Question about Hitachi VTFX621A VCR
Hooking up hitachi vcr to dvd & directv box
As stated above,I need help in connecting an Hitachi VRC #VT-FX621A to an DVD & Directv box.
5 Suggested Answers
  • 579 Answers
SOURCE: problem with my vcr Hitachi VT-MX 848E(AU) G-code
What speed are you recording at? VCR's with more than 2 heads use different heads at different speeds. Try recording at all speeds and see it that makes a diference on playback.
Posted on Dec 31, 2007
  • 98 Answers
SOURCE: hitachi vcr fx6505
you need 2 pairs of audio/video cables
from the back of ur tv set you can see (audio out---video out)
now insert cables in your tv set.. then connect to your vcr (audio in---video in)
vice versa vcr to tv----tv to vcr
Posted on Feb 07, 2008
SOURCE: Hitachi VT-FX240E
press the operate button fo rmore than five seconds as video is in parental mode
Posted on Apr 13, 2008
  • 2712 Answers
SOURCE: Hitachi M428E VCR
You can download the manual HERE.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Posted on May 04, 2008
  • 1140 Answers
SOURCE: Hitachi VT MX705evps: after inserting
TRAC is short for TRACKING. This is rather complicated to explain and requires some understanding of how a VCR works. To put it in the simplest terms, tracking is an adjustment which corrects a misalignment between the image on the actual video tape and the playback head. The playback head basically "reads" the picture on the tape and sends it to your TV for viewing.
Many VCRs (including yours) have automatic tracking. When you insert a tape, the VCR attempts to adjust the playback head so that is in line with the image on the tape. The TRAC message will usually appear briefly when you insert any video tape to indicate that the VCR is perfoming this alignment adjustment.
In your case, the TRAC message is continuing to display because the VCR is unable to automatically correct this alignment and is therefore unable to read the tape. This is usually caused by one of two things;
1. A worn or stretched tape. Video tapes do not live for ever. After repeated recording the tape becomes worn, stretched and/or distorted. 8 hour and 6 tapes are particularly susceptible to this as the actual tape in the cassette is thinner and stretches/distorts more easily as a result. These tapes have a much shorter life expectancy than shorter 3 or 4 hour tapes.
2. The playback head is dirty and needs cleaning.
To solve this problem, you need to determine which is the cause. This is very simple to do. If the TRAC message persists when you use a brand new tape then you probably need to clean the heads. This can be done with a head cleaning cassette which you simply insert into the VCR and play for a short while:
This are widely available from many retailers, but be sure to follow the instructions carefully.
If the problem is confined to a single tape or a small number of tapes, then it's likely these tapes are worn out and have reached the end of their life. You may be able to get a limited amount of further use from them if you clean the heads as above (sometimes the problem can be a combination of a dirty head and a worn tape) but don't expect these tapes to last much longer. You would be ill-advised to use these tapes for any further recording.
In addition, if you habitually use 8 and 6 hour tapes, you should limit their use to recording things you only want to watch again a limited number of times. If you are recording things you want to keep and watch long-term, I would suggest using tapes no longer than 3 hours or 4 hour at the absolute maximum. For better quality and longer life, you should also record in short-play (SP) mode rather than long-play (LP) mode.
I hope this adequately explains the TRAC message for you. Please try a selection of other tapes - old/new and bought/self-recorded, then reply to me from within this page with the results if you need further assistance.
Posted on Feb 03, 2011
0 characters
1 Points
Need tv remote codes for a hitachi remote model#vt-rm361a
but you forgot what make of TV you see so we can not help
Apr 22, 2015 | Hitachi VT-RM361A VCR Remote Control
How do you hook a dvd player up to a hitachi vcr?
Not knowing the model VCR or TV your asking about here is the most common connections. You will need a video/audio RCA patch cable. This type cable is always included when purchasing a new audio or video appliance. If you don't have this cable they are available at your local Radio Shack, Best Buy and other electronic stores.
On you DVD player locate the three OUTPUT connectors at the back of the unit and plug one end of the color coded (yellow, white, red) patch cable into the corresponding jacks.
Plug the other end of the patch cable into the VCR INPUT jacks, once again matching the yellow, white, red, at the back of your VCR.
That's It!
To see your DVD player on the VCR be sure to select INPUT or LINE on your VCR remote. Some VCR's have an additional set of input jacks at the front of the VCR, usually labeled Front or Line 2. Use whichever one is most convenient.
Aug 29, 2009 | VCRs
Recording 3 digit channels
With the VCR connected to DirecTV, you're not picking the channel with the VCR anymore. You're picking the channel on the DirecTV receiver, and the VCR will record on channel 3 or 4 (if you've hooked the receiver up using the RF output to the VCR) or through its line (A/V) inputs if you're using those. The tuning range of the VCR is completely unimportant.
