Question about HP Officejet 4315 All-in-One Printer
HP solution center?
I need the HP solution center download for Windows XP
Following are instructions I received for removal and reinstall of solution center. If this is a new install, you can just skip the instructions and click on the link. This involves removing all printers from your system. If you have some you want to keep you need to be more selective about what you delete in steps B,C, and D.
The following steps will wipe printer and printer drivers from the computer:
A. Removing entries from Add/Remove programs.
B. Removing entries from Printers and Faxes folder.
C. Removing entries from Registry.
D. Removing folders from C:\Windows
A. Add/Remove Programs:
1. Click Start, Control Panel and double-click Add/Remove Programs.
2. If there is an entry relating to one of the printers, select it, then click Change/Remove.
3. Follow the dialog and "uninstall all" or "remove all" as appropriate.
Some "printer software" have programs that show up here and it will be a good idea to remove those before going any further.
B. Printers Folder:
1. Click Start, Control Panel and double-click Printers and Faxes.
2. Delete all the Printers available, by right-click and selecting "delete" option.
3. Click File menu and select Server Properties.
4. Select the Drivers tab.
5. For each entry, select the entry and click Remove.
C. Windows Registry:
Before modifying registry, take a backup of it.
1. Click Start and click on Run.
2. Type Regedit and from File menu, click on Export Registry.
3. Select "All" option for backing up every key of registry.
4. Give a destination file (say Regbackup) and save it on to the Desktop.
5. Now, click "+" beside HKEY_LOCAL_MACHINE\SYSTEM
6. Click "+" beside CurrentControlSet
7. Click "+" beside Control
8. Click "+" beside Print
9. Click "+" beside Environments
10. Click "+" beside Windows NT x86
11. Click "+" beside Drivers
12. Under this key, there will be the keys Version-2 and Version-3 (some may be absent, which is normal)
13. Click on each Version key to find contents in the right-window pane.
14. Delete all the sub-keys inside Version-2 and Version-3, but not these keys themselves.
15. From File menu, click exit.
D. Deleting Folders:
1. Click Start, Run and type "cmd" (without quotes).
2. Key-in the following commands:
net stop spooler
net start spooler
3. Type exit.
4. Open Windows Explorer and navigate to:
%systemroot%\system32\spool\drivers\w32x86
NOTE: %systemroot% is usually C:\Windows, but it might be "winnt" or something else; this is set when the OS is installed.
5. Inside w32x86, there will be folders with the names 2 and 3 (some may be absent, which is normal)
6. Delete all of the files and sub-folders in each of the 2 and 3 folders, but not the folders themselves.
7. Inside w32x86, there may be other folders with names starting with "hewlett_packard", "hp" or something else; delete these folders also.
8. Restart the print spooler (as in 2nd step, above)
9. Restart the computer.
At this point, the system should be pretty well back to the way it was before any printers were installed. The printing subsystem is then "clean" and ready for printers to be added using printer drivers. Install the all-in-one software, now.
Steps to download the software
Click on the link below to view the software download page.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-40521-1&lc=en&dlc=en&cc=us&os=228&product=1138342
1. Click the Download only button.
2. Click the save button.
3. select desktop in save as window.
4. click on save.
5. The software will be downloaded to desktop
6. Unplug the USB cable from the computer.
7. Double click on the downloaded file to start the installation.
8. Follow the on-screen instructions to begin the installation process.
(plug the USB cable when the installtion prompts for).
Posted on Dec 31, 2008
How can i find drivers for HP Media Center m7000
You can download the device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Dec 31, 2012 | HP Media Center M7000 Drivers Recovery...
I just upgraded from an old dell (windows XP) to a new machine running windows 7. I have an hp scanjet 4570c scanner that I want to use. It ran fine on XP, including the HP director software and the HP...
if you still have the installation disc for the printer use it when adding a printer to the win 7 os
or go to hp download site and download the drivers for the printer
or may be go to the printer properties tab , click on compatibility and tick the box and high light win7 os and apply
Apr 15, 2017 | HP Scanjet 4570 Flatbed Scanner
I have an Compaq laptop with a built in web cam but how do i turn it on?
hi
this is the routine driver for the camera : download it , but you need to add a supplement software to use the camera : such as using the camera with SKYPE .
