Question about Creda W100FW Front Load Washer
Where is filter
Last tennant left behind a creda 800 superspin washing machine. jumps about when spinning. want to check filter to empty if needed but cant find it please help.
  • moconnor87 Dec 21, 2008
    thankyou so much for your help, havent tried it yet but know now where its at. thanks again, HAVE A GREAT CHRISTMAS.......
  • Creda Master
  • 3,463 Answers
Filter is located in the large black hose attached to bottom of drum, remove hose and clean filter.
Access is by removing lower rear panel of washer.
Plz leave feed back for this solution.Thabnks.
Posted on Dec 18, 2008
My creda ww100fw washing machine will not rinse spin or empty.I think it may need filter emptying but it was only cleared by washing machine engineer 3-4 months ago!which cost £40.00so would like to know...
if not at front then at the back, usually has a plastic cover that has to be removed with filter attached. it may be that ur pump propeller is blocked or broken? However I would also check the motor coupler or belt depending on direct drive or belt drive, also check clutch and the door switch , check with multi meter for continuity. any of these can stop it from spinning and thus no draining?
Mar 09, 2015 | Creda Washing Machines
My creda simplicty washing machine W200FW) is not finishing programs - it spins and fills but doesn't end - on a rinse cycle it just keeps spinning with water in, on a spin cycle it will drain but on
This is sometimes caused by water not exiting during or at the end of the wash. I have also encountered door lock issue for the same reason.
Jan 21, 2015 | Creda Washing Machines
Why does my creda washing machine stops when it gets to a rinse
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the next cycle with excess water in the drum.
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom)
Jul 05, 2011 | Washing Machines
Creda Simplicity 1000 (w100fw) - Drum does not rotate
you could try fitting new motor brush kit it wears down after 4/5 years and need replaced....please leave feedback
Apr 08, 2010 | Creda W100FW Front Load Washer
My washer does not empty
i had the same prob when i had a new kitchen fitted. . all i did was put the pipe that goes to the sink part in the shape of a n , that will solve it.......
Jun 17, 2009 | Creda W100FW Front Load Washer
Where is the filter
The filter is located at the rear`of the washer.
To access it, remove the rear lower panel.
You will see a large black hose, remove hose from bottom of tub, and you will find the plastic filter inside, remove filter and clean.
Refit filter and hose, and test.
If it still does not spin, then you need to check the brushes.
If you require info on how to check and change them, then let me know.
Please rate my fixya solution.
Thanks.
THanks.
Feb 10, 2009 | Creda W100FW Front Load Washer
Creda Washing Machine Detergent Dispenser not emptying
does the detergent get wet?
may be the blue trap door that is behind the detergent in the drawer is set for liquid detergent ie 'closed' and needs to be set to open to allow the powder past. or the holes above the detergent section where the waster comes out are blocked so water goes in another route.
you could always put the powder straight in with the wash to get yourself out of trouble.
Feb 03, 2009 | Washing Machines
Dial keeps turning and clicking
sue worth having inlet valve checked also have heater checked at same time ! is the machine draining ok !! if not there could be blockage in drain system or faulty pump good luck- regards bob btw
Feb 26, 2008 | Creda IWD12 Front Load Washer / Dryer
Not Pumping out water
Possible your outlet filter is blocked. After disconnecting electrical input from wall socket, remove the back panel of washer to see if the pipe from the tub is blocked, clear, also check the outlet filter, clean. If u have the users' manual check how to clean your outlet filter
Nov 14, 2006 | Creda W120VW Front Load Washer
Creda W100FW Front Load Washer Logo
140 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
