Question about Frigidaire GLER331A Electric Dryer
The dryer drum squeeks.
The drum squeeks while the dryer is operating. What is the solution?
  • jgarner9 Jan 10, 2009
    Dryer drum squeeks.
  • 32 Answers
Replace rear bearing with kit available, and replace front glides
Posted on Dec 23, 2008
Bosch Tumble Dryer WTA4107GB squeeks in operation
Sounds like it has a bad drum bearing.
Dec 17, 2013 | Dryers
Squeaks from drum area during operation
Hi there!
I think it is the drum main bearing that has started to sieze.
If it is not this, then the drive belt may need replacement.
If this leads to a solution, please take a moment to accept. Thank you.
Jun 18, 2008 | Bosch Nexxt WTMC 3300 Electric Dryer
Ge frontloader dryer is squeeking incessantly, high pitch squeek driving us all crazy. by manually turning the drum i can isolate the squeek, but cannot see anything wrong. does it need to be taken...
There is a teflon bearing that holds the back of the drum you will need to replace. To get to it remove the top cover, take off the control panel, remove the front cover, take off the belt, then take the drum out, ususlly by lifting it up as you pull it foward. While have it all apart I would reccomend replacing the teflon glides at the front that the drum rides on.
Jan 31, 2011 | General Electric DCVH680EJWW Dryer
Dryer makes a squeeking,or "chirping" noise while
Most likely the problem is the drum rollers are in need of lubrication.
Lube the drum rollers and this should solve your noise problem
Jan 05, 2011 | Maytag MDE9700AYM Electric Dryer
Dryer making a high pitched squeek, I took apart
I normally don't work on gas dryers but it sounds like the drum rollers are in need of lubrication. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Dec 27, 2009 | Amana LGA10 Dryer
Dryer squeaks when turned on, recently is getting louder and louder as drum is turning. Is it worth getting fixed, it's six years old
The squeek is probably the front 'bearing' which is generally made of felt.
Pop the top, pull off the front, remove the drum. Clean the felt or replace it.
A better alternative is to turn up the radio so you cant hear the squeek.
If you do go to this trouble, you may want to replace the belt while you have it apart.
Personally, id let it squeek. It may be annoying but on the ohter hand, you know when it is operating and when it is finished now.
Oct 21, 2009 | Dryers
Ge dryer squeeking
HI,
For a pictorial troubleshooting please open the link:
http://www.applianceaid.com/my_own_dryer.html
You will be looking at the front glides that the drum rides on, the glides are probably gone and the drum is rubbing on the plastic glide holder....if it is damaged will need to replace the front drum bearing/glide holder and all of the glides, usually about 4 of them.
If it is the drum front glides the noise will be from the front area, right behind the front panel at the top. If the noise is from the center rear of the dryer your drum bearing is gone, need to replace this also if you have to take this dryer apart..
Thanks
Apr 08, 2009 | GE Dryers
GE Dryer SQUEEKS VERY LOUDLY
Good Afternoon,
Replace all the drum rollers. You have to remove the belt and drum to get to them. Are you fixing this yourself? Let me know if this helps you and thank you for using FixYa!
Mar 27, 2009 | Dryers
Maytag gas dryer makes squeeking noise
it is more likely one of the drum rollers
Dec 20, 2008 | Maytag Dryers
Maytag dryer model # LDE5005ADE has a squeaky noise when starting up to dry clothes
thanks for the question. If your dryer squeeks just a short squeek just as you start it thats not a big problem If the noise is there all the way through the cycle it could be the drum rollers locatedat back wall of dryer ,the drum rides on 2 of these they could be worn if its a short sqeek could be a slightly worn belt . thanks for the question The appliance doc
Sep 10, 2008 | Maytag Dryers
Frigidaire GLER331A Electric Dryer Logo
128 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
