Question about Motorola Mobility V551
Charging deffect i brought a new battery and the charger not charging the phone an the charger is also new
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 8 Answers
Try cleaning the contacts on the phone also make sure the charger is properly connected if that don't work you may have to check the connection inside the phone it may need soldering. had a similar problem.
Posted on Jan 02, 2009
Lg tu500f
You need to replace the charger
Aug 12, 2008 | LG CU500 Cellular Phone
When ever i try to charge my phone it wont charge. I brought a new charger and new battery still wont charge
Hello there,
Have a nice day.
You have mentioned the you have bought a new charger and a new battery but still your handset wont charge.
The problem is from the charging port on your phone. You will need to change or replace the charging port on your phone to fix the problem.
Try to take your phone to any Sanyo service center or any local phone repairer to help you replace the charging port, it has a minimum charge only.
Hope it helps,
Thank you for using the fixya.
Adieh
Sep 12, 2011 | Sanyo Incognito 6760
Paslode battery wont hold charge.brought new battery, same thing.brought new charger, same thing. put battery in gun, fan runs and then the battery is flat again.
if you have bought a new battery and charger , and it still will not hold a charge. you might have bought a bad battery or charger , also the fan dosent allways run so the fan going off is not a sign of a dead battery. depress the trigger or safety and the fan should start up again
Feb 14, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Hi, I have a motorizr Z3 phone whose charger failed. I have run out of warranty and hence I went to a store and the guy gave me another Motorola Charger that is of 6.5 Volts. My original charger was of 5.0...
hi, you need to get the same charger if the output is to high then the phone wont put the charge into the battery as it could cause it to over heat, the best place to buy one from would be the well known online auction site you should get one from their for next to nothing and this will then solve the problem.
You know the battery is not at fault as it charges from your computer via the usb lead however the charger you have brought should still charger the battery but may cause it to over heat so to me it seems like their is a fault with the new charger. Its always best to buy the exact type of charger you had in the first place as this ensures the battery is charged properly.
What phone makers do is keep the same charge connector across most of their range of phone but as phones and technology changes they start using different batteries in their phone so they have to change the charging power to match the phones battery, so the charger you have brought is probably for a newer phone with a higher voltage battery, so you need to get the correct type of charger and this will then solve your problem.
Or if you have a car you could buy a car charger as these charge the phone alot quicker as they run off 12volt so put out more amps to the phone but keeping the volts at the correct type.
Let me know how you get on or if you need further assistance ok
Jan 27, 2010 | Motorola Mobility MOTORIZR Z3 Cellular...
My phone wont charge
does it ask you please insert a genuine battery ? if so then its the firmware. re flash it. costs $30. or else its the charger port on the phone. needs to be replaced.
Jun 13, 2009 | Sony Ericsson W760i Cellular Phone
MY MOBILE PHONE CHARGING SOCKET HAS SNAPPED
You have 3 options when the charge port breaks.
1. get it repaired, warrant if possible
2. Get a new one
3. Get an external battery charger and charge battery separate from phone. Another battery and charger will set you back about 10 dollars on ebay.
For more information and links to the parts check the following link below.
Fix for Broken Charge port on Samsung SGH-D900
Mar 07, 2009 | Samsung SGH-D900 Cellular Phone
Motorola RAZR2 V9 new phone wont charge
Spare Battery Charger - Motorola RAZR V8 /V9 - $14.95
will need also a USA/Uk power adaptor /converter to use in Uk.100% works by charging battery separately from mobile
Jan 29, 2009 | AT&T Motorola RAZR2 V9 Cell Phone - Purple
Not charging brought new charger still not workin
The battery may have reached end-of-life. Try getting a new or refurbished battery.
Jun 13, 2008 | Samsung Cell Phones
Motorola Mobility V551 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
