Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
How long to record a dvd from vhs?
I have a quantity of vhs to convert to dvd. I need an approxiamte amount of time that I can expext per vhs.
  • 376 Answers
It will be the same lenth as the vhs plus a bit extra for finalizeing and stuff
Posted on Dec 18, 2008
Unit will record by peressing the record button. But when programmed to record, the unit kicks on per the program, tape runs but does not record anything
Vintage VHS recorders can get quite messy. Probaly you need to take it to service. Presume it's time to convert your family tapes to DVD.
Sep 25, 2015 | Mitsubishi HS-U445 VHS VCR
Using a JVC /DVD/S-vhs dual dubbing Deck model jvc sr-mv55u Trying to do a straight dub from an edited S-VHS tape to a formated for video DVD for archival library. I am following the instructions in the...
now days dvd player comes with advace tacnoloy
u not need make vedio dvd u make to your dvd as a data dvd & dvd plyer read it isely so dont need to do vhs or vcd
Mar 29, 2008 | Televison & Video
How to convert VCR to DVD
no easy way to do this unfortunately. You either need to connect your VCR to a DVD recorder and record it directly onto DVD or use a device such as this http://www.dx.com/p/easycap-usb-video-capture-adapter-5707 to connect your VCR to your computer and record it onto your computer that way.
Feb 23, 2015 | Zenith XBR616
Can I transfer my VHS tapes to DVD using my Aiptek A-HD+? I do not have a DVD burner, can I use an external one? I really have no clue where to begin and what problems I might run into. If this is even...
The Aiptek A-HD+ has an AV in mode that can record from sources like VHS,DVD,TV etc. Connect the output from the VHS player ( You will have to use a composite cable i.e RED,WHITE,Yellow cable) to the AV - in of the camcorder. Press play on the VHS and record on the cam. The recording will only be at 640x480 or VGA resolution. Once your video is recorded transfer the video to the PC as you regularly do by copying and pasting to your internal HDD. Use a software such as Nero Vision Express to convert your videos to DVD format and write a DVD. It will take come time as the video will have to be converted from the format the cam records in to MPEG-2 which is the standard compressor for DVD. You can use an external DVD writer , but the writing will only start after the files have been converted. You will need some converter for converting the videos to DVD standard or else it might not work on the DVD player's. There are many converters available online but Nero is easy and just one step, drag all videos and click write it will convert and write the DVD , easy.
Hope this Helps.
Mar 04, 2011 | JVC Video Cameras
How to record a vhs tape to dvd on a samsung 1080
Hello
1.The VHS/DVD player must have recording capabilities.
2 Connect both players to a television so that you can make sure you are recording the appropriate content. You can also monitor the speed at which the VHS is copying to DVD.
3. Place the VHS in the VHS player and the blank DVD in the DVD recorder. You will need to use your remote and go through the menu options to choose the correct format for recording. The formats should be clearly labeled and outlined in your instruction manual. Choose the option that will read something like "VHS to DVD." You may also have to choose recording speed, which varies per blank DVD that you purchase. Every player is different, and every menu will vary slightly. If you have questions, refer to you individual manual.
4. Select the option that works best for you and hit "Play" on the VHS player and "Record" on the DVD recorder. To play the finished DVD, you will select the playback option.
THANK YOU
Dec 14, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
CAN I RECORD A MOVIE FROM VHS TO DVD?
Not if you mean recording within that 1 unit from VHS to DVD.You would need a second unit DVD recorder which normally requires a digital input of some sort such as a cable box or a self-contained digital scanner but I am not sure if that would even work.It would depend on what the media input was recorded on the VHS.
Sep 25, 2010 | Sanyo DVW-6000 DVD Player/VCR
When copying a vhs tape to dvd, and there is only a short amount of video on the vhs tape, how do I just burn that and not the whole 2 hour tape? When I stop the copying it does not finalize and do not...
You must be able to watch what is being reocorded.
After the part you want to record is finished stop it.
Also the recording can be set for a set amount of time.
Jan 07, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Aug 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VHS to DVD dubbing
YOUR OWNERS MANUAL
Please follow the troubleshooting steps found on page 105 of the user manual.
Additionally, be sure all cables are hooked up properly (page 12)
Thank you for using FixYa - a FixYa rating is appreciated!!
Feb 08, 2009 | Sony RDR-VX555
I cannot record using a DVD/VHS player.
You can record. From antenna to converter box, from converter box to vcr. From vcr to TV.
TV on Channnel 3 VCR on channel 3, and set channel on converter box. Then Record.
Time recording works the same way, but you can set for only one channel at a time. Tht is the only restriction that I have not overcome. The converter box sets the channel. Gee Whizz
Dec 14, 2008 | Philips Magnavox DVD/VCR Dual Player
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
80 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
