Question about Canon Pixma MP450 All-In-One InkJet Printer
Printer paper reloading
Hi I have a Canon Pixma MP650 that does not load paper correctly. I more often than not get the message paper jam and to remove the paper and hit the ok button. I remove all paper and reload the paper and hit print. The paper then does not feed properly. It has a noisy feed mechanism when it feeds, but when it does not feed the paper there is also no noise of the feeder being engaged. thanks
    Scholar:
  • 141 Answers
So the feeder woek sometimes, If you have a warranty, bring it back, if not , the printer might have something stuck in his mechanism or a bit of spread ink, open it and check for any weird thing, you can do some cleaning but the mechanism need some greassy spot so do not be too clean
then try a recommanded paper for the printer like 80g for example and no more than 30 new pages to begin.
You can test the printer when open, you just need to push a few switch or button to make it run also you will be able to see where the noise come from.
Posted on Dec 18, 2008
How do I load paper into my Canon Pixma MX452 printer?
A lot of times the printer has a small piece of paper jammed in it or has had a jam and will not recognize the new paper. Try this to see if it resolves your issue. http://www.wikihow.com/Clear-a-Paper-Jam
Jun 25, 2014 | Canon Pixma MX452
My printer (mp 160 pixma) shows error code 5,3,2 what is the problem
E2 = Reload the paper correctly and press [Black] or [Color]
E3 = If paper has jammed in the machine, clear the jam, reload the paper in the
machine correctly and then press [Black] or [Color].
E5 = The FINE Cartridge may not be installed properly, or the Cartridge may notbe the compatible with this machine. Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the FINE Cartridge Alignment.
Nov 02, 2013 | Canon Pixma Mp160 Mp 160 Photo All-in-one...
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
My all in one has an error message
E3 is a paper jam they may be small bit paper jam in side
Jan 17, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma MP160 shows errors E3 and won't print
Error E3 : Check if the paper has jammed in the machine, reload the paper in the machine correctly and then press [Black] or [Color].
Paper Jams :
Cause : Paper jams in the paper output slot/ Auto Sheet Feeder.
Landscape Credit Card sized paper jams inside the machine.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn the machine OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will eject automatically.
2) Reload the paper into the machine and press [Black] or [Color].
* If you have turned OFF the machine in step , you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
Important : You cannot load Credit Card sized paper in the landscape orientation.
Hope this helps.
Have a good day.
Dec 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Cartridge jammed
Error : Cartridge Jammed
Cause : The print head holder cannot move. This is normally due to a paper jam.
Action : Clear the paper jam or whatever is obstructing the print head holder. Reload the paper in the machine correctly and press [OK].
Hope this helps.
Have a good day.
Dec 04, 2009 | Canon PIXMA MP170 All-In-One InkJet...
The printer is not feeding paper but still gives the E3 error message
If paper has jammed in the machine,clear the jam reload the paper in the machine correctly and then press black or color key.If you are not success so it is problem mechanical.Service it and solve your problem.
Nov 24, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer jam
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-10
Jul 21, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper load and jammed problem
I have a problem of canon Mp180 printer. The problem is paper jam. When we start the print process and clear the process. It shows a message cancel printing.
Mar 08, 2009 | Canon Office Equipment & Supplies
E 2 and service error 5100 on Pixma mp160 printer
You can try to clean out the printer check to see if there is any paper jammed in it somewhere
Then realighn the printer cartridges and run a test page.
Make sure that the paper tray is not overloaded
Dec 24, 2008 | Canon PIXMA MP160 All-In-One Printer
Canon Pixma MP450 All-In-One InkJet Printer Logo
245 people viewed this question
old marine
old marine
