Question about Epson Stylus Color 1160 InkJet Printer
Printer Feed Problems
I have an Epson inkjet 1160 wide carriage. The paper is loaded to print. The first piece of paper will start to feed but then will pass through. Sometimes the next piece will catch and print and then other times a few pieces will pass through before it will catch. It will almost always happen with the first piece and then will happen randomly through-out if I am printing 20 or 30 copies.
  • Hollis Pecora Mar 30, 2007
    I use 24lb. paper, which is what I have always used. It happens with all papers. Heavyweight stock, labels, cardstock etc.
Epson Stylus Color 1160 InkJet Printer problem is all light are flashing, they say the waste pads need cleaning is this true????
Bill,
Posted on Apr 14, 2008
Paper too thin 80gsm is too thin..try100. hope it solves your problem...did mine cheers derek
Posted on Mar 30, 2007
Epson xp430 paper jam, but I can't find any jam!
They don't tell lies :>) Even the smallest piece of paper over the sensor will record a jam. This often happens when you have a jam and you pull the paper and it tears a piece off. Open all the doors, remove the paper tray, remove all the toner or cartridges and look with a flashlight. Always pull paper jam paper in the direction it was going, undo tensioner clips if present and pull paper evenly and slowly as not to tear the paper. If you do, keep the paper and find the piece that fits the piece that is missing.
Having said that, see the link
Paper Jam Problems - Epson XP-430 User Manual [Page 234]
https://www.manualslib.com > ... > Epson Manuals > Printer > XP-430 > User manual
Epson XP-430 Manual Online: Paper Jam Problems. If you have problems with paper jams, try these solutions: 1. Cancel the print job from your computer, if...
SOLVED: Error says paper jam, but there is not. What could cause this ...
https://www.ifixit.com/.../Error+says+paper+jam%2C+but+there+is+not.+What+could... Dec 18, 2013 - I have an Epson Artisan 837 all in one. It was working perfectly fine yesterday. Today it is telling me I have a paper jam. I went through the steps ...
How to solve paper jam or paper feed error DO IT YOURSELF ...
? 3:43
https://www.youtube.com/watch?v=kHHpVcSJvvA
Aug 16, 2016 - Uploaded by Easyprint-DZ Support
... of commons problem of printer . paper feed error or paper jam error. ... we gonna work on epson ...
Paper Does Not Feed Correctly - Epson
https://files.support.epson.com/htmldocs/pho22_/pho22_rf/trble_4.htm Paper does not feed. Multiple pages feed. The paper jams. Paper is not ejected fully or is wrinkled. Paper does not feed correctly when using the double-sided ...
Epson XP-430 ' XP Series ' All-In-Ones ' Printers ' Support ' Epson US
https://epson.com/faq/SPT_C11CE59201~faq-293729 Mar 24, 2016 - If paper jams when you load only one or two sheets, try loading more sheets at a time. Do not load more than the recommended number of ...
Epson xp430 paper jam Google Search
Oct 23, 2017 | Epson Office Equipment & Supplies
Epson DFX9000 printer is printing blank pages
On mine it was to turn off the printer. Then while holding down the paper feed button, press the power button. Let go of the paper feed right away as soon as you hear it start up. When it's done you should get a printout with a number at the top.
OR
Still Having Epson Printer Problems Then follow Us On: Epson Printer Support
Jan 27, 2014 | Epson DFX9000 9PIN WIDE 1550CPS PAR SER...
EPSON Photo 1400 paper feed and ink replacement problem
Asit is only a couple of months old seek a replacement under guarantee/warranty.
Jun 29, 2010 | Epson Stylus 1400 InkJet Photo Printer
I have an Epson R1800 and when I load Roll 13X19 matte media and try to print I either get a "jammed media" message or the printer trys to print without feeding the media.
I had a similar problem trying to print epson pro canvas. I finally learned the "trick". First I generally cut an appropriately sized pice of canvas from the roll. Then I attach a HEADER. This is dome by cutting a piece of 13" wide photo paper in a three inch length (so you have a piece 13" x 3") . Draw a line at 1.5 inches and place some sort of adhesive (I use a double sided tape gun) on one side of the line. Line up the canvas/paper with the line and make sure it sticks to the header.
Now you should be able to manually feed the header/paper into the printer - once the header passes the correcct point the printer will "grab" it a position it correctly for printing.
Hope this helps
nickerjo,
leaningpalmstudio.com
Oct 26, 2009 | Epson Stylus Photo R1800 InkJet Printer
Paper feeds ok but after a second it advances an inch then get the error paper jammed. wont print please help
When turn on status ok, but when star to print, it feed paper then jammed? Problem with head carriage. Check chip and connector chip at carriage. Try to use another ink tank.
Jun 25, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson c90 paper feed problem
Is the message general error? The problem is tchip. When turn on chip is recognized by printer, but when start to print, printer "read" some information from the chip. Here is the error. Some pin at the chip for redaing the existence of chip, other pin for reading the information. Check connector between chip and carriage.
Apr 17, 2009 | Epson Stylus C86 InkJet Printer
Epson stylus c68 paper jam
Hi Guest.
Turn your printer off and load a single sheet of paper. Move the rubber wheel to anywhere. Turn the printer on and watch what happens in the paper feed slot (in official Epson parlance this is the "automatic sheet feeder" or ASF). You should see the rubber wheel etc set into the correct start postion. Then press the paper feed button and watch again. The plastic "wall" behind the piece of paper should move forward, pushing the sheet into the rotating rubber wheel. This should feed the paper into the "ready to print position". If this doesn't happen, it means something has come adrift inside the paper feed system. To investigate this further requires the printer to be dismantled. Either take it to a technician, or if you want to have a go at doing this yourself, post a new comment to this effect and I will help you do this.
Mar 17, 2009 | Epson Stylus Photo R320 InkJet Printer
My printer no longer feeds in Epson Premium Glossy paper S041624
Try to clean the paper pick rollers with a cloth, dam it with little water and try to hange the paper settings by going into printer preferances.
Regards,  raj_p5983
Jan 20, 2009 | Epson Stylus Color 1160 InkJet Printer
Epson Stylus Color 1160 InkJet Printer Logo
192 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
