Question about Dishwashers
My KitchenAid Superba won't run, no lights, nothing
After years of working fine, my KitchenAid Superba won't even light up. I've checked the switches, made sure nothing was blocking the door from locking properly, and checked fuses and breakers.
Any ideas?
  • gharbison Dec 18, 2008
    I did turn the power off at the breaker, still no luck. Thanks, anyway!
  • tony_messers Apr 25, 2009
    I called Kitchenaid and they shipped my a new display panel and controller board which I replaced. That didn't work and killing the power for an extended period of time didn't work either.
    I have tested the feeds coming in and it seems to be the proper voltage.
Turn off the power at the breaker and let it stay off for at least one hour
Posted on Dec 18, 2008
Water and ice dispenser and panel light stopped working.
02227c0.jpg Look at above diagram. #18 needs to be replace. Trim pops off then there will be several screws. Goodluck...
May 30, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid gas convection oven model # kgst307hbl4 won't turn off
seems like the safety switch not work. be careful
Mar 27, 2017 | Ovens
How to replace kitchenaid superba light bulb
The light bulb on the water/ice dispenser on our Kitchenaid Superba side by side refrig needs replacement. Easy! Right?
However it is screwed in so tightly and the location is behind the panel is so small, it it very difficult to get a grip on it to unscrew it!
We,ve tried rubber gloves, WD-40 and an Exacto knife(w/ fuse turned off!) and still cannot get this very annoying light bulb out!!
Does anyone have any ideas or can we remove panel it hides behind to get to it!!!???
Thanks for any info on this should be simple issue!!
Susan M
Jan 15, 2012 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba that doesn't refrigerate
cathe if compressor is not running nothinh will get cold specially if frezeer is not working then the other side wont etheir if compressor is not running then it might just be the overload if nothing is running just the lights the is etheir the timer or thermostat
Oct 14, 2008 | KitchenAid Superba Architect KSCS25INSS...
Short in freezer?
IF THE WIRES SHORTED, AND THE DOOR WAS REPLACED,
WAS IT COMPLETE OR WAS THE DISPENSER ASSEMBLY TRANSFERRED TO THE NEW DOOR? IF THE ASSEMBLY ISN'T NEW, THE CONTROL BOARD IN THE ASSEMBLY MAY HAVE BEEN DAMAGED FROM THE WIRE SHORT.
Feb 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Refer Icemake not working
The light is supposed to flash twice with a 1 second intermission. When the fridge door is closed the light stays ON. Check this by pushing the white flap to the right of the icemaker while the door is open
Dec 11, 2007 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba Dishwasher
gagaweaver, couple of things you want to check here. Check the upper spray arm for any clogged holes or cracks along the edges. Position it in the 12:00 position and run the dishwasher for a little, open the door and verify that it has rotated. Make sure the water entering the dishwasher is min. 120 degrees, use a thermometer. Makes sure that there is no large pans or dishes blocking the upper spray arm from spraying onto the inner door. If all that checks out. You will have to remove the lower spray arm, filter cover and chopper cover to make sure the chopper screen is not coated or plugged up. If it is, it will prevent a good flow of water to the upper spray arm. Catriver..post back.
Mar 07, 2007 | KitchenAid 24 in. KUDU02FR Built-in...
Dishwashers Logo
935 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
