Question about Hisonic HS596B VHF Stage quality Wireless Microphone w/ 2 handheld & 2 lapel Microphone, 4 Transmit... Microphone
Mic troubles mic cuts in and out seams to be mostly in the morning but sometimes in the evening. It's not the battery or cable connection, checked both and replaced the battery anyway.
  • 113 Answers
Check antena connections first
Posted on Aug 08, 2007
I have a 95 Dodge stratus..2.4 L. The past week it was having trouble starting. After turning key off then on..3..sometimes 4.. it would start right up. Next morning had to do same thing. Yesterday I took...
Yes, it has to do with the ignition switch. but just as possible could be a battery connection from the battery to the switch. So, sometimes turning key to ON causes no dash lights or warning lights to come on?
That sounds like a bad switch, or more likely, a bad battery connection or a bad connection between the battery and the switch. First thing to do is check the charge of the battery, it must register at least 12 volts. 12.6 volts is the ideal for a good and fully charged battery. Clean and tighten all battery connections.
Sometimes when you have a poor connection, from looseness to corrosion, and you turn key and see all warning lights and gauges come on, and then turn key to start and everything goes black...that can happen because the power surge causes the bad connection to come apart. So check for loose or corroded connections.
Mar 02, 2018 | Dodge Cars & Trucks
Having trouble starting in the morning
You may have a weak battery. Get it checked for free at a battery shop. Sometimes a weak battery will work and other times they won't.
Jan 19, 2016 | Cars & Trucks
Sorry, I mean, I have a sm 57 connected to a behringer ultragraph fbq1502, then to a behringer multicom proxlmdx4600 and then to a behringer xenyx 2442FX, and works very well
First try another cable. Then one more. Then take a mufti-meter and test the mic cable pins to see if you are actually getting those +15 to +48 phantom volts. On Balanced XLR connectors Pin 1 is ground/shield. Pin 2 is HOT. Pin 3 is cold. Measure pin 2 positive and Pin 1 to ground at the mic end of cable. See if you are actually are getting phantom. Balanced TRS connector is tip hot, ring cold, sleeve ground. You should always have a couple of digital multi-meters with audible conductance testing for all connections, and good batteries on hand when working with studio equipment. It saves a lot of headaches such as a bad cable. Even a brand new one could be bad! After eliminating cables...I tear the mixer apart. I know it may be too much but, when I Engineer a new studio for someone I make sure all cables are out of the way and cut and soldered to the length of each cables designation. That way they are all out of the way and they never get the chance to go bad. Also save time by setting up your studio so everything is mostly a permanent installation, that way you do not have to keep re-connecting things. Only a new piece of gear once in a while. Good luck!
rockinbadboy-
Sep 02, 2012 | Behringer Music
Our car starts right up in the morning just fine. The rest of the day in and out of car it has trouble starting. What could it be?
If battery and connections are good (it's a big draw,different then other components).Because a bad connection or old battery can sometimes work the starter after it sits,doesn't make it .Some times a starter has a bad spot,thats whe you see some one get under and directly jump it.If buying a battery get at least recommended cranking amp size battery,Larger auto stores check battery no charge (bad joke). Its free google /bing who does a free battery test.Auto zons,pep boys,sears.May even be running a sale.Most switch out battery for fee (no charge*),*Hopefully you will laugh later.
Nov 08, 2011 | 2004 Chevrolet TrailBlazer
Since last November, I noticed sluggish cranking on start. Sometimes the engine refuses to start much like a dead battery but the battery tests strong. I thought perhaps the new Interstate battery may...
Check the connections on the starter, and on the battery cables from the Honda. I know it sounds funny but I had the same problem with my BMW. It turned out there was corrosion on the the cables and it wasn't getting all the juice. Corrosion and or loose connections to the starter could be your problem...Hope this helps.
May 04, 2011 | 2003 Honda CR-V
I PUT IN NEW BATTRYS BUT NO GREEN LIGHT ON MIC . IT WAS CUTTING IN AND OUT BEFORE THIS HAPPENED. ITS LIKE THE MIC JUST DIED. CAN YOU HELP?
most likely a loose connection inside suggest,
check battery is held tight in place, if not then it might be possible to very gently bend the battery terminals just enough to help the connection.
if not battery connections then its inside the mic could be the power or the capsule wiring, need a tech or the dealer to take a look
hope this helps
thanks for using FixYa
Aug 15, 2010 | AKG HT 40 Professional Microphone
My car was running fine all day yesterday until that night. I cut it off and it wouldnt start back up. Finally i got someone to give me a jump off and it worked but the dash lights kept on dimming in and...
You, my friend have a flat battery.
However, replacing the battery will not fix the problem, the battery is just a symptom, just like having cough syrup won't fix a cold, it will ojnly make your throat feel better.
What you need to do, is replace the battery, then get a multimeter, and check the voltage of the battery when the car is running at idle (in park/neutral), it should be 13.2-14.4v. If below this, im suspecting 12.0v or below, then you will have to have your charging system (alternator) checked.
Jun 11, 2010 | 2003 Pontiac Sunfire
Shure sm58 just started outputting very low volume. It has been working fine with our system for years. Tried other sm58 mics on the same mic cable with same system setup and no troubles. There is still...
Check your wire connections inside the mic where the xlr cable connects to the mic. Hopefully your mic has never been dropped as this will damage it. The sm58 is pretty much indestructible, so check your cabling that you use, try a different channel.
Apr 04, 2010 | Shure SM58 Professional Microphone
Hisonic HS596B VHF Stage quality Wireless Microphone w/ 2 handheld & 2 lapel Microphone, 4 Transmit... Microphone Logo
167 people viewed this question
Top Hisonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Hisonic Audio Player and Recorder Expert? Answer questions, earn points and help others
