Question about Baby Trend Compact Sit-N-Stand 73113 Stroller
Using with an infant car seat
I just bought this used stroller and I am trying to figure out if it can be used with a car seat. Various sites onlie describe it as compatible with an infant car seat. I'm not sure if it originally came with another attachment that would go where the child tray is that would accept the car seat. Or maybe there should be some sort of strap? If it is in fact supposed to accept a car seat, does the brand matter? I have an Evenflo Embrace car seat that I was hoping would fit somehow... Thank you for any advice!
3 Suggested Answers
  • 23 Answers
SOURCE: stroller compatability
The Baby Trend Snap N Go 1308 is compatible with the Britax Companion infant carseat, as follows:
Use snap bar position: II, use the BT bar on the "snap bar angle" and SNG depth position A.
Posted on Nov 03, 2009
SOURCE: problem with sit n stand stroller, attaching front infant seat
Posted on Apr 30, 2010
SOURCE: where can \r\ni order a strap extender for baby
i need screw for the front wheel to be attached where can i get one
Posted on Oct 30, 2010
0 characters
1 Points
Need used chicco infant seat adapter for 2010 bob stroller
Check out ebay or amazon you can get almost anything you need between these two sites
Mar 24, 2013 | Chicco BOB Infant Car Seat Adapter - for...
Pram or Stroller
Strollers with detachable infant car-seat carriers extremely practical. In the first couple of months, your baby can sit securely in the infant carrier while you go for a walk. As an added benefit, you can transfer your baby from the stroller to the car without having to disturb her, as you would with a pram. For older infants and even toddlers, you can use the stroller without the carrier. Most have seats where the back adjusts from nearly a full upright position to a full recline.,1511,942,00.html
on Oct 07, 2007 | Evenflo CitiTour Double-Tattersall...
1. How do I open and fold the DuoGlider stroller? 2. How do I attach an infant car seat?
The steering handle has a red switch on it. Pull the switch to the right and then twist the handle grip forward. The stroller should start to collapse.
Infant seats sit rear facing. You'll have to recline the stroller seat. Then the clip on the infant seat will grab the food tray and lock it in. Your stroller might have come with an additional strap to secure the seat once you have it locked.
Dec 18, 2010 | Graco DuoGlider 7924 Twin Seat Stroller
Was given to me without the manual. Can't attach infant seat to stroller. Not sure how to do it.
The manual on how to do this can be found at
To attach the Baby Trend Infant Car Seat, recline
the seat all the way back.
• Position the Infant Car Seat, facing toward the
rear of the jogger, so that the seat shell goes
into the Child Tray and latches into place.
(Fig. 13a) Check that the Infant Car Seat
is firmly locked onto the Child Tray before
• Check that the front Child Tray is firmly
attached to the jogger's armrests. Make sure
that the car seat locks into the front Child Tray.
Then turn tabs on stroller frame to lock the
front of the car seat into the stroller. (Fig. 13b)
• To remove the Infant Car Seat, squeeze the
release handle located at the foot-end of the
seat and carefully lift upward on the seat.
Hopefully that helps!
Jun 15, 2009 | Baby Trend Expedition LE Jogger
How to reverse zooper buddy stroller seat.
There are 2 red buttons on the bottom back on the seat. Push them together really hard until they lock in place. Pull up on the whole seat...really hard. The whole seat comes off. Then turn it around and snap it to the other knobs
Jun 09, 2009 | Zooper Cool Zone Buddy Stroller
New car seat, quinny freestyle
what you need is a maxi cosy infant seat. these are the ones designed to fit quinny freestyle frames. you will also need attachment bars that you can easily buy on ebay for a coulpe of pound.
hope this helps
Mar 10, 2009 | Quinny Freestyle 4 Marina Stroller
What infant car seats are compatible with an Eddie Bauer Vector
I read on anothe site only the eddie bauer infant seat is comp
Feb 15, 2009 | Eddie Bauer Glacier Vector Jogger
Graco Leisure Sport 7420 Jogger Stroller
My manual for the Leisure Sport says to only use with the Snugride. I think it's the only one that will snap in properly.
Feb 04, 2009 | Graco LeisureSport 7420 Jogger
Peg perego venezia stroller with infant car seat
you should be able to turn them how you want then lower the lver the way you want them to lock hop it helps
Oct 31, 2008 | Peg Perego Venezia Single MT Blu Moon...
Installation of Car Seat base
Try this link it seems very good
May 13, 2007 | Cosco Travel Systems 01-938 Stroller
Baby Trend Compact Sit-N-Stand 73113 Stroller Logo
98 people viewed this question
Top Baby Trend Baby Strollers Experts
Jennifer Rock
Jennifer Rock
Stephen Faulkner
Stephen Faulkner
Are you a Baby Trend Baby Stroller Expert? Answer questions, earn points and help others
