Question about Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas
MY Teledyne Laars is 20 year old +
Cleaned filters, cleaned gas offices(mechanically), used blown air, took out filters and ran without them to increase water flow, pilot light is running fine...water is circulating fast...yet does not fire. What gives? Before I used to tap, w/ plastic mallet, the Aluminum alloy(?) control box and then it would fire up. Is there a valve in there that might be a bit sticky??
    Top Expert:
  • Teledyne Laars Master
  • 9,712 Answers
Check pressure switch (looks like space shuttle copper wire one side 2 wires other side) need 24 volts ac both sides if not need new
Posted on Jan 14, 2016
  • 718 Answers
SOURCE: Where can I download an instruction manual for
You can download some information from;
http://www.manatron.net/Pdf's/JANDY%20MANUALS/heaters.pdf
This will give a parts list, applications and diagram.
Posted on Mar 27, 2009
  • 139 Answers
SOURCE: starting a teledyne laars heater
check for proper millivolt reading( 400-600).it could be 20 different problems and/or components
Posted on Jun 21, 2009
  • 279 Answers
SOURCE: Burner cycles on and off within 2-5 seconds.
Sounds like the flame sensor. If the sensor doesn't see a flame, it shuts off. Good luck...Lee
Posted on Nov 06, 2009
  • 3 Answers
SOURCE: Teledyne Laars LD250 Propane Pool heater cycles on and back off
Do you replace the thermopile or check the milivolts?
Check the Pressure gas
You need replace all of them terminals and check again the milivolts at the gas valve
Posted on May 29, 2010
  • 33 Answers
SOURCE: my heaters pilot wont stay on and ive replaced the
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Posted on Jun 05, 2010
Motor fires up fine runs slightly rough for about 10 seconds then smooths out for about 5 seconds and cuts off. Will start right back up after about 5 seconds and does the same thing. I have drained the...
Previous owner had way overfilled crankcase oil. Oil had gotten into carb and clogged air filter. Drained oil to correct level. Ran engine but kept cutting off-see above. Took off carb cover cleaned housing and ran without air filter-ran fine. Unsuccessfully tried to clean air filter with gas-did not work. Apparently, the engine could run just long enough to exhaust the air in the old filter and cut off which is why it would start back up after a few seconds. Bought new air filter-whole thing-about $15 at Carquest. Put in some carb cleaner and installed the new filter and it runs perfectly.
Jun 10, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
I have a Teledyne Laars XE and it came with the house I just moved into. It's at least 15 years old and whenever I try to heat up my spa (it's natural gas), it won't get above 80 degrees,
It sounds like its either the temperature sensor (thermistor) or the control board. If you remove the control panel you will see two gray wires that plug in the back next to each other.
unplug the wires and use a multimeter to check the resistance (ohms).
At 80 degrees the reading should be about 9 thousand ohms (9K ohms); at 75, 10.5K ohms; at 70, about 12K ohms. Otherwise the thermistor needs replacing. About $70 Not too hard to DIY but you will have to take some panels off to get to it
If your readings were pretty close, it is probably the control board having trouble, but be warned they are not cheap, about $350. Tell you pool store what you are doing and some will loan you a good board to plug in just to verify whether or not that was the problem.
Who ever you buy from, make sure they have a return policy. Some companies will not accept return on heater parts that have been removed from the original packaging.
Mar 21, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a Teledyne Laars spa heater XE Electronic, ES 125 ; Question, The spa and heater was drained and cleaned about two years ago, I want to get running again, But before I fill the 500 gallon spa , Is...
Locate the pressure switch within the safety circuit and jump the two wires that are connected to it. Be sure the power is off when doing so. Then you can power up the unit and it should fire assuming all the remaining safety circuit switches are closed. DO NOT RUN this for more than a few moments as you can damage the heat exchanger rather quickly operating the burners without water flowing thru the heater.
John
Nov 09, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Ignites then goes out after 10-20 seconds
Miles
May 16, 2010 | Teledyne Laars Laars Lite2 Heater 400000...
Laars Teledyne Pool heater flames on for 2 seconds, shuts off
You have no flame rectification.....LLD series heaters check for a signal through the flame to ground; if the module does not detect this signal, it go through two more trials for ignition and then lock out the module. There should be a flame rod and it may need cleaning. I use steel wool.
May 30, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
pull out flame sensor and clean with sand paper or emmoring cloth then try again should work (small black wire with sensor sitting above burners)
May 05, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas  Logo
164 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
