Compaq Presario V2000 Widescreen
I have a Compaq Presario V 2000 laptop. After three year insured warranty (: I get black screen.Today, I was at the Best Buy where I bought the computer and they told me I have to change to whole screen which very expensive aprox. $600. So, much better if I hook up an external monitor. I hooked up an external monitor and works fine. However, I am traveling a lot and I can not carry always an external screen and a laptop with me. Where can a buy a cheap whole widescreen for my laptop and how can I change it? For any reply thank you.
Bogdan
  • 198 Answers
SOURCE: Compaq Persario V2000 Black (very dark) Display
Hello Bigkahn, The problem you have is related to the power inverts that powers on a small fluorescent light on the bottom of the actual LCD pannel. The "display" is composed of mainly 2 parts. One is the TFT active matrix that is build up by using many transistors. There are 3 of them for each pixel, each transistor displaying one basic color (RGB code red-green-blue) and 3 of them, like i said, forming a single pixel. They don't produce light by themselves they only filter the light that pass through the TFT pannel. So if a transistor displays "green" it will do that by filtering the light that comes from the fluorescent lamp i was talking before. It produces white light so therefore the transistor pannel will filter the coresponding wave lenght to block anything else than "green". (white light is a combination of all spectrum lenghts) Therefore in your case, if you light up the display using an external light, you may see something on it because the pannel will try to filter the light you give to it. This shows that the actual transistor matrix is working. Your problem is like i said, related with the power inverter. It'a small device inside your laptop that will raise the tension given by the batteries to about 2-3000volts needed to fire up the fluorescent light (some kind of "neon"). If it doesn't work that light woun't come on and the display woun't light up therefore the transistors on the pannel woun't have anything to filter and display on the screen. This problem can happen because of either a faulty connection between the inverter and the fluorescent lamp, or the inverter to the mainboard. Another cause can be the hardware failure of the actual inverter that is preventing it to raise the tension to the specified values. Either of these will require you to have your laptop checked at a service center because we are talking about tensions ranging 2-3000Volts and sensible component. This shouldn't be an expensive repair because the actual pannel (the screen) is working fine and all that needs to be done is to check the inverter or replace some components relating to it. If you have further questions please feel free to reply to this. Good luck.
Posted on Apr 04, 2007
  • 263 Answers
SOURCE: presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Posted on Jan 05, 2008
ceezer
  • 20 Answers
SOURCE: how to connect my compaq presario V6000 to my dell monitor.
try hitting Function (FN key next to the control) and F7 at the same time on the laptop. Also, is the dell monitor's input set to VGA (some have multiple inputs like DVI, VGA, HDMI, etc)
Posted on Jul 08, 2008
Geekman
  • 32281 Answers
SOURCE: FLOATING BOX WITH ATTENTION INPUT NOT SUPPORTED
Your monitor has several different video inputs.
Go to the configuration settings on your monitor and select the video input that matches the video cable from your computer.
Posted on Nov 13, 2008
lorenzo_most
  • 60 Answers
SOURCE: Hard drive replacement
Hi there, I have an HP nx6110 and it had a WD 60GB 4200 rpm IDE, I bought a Seagate 80GB IDE Hdd and it worked fine. The only think you should be careful is to check if you need a SATA Hdd or IDE Hdd, but I think it's a SATA.
Posted on Apr 02, 2009
HP Compaq Presario V3000 PC Notebook - Screen Blank, Won't Boot
try to put the windows installer, and re-install again your OS.. format the drive and install a fresh copy of windoes..
Jul 02, 2008 | HP Compaq Presario V2000 Notebook
No screen on starting laptop
remove the battery from bottom, plug into ac power pack, and try it that way
Jun 01, 2008 | HP Compaq Presario V2000 Notebook
My Compaq Presario v2000 laptop does not power up after pressing the power on switch. It all started whenever I hibernated it. But it worked after several attempts. Now it has become dead. Can you help?...
Generally this type of problem arises due to Battey. But in u r case it appears like a Mother Board Problem.So u better to visit nearer HP/compaq Service Station u can extende warranty for another year if ur previous extended warranty expired within 6 months...there is a provision in HP Customer Support.
Apart from this You can buy third party Mother boards compatible for V 2000 in other Laptop Acessories store
Jul 08, 2009 | HP Compaq Presario V2000 Notebook
Turn on goes to black screen
Can you access F10 bios - if you can access bios you have a hard disc failure - remove you hard drive - boot the system without the hdd and see if the pixie boot boot goes through - seen it before - your hdd is unservicable.
May 16, 2009 | Computers & Internet
Compaq Presario V2000 laptop wont boot
hi it seems that ur mother board has been damaged.. and immediately u should go for replacement....
thank u!!!
Apr 09, 2009 | HP Compaq Presario V2000 Notebook
I have a laptop hp compaq presario v2000
Firstly you need to check if your laptop is bluetooth enable, if yes then you can activate it from control panal.
Jun 20, 2008 | HP Compaq Presario V2000 Notebook
Ma lap top fell down
sorry ok. what i will suggest iis yu replace your screen and zap yr done.
thank u
May 25, 2008 | HP Compaq Presario V2000 Notebook
Monitor
if you are under warranty, please return it to the company.from my knowledge it should be the loss of pixels.
Dec 23, 2007 | HP Compaq Presario V2000 Notebook
AC charger for a presario v2000
use ebay, same thing but cheaper in prices... i got my presario v2000 ac power charger for 24.50 with shipping and handling.... took 3 days and it arrived unless u want to do overnight shipping which is like an extra 12 bucks which is good too... WELL WORTH IT EBAY IS THE PLACE... i think his name is "honestworks" or something like that buy it from him he has a one year warranty if any defects occur...
Oct 18, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
80 people viewed this question
Alun Cox
David Payne
David Payne
