Question about Sony Handycam DCR-TRV330 Digital Camcorder
Digital 8 sony handycam will not stay on with electrical power
I am trying to use my camera without the battery, with only the electrical outlet. I am getting errors that I should use infolithium battery pack with camera.
  • lwhite63 Dec 18, 2008
    My battery is fuly charged and the camera will only stay on for about 3 seconds. Without the battery, using only the power cord the camera will come on and still only stay on for about 3 seconds.. The charge light over the battery is yellow. When the camera comes on for the 3 seconds the camera light is green, and the screen tells me to use the infolithium battery pack, and shuts off.
  • 10,594 Answers
Check battery placement connector, center pin has some problem and not sending info-lithium signal to camera system control.
You might need to replace this battery connector and this requires to open camera.
If you have some experience in camera repair, let me know to guide you further.
Posted on Dec 17, 2008
Worked when I first tried it
Sony handycam won't work! - Forums - CNET
www.cnet.com > Forums > Camcorders
CNETI dont know if this would work but have you tried resetting the camera? Some have a reset ... I hit the reset button. ... 2. left it powered up without the tape in for about 15 minutes. .... Sony Handycam Digital 8 Usb Streaming DCR-TRV250 NTSC
Fixing dropped compact cameras - Instructables
www.instructables.com/id/Fixing-dropped-compact-cameras/
Instructables*Disclaimer* This is not a guaranteed fix for your camera, if it is insured or ... you take with personal property and your own body by working on your camera, ... after removing the battery and give the battery a charge up if it won't go open it up and ....Tags: camera compact repair assembly dropped take apart digital damaged ...
Jan 27, 2016 | Cameras
Battery charging problem.
hi, its clear that the battery is gone .
replace the battery with a new one its gonna work fine.
when you plug the charging chord into the camera,the camera shuts down because the battery is gone.the battery has lost the ability to charge,so to protect your handycam from any hazard the camera shuts off.
take care bye & have a nice day.
Dec 13, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
I am trying to use a sony full hd 1080p handycam but the battery is low. How do I recharge it? Does it have a separate recharger?
my handycam, came with a separate charger. the battery gets removed from the camera, and put into a holder which can then be plugged into a wall outlet. This will recharge the battery.
Aug 20, 2011 | Sony Cameras
On a sony digital handycam digital 8 TRV 250. what does the self diagnosis display c:31:32 mean?
A malfunction other than the above that you can service has occurred.
  • Eject the cassette and insert it again, then operate your camcorder.
  • Disconnect the power cord of the AC Adapter or remove the battery pack. After reconnecting the power source, operate your camcorder
Oct 21, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
HANDYCAM USE
Go to any Sony dealer ask for NP-33 battery pack for your CAM
Cheers
Dec 08, 2008 | Sony Handycam CCD-TRV416 8mm Analog...
DCR-SR42 Camcorder does not power up
I think AC power charger of your camera got defective first and later on battery lost its charge so no power for camera now to power up.
Try to borrow same charged battery from friend. neighbors etc and test your camera.
If camera power up, it is sure that charger has gone and you need new one.
let me know in that case to guide you further.
Oct 05, 2008 | Sony Handycam DCR-SR42 Camcorder
Operation
if you power the camcorder from the call socket, if it works that mean the battery has bad.
May 12, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
New batteries will not charge
a technician ' s adjustable bench power supply - set for 9 volts at 1 amp - for a minute or so , will initialize most new lithium batteries ( a charger update may also be available ) ;
Sep 18, 2006 | Sony Handycam DCR-HC30 Mini DV Digital...
Sony Handycam DCR-TRV330 Digital Camcorder Logo
229 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
