Question about Onkyo Audio Players & Recorders
DELAY AND DISTANCE AND CELLEBRETION OF VIDEO
MAY I GOT DIAGRAM OF SETTING,DISTANCE,DELAYTIME, DESIGN SITTING FOR MY ROOM.? My room size is 16ft.1" X 18ft.3".00. Hight is 10ft. 6" .I have Onkiyo
898 A/V Receiver and thx certified LCR Speaker with 4 diopole surround &
back surround . L- C- R speaker & surround and two back surround are place as attech file herewith Ditance L-C-R 10ft .6 " & SURROUND LEFT & RIGHT ARE 8ft .6" and back left -right Back surround 6FT.6" ARE far from my iistaning -sitting . . I put SPL METTER incenter room and set at 82db in all speakers.i.e left +4 db , center +2 db, Right +4 db, right sur 0 db , back sur. left +1 db, right back sur.+1 ,& left sur +1 db Woffer JAMO D-7set near front Left at 9ft. 5" far my sitting on -1 db in ONKYO 898 AV RECEIVER.I got good sound .But WHAT & WHICH set delay AND
distance in A/V.So what do I do .Please guide to me properly for same and got
surround My room size is 178t.3' x 16ft hight is 10ft.3". SIR,IN MY ONKIYO INTERRA TXS 898 A/VR NOT IN BUILT AUTO SET UP .NOE I PURCHASE ONLY AUTO SET UP (DON'T KNWO NAME OF INSTUMENT) WHICH CAN ATTECHE WITH MY A/VR AND CAN do ALL CHANELL -speaker 7.1 or MAY I GOT DIAGRAM for my SPEAKER PLACEMENT FOR SAID roomsize & AVR ?
which color petten for R G B to V G A VIDEO CONNECTION
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: no surround sound
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Posted on Jun 04, 2006
  • 17 Answers
SOURCE: Hi We are setting up our
Hi there. If you are running a 5.1 speaker system, make sure your surround speakers are on the surround terminal NOT ON THE SURROUND BACK. the surround back is only for the 7.1 speaker system.
Posted on Nov 28, 2008
Xtremeroofin
  • 67 Answers
SOURCE: Speaker set up problem
They hook to the rear surround.
Posted on Dec 20, 2008
What size tv will fit in main room
http://www.rtings.com/tv/reviews/by-size/size-to-distance-relationship
May 05, 2017 | Televison & Video
What size do l need
That depends on you really BUT
Take into account the room size, mounting wall placement size and most important the distance from where you watch to the TV. also consider where you place it when daylight comes in.
Like bedroom a 32" say, family room the farther you set from tv the larger the tv screen 42"good 60" great but only for larger rooms
hope this helps let me know how this works out for you Mike
Feb 04, 2016 | Televison & Video
We installed a mr. heather IR30LPT, set the fan to auto and the control to #1, however, the unit runs continuously without shutting off. The room is less that 1000 sq. feet. Can you tell me why the unit is...
THERMOSTAT CONTROL OPERATION
FOR IR20LPT / IR30LPT: The thermostatic control used
simply turns on and off the burner.
FOR BF20LPT / BF30LPT: The thermostatic control
used modulates the flame size as the temperature gets
closer to set point, then it turns off the burner upon
reaching temperature.
The burner will cycle back on when room temperature
drops below the set temperature. The control knob can
be set to any heat level between 1 and 5. Selecting the
HI setting will cause the burner to remain on.
Note: The thermostat sensing bulb measures the
temperature of air near the heater cabinet. This
may not always agree with room temperature
(depending on housing construction, insulation
location, room size, open air temperature, etc.).
Frequent use of your heater will let you determine
your own comfort levels.
The LED temperature indicator measures approximate
room temperature around the heater.
Note: The LED temperature indicator DOES NOToperate with or control the thermostat setting of the
heater.
IF YOUR UNIT IS NOT TURNING OFF IN POSITION 1 BUT THE TEMPERATURE AROUND IT IS HIGH THAN THERMOSTAT IS STUCK AND YOU HAVE TO CHANGE IT OR VISIT SERVICE.
1-5 knob has no info what is the parameters of temperature sorry!
Nov 27, 2017 | Heating & Cooling
What does economy button mean? When it is not on economy it goes above the desired temperature setting but when it is on economy it never reaches the desired setting. Can you help??? Do others have th
According to the owners manual, the "Economy" mode is designed to reduce the temperature setting by 2 degrees every hour. May not be what you were expecting... On the too hot issue: Check the thermostat setting - it can read either Celsius or Farenheit - Make sure you are setting it to what you think you are... Recommendation: if it is heating higher than set temperature is 1) set the temp lower and see how it does or 2) call a repair man to check and calibrate the thermostat.
Jan 15, 2015 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
How to unlock your room?
When you are in the room you want to lock, click on "Room design" on the right side of the Suite. There you can choose to lock the room for visitors. Unlocking the room works the same way.
Jul 07, 2014 | Video Game Consoles & Games
What is the best speaker volume settings for 5.1 system my receiver is Yamaha rx-v430 and room size is 15x20
As this receiver does not have automatic speaker calibration, you need to set the volumes manually. The best is if the left and right speakers are at the same distance from you (then their volumes can be equal). If one speaker is at more distance than the other, the volume must be higher for this speaker.
You can find instruction for volume setting at p. 21 of your receiver manual. There you can also find settings of the speaker mode - that depends on the specific speakers you have. You can define for each of 5 speakers if they are Large/Small/None (on this setting depends where will be the lowest bass tones directed).
Oct 20, 2013 | Yamaha RX-V430 Receiver
What is the best locxation for 901 series v1
Optimal placement of these like speakers of any design will vary depending on room dimensions and your listening distance from them.
A good place to start with them would be the same distance apart from each speaker as they are from the listening position. In that position they should also be placed closer to a rear wall than any side wall, approximately half that distance.
Dec 10, 2010 | Bose 901 VI Main / Stereo Speaker
Long delay between singing into mic and hearing voice in speakers
Usually delay is associated with "reverb" not echo. If you are in a large room, the room acoustics can add reverb without the benefit of signal processing.
Reverb NORMALLY passes the inout signal as is and then adds in a delayed version on top.
The delay should be less than the room size delay.
Try turning off all effects as a start. There is some "transport" time if it goes through a digital signal processing.
Apr 30, 2010 | Vocopro Da1000pro Professional Digital...
How long should it take for a ps3 to update?
This depends on your connection, your connection speed, update size, your router, and distance from the router. For instance if you have a 5mb connection with a wireless router to your ps3 in a room across the house, and a ps3 in the same room as the router, the one closer would download faster. So I would say it could be anywhere from the range of a few min to a couple of hours.
Dec 24, 2009 | Sony Playstation 3 (PS3) Console
WHAT speaker distace & delay .sitting and Db in my AVR AS MY ROOM SIZE
Hello, if you have the speaker set up microphone I suggest that you use it to calibrate the speakers and it will set the distance and delay. Thank you, Onkyo USA
Mar 02, 2017 | Onkyo TX-SR605 Receiver
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
