Question about LG Vu CU920 Cellular Phone
Importing music... I have a lg vu phone and I can't import my music from the computer onto a microSD card. I also have a new Mac computer. Is the phone not compatible with my computer. And if so is there anything I can install in order to get my music files on =to my phone????Thanx...
Now a days you are getting latest Mp3 players with Micro SD card fecility. Buy them and copy the mp3 songs from computer to Micro SD and shift that from mp3 player to your lg phone. This works fine.
Posted on Dec 18, 2008
Music aint on my phone
Save the music onto the computer from the SD Card. Format the SD Card, It should give you this option in the phone and on the computer in my computer. Redownload the songs to the SD Card and try to reinsert the card. See what happens...
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_156682b88afabb53
Dec 07, 2009 | LG Vu CU920 Cellular Phone
How do we add music to the LG xenon, i hooked up the USB cord into the comptuer and stuff, but it wont let me add the music, soo how do we do that ? i dont want to go buy a memory card cause i jsut go the...
[Extra Hardwares Needed] 1. MicroSD card 2. "Micro-B" USB data cable
[Procedure - either PC or Mac] 1. Disconnect USB cable (if you connected already) 2. In Xenon phone Settings -> More -> Connection -> USB Connection -> (select) Mass Storage Note: If you don't do this, you will get an error message "Unable to use liscense. TRy again after formatting memory card." 3. Insert MicroSD card into Xenon phone slot 4. Connect Xenon phone to PC (or Mac) using USB cable 5. If MicroSD is not accessible as a disk drive, then (1) remove the MicroSD from Xenon (2) format the MicroSD from PC (3) retry step# 3 & 4 6. You can drag & drop your folders and/or files (.mp3 or .m4a only) into the MicroSD card 7. Disconnect Xenon phone from PC then go to "AT&T Music" -> "Music Player" Note: All features work except for "Playlists" 8. If you want "Playlists", you need to use Windows Media Player and sync. iTunes doesn't work since it doesn't allow other devices than iPod. This means that you cannot use Mac to create/sync the playlist.
Sep 20, 2009 | LG Xenon GR500 Cell Phone
Can not put files on to microSD for my vu
try formatting it as fat16 or just fat depending on your windows version, not ntfs, from My Computer right click it then pick format and choose your options, if this says unable to format, be sure then SD adapter you are using to plug it into the pc is not in locked mode
Jun 22, 2009 | LG Vu CU920 Cellular Phone
I am adding music on SD card, by a Mac, but when put card into ph, it does not transfer to "My Music", it transfer to audio/ringtones
make sure you read the manual about your phone to see which music file format does it support(MP3, WMA etc).
May 31, 2009 | LG Vu CU920 Cellular Phone
Phone shuts off
if you droped the Vu than you could have damaged the insides and that might cause the repeating of it shuting off but a easyer way to get music onto your Vu is to get a Micro SD and get an adaptor for it and put music on that and then plug the SD into your phone its alot easyer and faster than useing the cord
hope this helps
May 27, 2009 | LG Vu CU920 Cellular Phone
Lg vu
It's quite simple. First search for a microSD slot, the logo on it should look similar to:
http://www.maxedigital.com/ekmps/shops/maxedigital/images/logo_microsd.gif
After you locate it, open it to see if it currently has one in it. If it does, great! Buy an adapter for your computer to read MicroSD and just put the music files under that card under the "MUSIC" folder.
If not, then you have three options:
1. Purchase a card. This is by far the best method and I highly suggest this. It's a MicroSD card, get at least 1gb stick and you'll be fine for a while.
2. Connect it to the computer. Most LG phones come with software to transfer music onto your cellphone. You may need to purchase a connection cable though, talk to your local cellphone company's store about it.
3. Send the music as an MMS! This is the least perfered method, but it works for small files. Upload your music as an attachment in your email. Depending on which carrier you have, the address may be different, but (assuming you're using AT&T) your addres will be:
number@txt.att.net
Example:
The number 123-123-1234 would be:
1231231234@txt.att.net
May 21, 2009 | LG Vu CU920 Cellular Phone
Can you use music on a memory card as a ringtone on an LG Vu?
Yes you can. Make sure the MicroSD is no larger than 4GB though.
May 20, 2009 | LG Vu CU920 Cellular Phone
At&t lg vu music sync
does those file open in any other player. reinstall the higher version of it
May 08, 2009 | LG Vu CU920 Cellular Phone
Memory Card Error
you need to put what ever is on you card onto you computer then reformate you cardthrough your phone .the card is setup for your old phone
Apr 16, 2009 | LG Vu CU920 Cellular Phone
Importing Music.
I had a similar problem. I did not get a USB cord with my phone. I found that if you insert the microSD card into your computer a folder opens that says Secure Digital Storage Device (E:). I have iTunes. I don't purchase music from the store (which is an option) but I download my cds to the program. If you highlight a song from the iTunes and then right click and select copy then open up the tab for the Secure Digital Storage Device (E:) then paste the item.
Remove the card from your computer and put the smaller card into your phone. Hit the menu button. Then hit the folder button located on the right side of the screen. Then select the more button. Then select the memory card. This will allow you to access the item you have on the card.
If you wish to download the item to the phone memory (meaning you can remove the card and the item will remain on the phone) you select the option button and hit copy - it will then give a prompt asking if you want to copy it to the handset memory or the memory card - select the handset memory. After this is complete you will be able to remove the microSD and still be able to access the item you downloaded.
Dec 18, 2008 | LG Vu CU920 Cellular Phone
LG Vu CU920 Cellular Phone Logo
164 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