With your new system, though, there's one big drawback. Since the VCR is always set for channel 3 or 4, or its line input, and you're changing channels on the DirecTV receiver, you can't program the VCR to record several different channels if you go out. You won't be home to change channels on the receiver, so the only channel you'll be able to record is whichever one you've selected before you go out. Remember the VCR is taping the output of the satellite receiver, and not the satellite channel directly. If you record on some channel other than the receiver's output channel, there won't be anything there. All you'll get is snow or a blank screen.
Mar 31, 2009 | RCA VR706HF VHS VCR
How do I hook up a daewood vcr to a TV through a Direct TV
If you are trying to connect a VCR to your television and still have Directv, this is the way to do it. Disconnect your Directv receiver from your television, Then connect the VCR to the television either through coax or RCA cables. If using the coax cable connect the out to tv on the VCR to the television. If using RCA cables connect the RCA OUT to the television AV1 connection. Once that is done, connect tha Directv receiver to the VCR using either coax or RCA cables. the Directv receiver only has RCA outputs so, if using RCA cables connect to VCR in. Remember that in order to see the Directv the VCR needs to remain on and it must be on the channel line in. If using coax cable connect to the VCR where it says in from antenna. Remember that if using this method your VRC does not have th remain on to view Direct. If you're trying to record Directv, then your VCR need to be on the same channel as the Directv output channel either channel 3 or 4. If trying to record Directv using RCA connections the VCR needs to be on the AV settings. If you have any futher questions please feel free to call me at (361)510-0339
Jonas Lopez
Jag Satellites/ Directv
Installer and Technician specilist
Mar 02, 2009 | Daewoo DV-T47N VCR
Connecting Hitachi VCR to my Direct TV.
Connect your Direct TV to the Ant. In connection on your VCR. When you want to watch TV, just tune the TV to channel 3 (or whatever channel the Receiver is set for). When you wish to record, set your VCR to that same channel and set your TV to the channel that your VCR outputs to. For simplicity sake, I would suggest setting both systems to channel 3 and just watching your program through the VCR. If you are still using an "off air" antenna, then connect that antenna to the ANT. IN connection on your Direct TV receiver and when you turn off the dish, it will pass the signal through just like the VCR would.
Jan 28, 2009 | Hitachi VTF392A VCR
Hook up,s
Hi-I used to be a DirecTV installer. Depending on the type of reciever you have, there are yellow/red/white or red/green/blue outputs on the back. You will need to run the dvd/vcr through these and then change the tv to video 1/ video2, or AVI, CV1, CV2, Front (or whatever acronymn your tv has) when you want to switch between the componet and the reciever.... you should only need to change the tv channel to be able to use the dvd player. I've found that vcr's usually need to be on channel 3 and if DirecTV is using ch 3, you may have to slide the button on the back of the reciever to ch 4 instead.
Jul 24, 2008 | VCRs
Hitachi VT-FX240E
Jan 27, 2008 | Hitachi VTFX65SK S-VHS VCR
RCA VR355 recording problem
Are you sure the reciever is coming through the vcr.? are you hooking it up through a/v on vcr?
if so hook from a/v out from directv to a/v in
jacks on back of vcr. and turn vcr on a/v channel
to record it. you will see the picture as you record it. if the vcr isn't on a/v channel it won't record it
If you use ch 4 or 3 to record it you
hook up directv to cable in on vcr and you
have to turn vcr on that channel and see it coming
through it you have to push a button on satlette
remote to make it come on the vcr on the channel
or it will record snow. and you have to push
another button on vcr remote if you haven't
already to get the vcr on ch 4 or 3 on your tv
or if u got it through a/v turn tv to a/v channnel.
just beacuse you see the picture coming through
your tv doesn't mean it going through your vcr
you could be just seeing it through the tv only.
you will see the vcrs graphics or vcr channel number on your
tv too along with the directv channel if it's hooked
up right. notice the vcr won't record it's own
graphics or channel number on the screen but it will record the directv's graphics. and it won't record the tv's own grapic channel number either.
to make sure it's right you will see 3 graphics on
your tv the own tv's channel number or a/v
the directvs and the vcr's channel number or a/v
on your tv if you see these you know it's hook up
Nov 11, 2007 | RCA VR355 VHS VCR
Dvd into vhs input
If you can watch TV normally then it should be a button on your VCR remote. It could be "Input", "Line" or "Aux". Tvs with more than one input line will may require 2 presses on that button, one for each line. This is the best answer that I can give not seeing your remote. Any questions?
Nov 07, 2007 | Hitachi VTFX685A VHS VCR
VCRs Logo
35 people viewed this question
Top Hitachi VCRs Experts
Sudeep Chatterjee
Sudeep Chatterjee
Raj Patel
Are you a Hitachi VCR Expert? Answer questions, earn points and help others
