How do I setup my wireless repeater
I have a wireless router/modem from AT&T Uverse. The signal is weak in the back yeard so I want to setup a repeater in the back of the house to extend te wirless network. The repeater itself is an Airlink wireless router/repeater/bridge.
I've followed the instructions, but can't get the repeater to work. When I tae my laptop to the backyard, I get no signal eventhough I'm 3 feet from the repeater.
  • Anonymous Dec 25, 2008
    I have an Airlink wireless repeater. When I set it up with my ATT wireless router it connects to the router, and computers see the local network, but it does not seem to pass through internet traffic.
SOURCE: PLAYSTATION 3 WIRELESS NETWORK
You may need to add the PS3 MAC address to the router's list of allowable MAC addresses:
1. Locate the PS3 MAC address number: Settings - System Settings - System Information
2. Open the software controlling the router. This is usually done by typing the router's IP address on your browser. ie http://192.168.0.1
3. Locate a tab for FILTERS or similar
4. Slelect MAC filters.
5. Enter the PS3 MAC address from previous step as an allowable MAC address.
6. Save entry. At this point rounter will reset itself.
7. Go back and set up the wireless connection on PS3. Select all settings automatic or EASY as the case maybe.
Posted on Dec 02, 2007
SOURCE: 2wire modem not broadcasting wireless signal
Hey I was given a high speed Bell Sympatico interent system and I even had 7 different modems installed in one year and even including 2 new 2wire modems..
Firstly all of the problems were firstly related to the fact there was no Bell high speed cable actually in my area, even though i had paid for a high speed interent service for years too.
and the problmes were next directly also to the mostly pretentious, incompetent Bell technicians.
Do first use an interent speed test site to verify your actual supplied interent speeds and do always tell the ISP that you want real high speeds and real service from them rightfully ..
FINALLY THEY BELL SYMPATICO WOULD CORRECT THEIR SYSTEM PROBLEMS , AND FINALLY GAVE ME EVEN A FIBER OPTIC CABLE CONNECTION TOO, AND IT WOULD RUN GOOD FOR 3 WEEKS next till another fool, a Bell technican make some other LINE changes and my system became slow, problemed,
THUS SO MANY TIMES now I had discovered firsthand what the right hand of BELL,ca giveth the left hand can take away.. for it seems everytime they the techs do make new line changes my own ISP address next would change AS A RESULT too and lead to some of the new problems...
So I again called Bell tech and they next tend to do a ping and do something else and so for another short period their interent system would work till... the other hand had taken it away..
Continue to give them the techs hell for they deserve it and tend not to tell the truth as to what the real problems are.
If you have a 2 wire modem you do not need firewall software too and you can turn it off.
Posted on Dec 30, 2007
SOURCE: how to use second access point as repeater
pls i also need solution to this problem, kindly send to my email akinomatics@yahoo.com
thanks
Posted on May 28, 2008
Benimur
  • 6966 Answers
SOURCE: Wireless repeater
Might it be that your problem exist because both the 2Wire HW1700 wireless modem and the D-Link DWL-G710 have their DHCP features enabled? During the setup, use static IP adds, disable the DHCP function of the HW1700, follow setup instruction/procedures of the DWL-G710.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 19, 2008
SOURCE: My laptop can't find the SSID
HI all, A couple months have passed since I posted this problem. I found my own answer after weeks of asking for help. The hawking Reg 1 repeater. Here's the answer. THE REG1 REPEATER ONLY WORKS WORKS WITH ROUTERS THAT OPERATE IN WDS MODE. Not all routers can. Check to seeif the router you are extending is capable of this mode. I tried 2 differnet routers, neither worked. Finally when I got one that spoke WDS. It worked like a dream. Why did the directions not say that!!!!!
Kayellynn
Posted on Oct 03, 2008
Dynex tv won't give me the option to connect to a wireless network. It defaults to wired
This would normally indicate either a compatibility problem, the wireless network is not broadcasting, or you do not have enough signal to see the network. First thing I would try is most devices that can connect to WiFi have the option of connecting to a network that is not listed. I would try that. If that still does not work I would then try disabling all wireless security on the router just to see if that will work(I do not recommend leaving the security disabled any longer than it takes to test this). If none of that works then the next thing would be to check the signal. If you have a laptop, tablet, or cell phone that is connected to your wireless network then bring it over to the tv. If you loose signal, or have low signal then you will need to find a way to get more signal. Even if you do not see low signal on other devices the tv can still have too low signal partly because the antennas are usually in the back where the signal would be blocked by the tv as well as any other equipment you may have around the tv. Try to make sure that there are no metal objects between the tv and the router, and if possible try to get the router as close to directly behind the tv as possible. The more walls the wireless signal has to go through the weaker the signal will be, and metal can reflect the signal, completely blocking it, as well as causing noise on anything near the metal.
