Question about Akai LCT2060 Television
My akai lct 2060 lcd fell 8 inches to the floor, no power up now
I cant get tv to power up, so I took the lcd screen apart and noticed the 2 inch wide ribbon connecting the lcd screen and the mother board behind the screen had come apart. I cant get my fingers far enough in to reconnect the ribbon. Do they make a tool that will reach that far or do I need sto take it to a tv tech. Thanks , Bill
  • bcrossinspec Dec 18, 2008
    If I take the tv apart can I get closer to the ribbon connection
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, would suggest:
  • take it apart (if comfortable doing so), almost always, these flat cables have to be hooked up correctly otherwise, not all the wires would be making contacts, or folds/kinks would be introduced to the cable making things harder;
  • Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 18, 2008
    Novelist:
  • 152 Answers
You may want to let the techs handle it if you think you cant remove other boards or parts to reach the ribbon to attach it securely. since you got that far allready
and you get the ribbon back into the connector you need to snap the plastic clip till it locks in place
then check and see if it powers up
if no power then you will need a tech..
  • charlie rodriguez
    charlie rodriguez Dec 18, 2008
    to open the clip you lift upwards from the outside of the clip connecter towards the cable to close you snap it back down
  • 275 Answers
If you have never done something like this, and are not confortable doing it, not sure what the outcome would be if you do it yoursef, I would defenetly recomend that you rather take it to a Tv repair man. Fixing shoudl be simple and non-expensive, also would save you from blowing up your Tv!! Good luck..
    President:
  • 1,314 Answers
Yes if you take it apart further, you should be able to get to a point where you can reconnect the ribbon cable.
    Genius:
  • 1,269 Answers
Taking it to a TV tech is the most convenient way to avoid fatal damage to your tv.
AKAI LCT 2060 was working well as a TV. Just hooked it up to my PC and the message on screen reads "No Signal" Checked monitor cable and it's good. checked old monitor and it works well. Why...
The display settings on your computer need to be turned down. Set it to 800x600 and move up from there, if the resolution is too high - the TV won't display it.
Feb 28, 2011 | Akai LCT2060 Television
Akai LCT 2060 TV will not turn on. Power unit shows blinking green light, but no picture.
Click HERE to download service manual copy as it was promised in chat session.
Thanks.
Jan 07, 2011 | Akai LCT2060 Television
I have a AKAI LCT 2060 TV, cannot see picture, only sound
This problems,i fix alot models of tvs all diffrent models of tvs but have the same board alway dies.The LCD inverter board is dead.This board help the LCD to have a backlight to go through the Turner board to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.The board is long in shape.It the easiest board to replaced in LCD tvs.
May 07, 2010 | Akai LCT2060 Television
I have an akai 50 inch tv. I have a darker area on the left side of the screen about 3 inches wide. I replaced the bulb but the problem is still there. Any idea how to fix it. Its a projection tv.
Convergence is dead.Replaced the 2 convergence ICS,should solved this problems.Try website Tv repair World.com to buy a Whole convergence board to replaced.Samsung/Akai use the same convergence board.
Feb 26, 2010 | Akai PT4298HD Rear Projection Television
Akai LCT 328STA,Comes on Akai screen appears then goes off.
Akai LCT 3285TA (notice the "FIVE") uses the MLT169A Power supply. This is available from shopjimmy.com for about $100.
Jul 22, 2009 | Akai LCT3201AD 32 in. LCD Television
Akai lct2060 fell 8 inches to floor,wont power on
the ribbon can be replaced but be careful and use gloves to avoid contaminating the componite with the oils from your hands
Dec 18, 2008 | Akai LCT2060 Television
Darker fatter letters every 2 inches apart from top to bottom
it is called phase you can attempt to let the lcd monitor auto set or you can disconnect the power over night then plug in and then do not auto set this default usually seems best some times
Nov 29, 2008 | Proview PL926WBi 19" LCD Monitor
Wall mount Akai LCT 3285TA flat panel TV
You have to get correct wall mount for this model tv.
Sep 28, 2008 | Akai LCT3285TA 32 in. LCD Television
NEED AN OWNERS MANUAL FOR AKAI LCT2060 My Tv.not have power
hola nesecito el modelo del boar el tv es akai lct 2060
Jun 07, 2008 | Akai LCT2060 Television
Akai LCT2060 Television Logo
21 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
