Question about SanDisk SDMX1 MP3 Player
Dont know what part to weld!!
The problem with my sandisk sdmx1 is that i can only hear the music through the headphones when i hold them at a certain spot or an angle and ive already gotten a couple of new headphones and its not the problem...I looked on this website and i saw someone who had the same problem and the solution was to weld a part back together but i need something more specific than that i already took it all apart but i don't know what to weld together with the paper clip!!!! What specific part do i need to weld??????????????????????? Someone please help!!
    Problem Solver:
  • 7 Answers
I hope I can help you since so much time has passed. This is a rather common problem with the SDMX1 and that is because the headphone jack was installed with too little solder. Here is what you do.
1. Dismantle the player by removing 3 screws ( 2 at one end and 1 at the other).
2.Carefully pry the end caps away.they should pop off.
3.lift the upper half of the case from the joystick end gently.
4.lift the entire circuitboard out. watch where the battery terminals are.
5.look at the headphone jack where it is installed on the smaller circuitboard.
6.on both left and right sides of the jack down on the circuitboard you will see 2 solder connections.
7.these are for the left and right channels.
8.if you look carefully (you might need a magnifying glass), you will probably see a very small break in the connection.
9.using a pointed soldering iron (no soldering gun here!), simply resolder BOTH connections using a very small amount to solder. This will most likely solve your problem.
10.put everything back together and it's as good as new. VERY EASY.
Posted on Feb 02, 2008
SOURCE:
Sandisk SDmx1 frozen on pause. Won't play music
Try the manufacturer's driver download wizard at http://www.sandisk.com/sandisk-support/driver-download-wizard
Jul 08, 2010 | SanDisk SDMX1-1024-E18 MP3 Player
My SDMX1- 256MB can turn on but doesn't play and turn itself off
dont know what "hall" is, and im guessing the battery isnt dead---might need to format it
Aug 12, 2009 | SanDisk SDMX1 MP3 Player
Sandisk Problems
ICH HABE EIN PROBLEM MIT MEINEM SANDISK SDMX1 1024R vR. UND ZWAR ICH BRAUCHE DRIVER FUER WIN98 DAMIT ICH MEINEN SKANDISK BENUTZEN KOENNTE.
MFG
Sep 09, 2008 | SanDisk SDMX1-1024-E18 MP3 Player
Mp3 player
If you have not downloaded any music into it, you won't be able to play it however, the FM radio should work. Dowmload the instructions from www.sandisk.com These 32 pages will explain everything!
Jan 28, 2008 | SanDisk SDMX1 MP3 Player
Volume Control
First go to www.sandisk.com and download the instructions for this particular mp3 player. I'm guessing it's the SDMX1. Look for this model and get the instructions. They're about 30 plus pages. Volume is adjusted very easily-Look at your SDMX1 with the data screen to your right and headphone plug to the right.
1.find the joystick control-it sticks up and is chrome plated.
2.imagine it is a compass with North-up
3.simply move the joystick North for louder volume and South for lower volume.
4.you can also read the volume numbers on the screen in the right lower quadrant. they go from 1-40. Good luck.
If you ever have headphone problems with sound from only one earphone, let me know. I know how to fix this better than new! Also, if the play-on/off switch becomes hard to operate, this fix is also very simple.
Jan 06, 2008 | SanDisk SDMX1 MP3 Player
I dont know how to put music on it
Go to www.sandisk.com and download the instructions for this model. They are about 30 plus pages. Look on p.11. Good luck!
Sep 09, 2007 | SanDisk SDMX1 MP3 Player
SanDisk sdmx1
Try formating it. got to my computer, right click on the sandisk and pick format. Let me know if it helped. D.
Apr 02, 2007 | SanDisk SDMX1 MP3 Player
Sandisk MP3 player SDMX1 - bad headphone connector
I have the same trouble. I ended up taking the 3 screws out, then I used a flat screwdriver to pry open the end pieces. Note from the top that there is a line where the end pieces connect. Pry off both end pieces - then you can separate top and bottom. HOWEVER, once you get in, it will be apparent that this is not very hacker friendly in there. There is a daughter-board with the microphone and headphone adapter and its epoxied in there. If anyone is successful in determining how to fix the headphone jack, please add!!!
Dec 26, 2006 | SanDisk SDMX1 MP3 Player
Opening Case for Repair, Defective Head Phone Port
I had the same problem with my SanDisk SDMX1 player. After you remove the battery you can slide down the two plastic endcaps of the MP3 player shell (one end has the headphones and microphone and the other end has the usb input). After you slide both of them off the player can be pulled apart into the two peices of the outer shell and the internal "guts." The spot to resolder was hard to get to with a conventional soldering iron. Since I didn't have one I just heated up a paper clip tip on the stove to red hot and pressed it to the area that needed soldering and rubbed on the solder. My MP3 player now works fine (I was amazed it worked) If you need more detail please ask.
Nov 17, 2006 | SanDisk SDMX1 MP3 Player
SanDisk SDMX1 MP3 Player Logo
120 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