Apr 13, 2014 | Gateway At&t 2701hgv-b 2wire Hi Speed...
Cant get wifi unless I am a couple of inches from router. All other wifi devices work perfectly. I even downloaded the latest driver directly from Intel and problem still exists.
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home.
Mar 01, 2013 | Samsung 19628 NP300V5A-A0AUS NP300V5AI
Need to connect my nvg510 brodband
Does your bluray player have an internal wireless system, or does it require an add-on? Need to know model of bluray player
Jan 05, 2013 | Arris Nvg510 At&t Uverse High Speed...
Netgear dgn1000 modem router keeps dropping out
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Apr 29, 2012 | NetGear Computers & Internet
Can't get tv to connect to new wireless modem, but everything else did connect
What is the model no of your 2wire wireless modem not all 2wire wireless modem can support cable tv might as well contact you cable service provider
just feel free to add comment if you have furthur queries:
can also call: AT&T ' Uverse
Call +1 800.288.2020
if your under the uverse service of AT&T
or try going to this site for more 2wire infomation
http://support.2wire.com/
Aug 12, 2011 | 2wire (2701HG-B) Wireless Router
Have 2 computers connected to Netgear WGT624NA router via ethernet connectors and have operated well for over a year. Now have gotten DSL and have run phone line to modem and via ethernet cable have...
Have you tried to reset router. It has to be done in order.
1. unplug router
2. unplug modem
3. shut down computer and restart after waiting 1 min
4. after restarting computer plug power back into modem and wait for all the lights to start blinking
5. after the modem is working plug power back to router and plug in the computer with ethernet cable and make sure you have internet,
6. try to link up with wireless,
If this does not work you will have to setup the router for wireless if it is att wireless you will have to call them to give you the password to set it up.
Jan 10, 2011 | NetGear WGT624 Wireless Router
The ploblem is In need the solution of wire less network to build in the big house.
I presume you need Internet access in this house using a wireless network.
The best place to locate the wireless router is in a spot centrally located where the radio signals can reach the rooms where the computers are located. The DSL or cable modem/connection would also need to be in this area so it can connect to the wireless router.
If the wireless router is in a multi-storey house and the floor slab and walls are concrete and/or brick, then the radio signals will be impeded and the signal strength to some rooms will be weak.
In such circumstances, it maybe better to install network cables from these rooms to the wireless router, or install wireless access point repeaters to increase wireless coverage.
If you are not sure how to setup and install this network, then I suggest you get help from a computer savy friend or from your computer friendly shop.
Nov 04, 2009 | Adapters.com Computers & Internet
I bought the wireless WRT160n and i get a wireless signal
Try the following steps :
1. Connectthe cable from your modem into the Internet port of the Linksys router.
2. Reset the router with the reset button for 30 seconds when the router is ON.
3. Turn the router and the modem OFF.
4. Turn the Modem On first, wait for 10 seconds and than the router.
5. Your Internet should work from the computers connectedto the router.
6. If not open the setup page of the router by typing 192.168.1.1 in and browser, the default password is admin.
7. In the setup page, below setup tab, the 3rd subtab is MAC Address Clone, Click on that and click Enable and click Clone the MAC Address.
8. repeat Steps 3 and 4.
Hope tht helps Nikki !
For more info on linksys devices, you can try these links :
http://linksysfirmwares.googlepages.com/configurations
http://linksysfirmwares.googlepages.com/wirelesssecurity
Feb 03, 2009 | Linksys WRT160N Wireless Router
How to install wireless
First, do you have a wireless router? I am assuming the AT & T service is DSL (am I incorrect?).
For a wireless network, you need a cable or DSL modem, then that is hooked to a wireless router that transmits the signal. The laptop is then set up to connect to the wireless network that you have created.
When you buy a wireless router, there is normally a setup disk that will help you do all of this.
Just give a shout if you need more help.
Jan 23, 2009 | Acer Aspire One PC Notebook
Computers & Internet Logo
1,317 people viewed this question
David Payne
David Payne