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-42488-1&cc=ca&lc=en&dlc=en&product=1842155&tmp_track_link=ot_search
this program facilitates these operating systems only
Microsoft Windows XP Home Edition
Microsoft Windows XP Media Center Edition
Microsoft Windows XP Professional
thank you for using FIXYA
Apr 11, 2011 | HP Pavilion dv6000z Notebook
I am just trying to download HP Solution Center for an HP L7680 All in One...I cannot find the free download for this device...can you help
May I suggest - HP Support > HP OfficeJet Pro L7680 All-In-One Printer > Installing HP Solution Center.
OH, but WAIT, there's more.....(Sorry too many commercials)
Click on the + sign to the left of -
Do I already have HP Solution Center on my computer?
Gives you directions, and information about HP's Solution Center.
If you have the Windows XP operating system, click on the + sign next to Windows XP.
If you have the Windows Vista or Windows 7 operating system, click on the + sign next to Windows Vista and Windows 7.
Oct 29, 2010 | Computers & Internet
I cannot play a sound because i don't have a sound
Click on the links below if your computer has that particular operating system on it.
Microsoft Windows 2000 s.gif » Microsoft Windows XP s.gif » Microsoft Windows XP Home Edition s.gif » Microsoft Windows XP Media Center s.gif » Microsoft Windows XP Professional s.gif » Microsoft Windows XP Tablet PC Edition
Jun 06, 2010 | HP Compaq nc6000 Notebook
I have an HP media center pc the m370n, and i just upgraded to windows 7 ultimate. I can not get the tv tuner to work, what could be wrong? thanks. Ryan
think you'll find the drivers for the tuner are not compatible with windows 7. according to the hp website this is an xp machine. download the windows 7 compatibility checker from here to check http://www.microsoft.com/downloads/details.aspx?familyid=1B544E90-7659-4BD9-9E51-2497C146AF15&displaylang=en
Oct 14, 2009 | HP Media Center M370N (DM163A#ABA) PC...
I reformated my desktop and theres no sound on this hp pavilion a6000n i need sound
he has
  • Windows Vista Home Premium
  • Windows Media Center
  • or windows xp and here the website to download the drivers for vista, xp, media centre
    http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3377269&lc=en&cc=us&dlc=en&lang=en&cc=us
    Apr 15, 2009 | Fujitsu Siemens ESPRIMO P2500 PC Desktop
    IE 7
    Yes you can upgrade your Internet Explorer to IE7 (assuming you have IE6 right now)
    You can download and install IE7 from Windows updates or go to the Windows Support Site to download it at http://support.microsoft.com
    Only upgrade to IE7. Do not download and install IE8 Beta. It is still in testing. IE7 will not cause any problem with your HP Pavilion.
    Jan 31, 2009 | Microsoft Windows XP Media Center Edition...
    Xp audio driver for fujitsu amilo
    Downloads results for AMILO La 1703 CLICK HERE FOR AUDIO DRIVER
    CLICK HERE FOR SUPPORT PAGE AND ALL THE DRIVERS
    VT8237A imbedded / VT1708A codec(HD ADeck's default setting changed)
    Title: VT8237A imbedded / VT1708A codec(HD ADeck's default setting changed) Date: 04.10.2006 Size: 7,17 MB Version: 5.10.01.1080 Manufacturer: VIA Technologies Status: Released for AMILO La 1703 Language: all.gif Supports all languages Operating systems: [Supported] Windows XP
    [UnSupported] Windows XP Media Center Edition (WHQL)
    Minimize up.gif Use in the following products: minus.jpg AMILO La 1703
    Jul 03, 2008 | Computers & Internet
    Driver updates
    You can download free and realiable drivers for your product from the manufacturer sites.
    For realtek driver try this:
    This page contains all windows drivers for realtek. try this..... :))
    Thanks
    Iqbal
    Mar 31, 2008 | HP Media Center m1080n (PC099A#ABA) PC...
    629 people viewed this question
    Seeker5211
    Seeker5211
