someone has broke the lid switch to the washer. Below I have attached a picture, Item number 9 would be the part you seek. P# 3949247 Under the control panel you will find a harness that contains 3 wires coming out of the cabinet housing. The colors should be tan, white and green. If you jump the white and tan you unit should run and think the lid switch is working. Safety way is to unplug the unit to by-pass the switch and plug it back in and select spin only. This is only to test, you need a lid switch for safety. You should replace it ASAP if this test works for you.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 26, 2011 | Roper RAX4232KQ Top Load Washer
How do I remove the lid to a Roper RAX4232JQ top load washer? I need to replace the lid switch. Thanks
To replace the lid switch you need to unplug the washer first. Then remove 2 screws on either side of the control console. These 2 screws are on the back side of the control console and are on the far left and far right. They go in at an angle and are phillips head. They won't come out all the way, but loosen them enough so that the control console will flip up and backwards, it should not come off because it is hinged. Then you will see 2 brass spring clips, one on the left and one on the right that hold the entire case of the washer (top, front, sides, all wrap around) on. Remove those then the whole washer cabinet should remove. Be sure you unplug the lid switch located near the middle under the control console. Replace the switch and reassemble.
May 24, 2010 | Roper Washing Machines
I have a roper rax4232rq3 washer. The washer will
If this is a Whirlpool manufactured top loader (such as your Roper), the most common cause of the symptoms you describe is a lid switch malfunction. Symptoms may include, no spinning, no agitation, stopping at the rinse cycle and no draining.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30. Prices differ between sites so shop and compare.
If you have questions, or need additional assistance, please post back and let me know. I hope you find this information helpful.
Jan 21, 2010 | Roper RAS8445KQ Top Load Washer
I have a Roper Washer Model RTW4340SQD that
The lid switch is on the top left side of the top cover. If it is bad the machine will fill and stop. The lid switch must be good for the machine to agitate and spin.
Nov 01, 2009 | Roper RTW4300SQ Top Load Washer
How do I replace the lid switch on my waher it's a Roper
buy a replacement switch and the top lifts off from the front.  It could be the switch has only come loose or the probe on the lid has broken off.
Feb 27, 2009 | Roper RAX4233PQ Top Load Washer
Roper rax4232pqo wont spin
Still replace the lid switch. Most have multiple contacts.
Nov 08, 2008 | Roper RAS8445KQ Top Load Washer
Top loading roper washer stops at spin cycle
HI thanks for the question. the washers lid switch, is the problem. replace the lid switch. its located under the top.if you need more info. get back to me. thanks the appliance doc
Oct 06, 2008 | Washing Machines
Roper Washer filled with water and then stopped
HI thanks for your question. the problem you are having is with the lid switch, which is located uder the top. replace the lid switch. if you need further assistance . plese get back to me thanks the appliance doc. please rate my answer thanks
Jul 21, 2008 | Roper RAS6233KQ Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
106 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
