Question about Lexmark Z735 InkJet Printer
Is my ink cartridge refiilable??
The lexmarkz735
  • 432 Answers
Yes it is, but not adviseable. After you refill the cartridge, it's possible it won't work again if you fill it to full. If you do this, lay down a lot of newpaper, it can get very messy. Have paper towels ready. Most important, stay away from the carpet.
Posted on Dec 18, 2008
Reset ink counter ipf6300
first you must follow the step:
1. open cover ink
2. then follow the massage from the display panel
3. untill the information select displayed on the display panel
4. select oke if you want to change original ink to refiill
then on display shown the non ink chek status.
Apr 06, 2013 | Canon imagePROGRAF iPF6300 Large Format...
Scx 3200 samsung status light
If you refiil the toner cartridge ,now must be change the cartridge chip.The chip countered the total copy,not how many time you refill the toner.The original chip working 1500 copies,change one new chip to 1,5K or 3 k or moreK(K=1000 copies).
Mar 26, 2013 | Samsung CLP 300 Laser Printer
Refiilled canon PG 40 now won't work. what to do?
If it is still flashing empty cartridge, hold the stop/reset button down for about 10 seconds. this disables the ink levels because they can not be re-set. If it is going through the motions of printing but nothing is coming out then try this:
  1. Simply fill a saucer with approx 2mm of just boiled water
  2. Place the print head in the saucer with the head in the water.
  3. Leave the head in the water for approx 2 - 5 Mins
  4. The Heat will assist in dissolving any blockages and help get the ink flowing
  5. Also by using a syringe and forcing air into the top of the cartridge can help fill the lower chamber of most cartridges, this can overcome the Air-Lock issue some refilled cartridges have.
I hope this helps, if so please rate this response below Thank you for supporting the FixYa Community Regards GM
Apr 15, 2011 | Office Equipment & Supplies
Replace cartridge error
i have brohter dcp7030 laser printer .earlier toner is empty si i refiiled the toner but toner giving me not printout.printer is display the message of toner end so plase me suggest the reset of this ptinter
Oct 28, 2010 | Brother DCP-7030 Digital All-in-One Laser...
How reset cartridges for Lexmark Impact S305 ?(refiils)
I just did it...somehow. I refilled the red and a test page printed yellow instead...no red. Kept telling me 'very low', etc. I used the maintenance button (wrench) and tried a number of things. First I said OK to reset to factory defaults. Then I said OK to clean printhead. Maybe some other stuff. I tried to print and it said the warranty would be void. Then that it would no longer be able to tell me the amount of ink available and assorted other ****. But a test page printed the colors again. I haven't turned it off and tried again, Im afraid to. But apparently it can be done. I just wish I had written down exactly what I did and the order. But it was all thru 'the wrench'. Good luck!
Sep 30, 2010 | Office Equipment & Supplies
Unsupported cartrige lexmarkz735
Hi there
You have been lucky if you have been using re-cycled cartridges, most times they not work with Lexmarks or Brother Printers.
You must have been Lucky to get some good ones.
All the best Pineworks
Apr 26, 2010 | Lexmark X7350 All-In-One InkJet Printer
I refiiled my black ink cartridge at Walgreens and now the printer thinks my black is empty and will not print.
Normaly when you refill a cartridge the level is not reset & is normal.
I assume if you read your instructions you should be able to press a button on your printer for 5 seconds & it should override the software.
Also on some lexmark printers you can tell the printer software you have installed a new cartridge.
Another common problem is when a cartridge is refilled if the correct type of head seal is not used the cartridge head clogs or dries up, to rectify that get a piece of tissue paper, wet it and place the printhead on it, just dab it, after a few dabs you should see a nice block of ink the same size of the printhead, if you do replace back into printer & it will work.
if you don't get a good band after a dozen goes the printhead is either blocked or when they refilled it they did'nt do it correctly.
Nov 08, 2009 | Lexmark X2600 InkJet Printer
Paper in correct turned printer on red light flashing and will not print paper is blank when it comes out.
Red light flashing, do printing, paper blank out : ink low message. Ink level low, near to ink out level. But it just program, may be ink tank is out actually (no ink at ink tank). Refiil ink tank or replace w new one. Check Nozzle.
Jun 11, 2009 | Epson Stylus C46 InkJet Printer
I dont know how to take my ink cartridge out so i can put the refiil ink cartridge in.... i dont want to brake it... lol... help me
try to shut it off..and then force the carrier or the cartridge holder onto the middle by pulling it...
May 17, 2009 | HP DeskJet 6540 InkJet Printer
Lexmark Z735 InkJet Printer Logo
53 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
