Question about Garmin StreetPilot C330 GPS Receiver
Garmin c330 antenna connector has fallen into the gps
How do I retrieve the antenna connector from inside the gps
Pry off the colored faceplate around the screen. Underneath will be four screws. Remove them and open the unit up. You should be abe to access the inside of the unit to figure out a way to reattatch the connector. I have not had to do this but I have opened a couple up to replace displays. The hardest thing is getting the thing back together due to how the antenna mounts (poorly). Just open it slowly and visualize how it goes back in. I have no advice on actually fixing your issue, just on how to get in to look around.
Posted on Dec 18, 2008
My Garmin does not connect to sateliyes
Try Raising the antenna and then press the reset button when the C330 is on,this should restore the garmin, then: Make sure the C330 is fully charged and
I would try updating the C330 by connecting to to a usb port on your computer and then downloading Garmin Communicator. If that does not help then try contacting Garmin. I will attach a link to Garmin customer support. thanks for using FixYa
http://www.garmin.com/garmin/cms/site/us/support/supportcontact
May 05, 2011 | Garmin StreetPilot C330 GPS Receiver
C330 external antenna connector has gone into the gps
yes there is a way of retrieving it just take the faceplate off unit and there is 4 small phillips screws there take them out and unit will come apart
Dec 17, 2008 | Garmin StreetPilot C330 GPS Receiver
Update older garmin c330 purchased march 2006
check with GARMIN we have no clue as to if OLD units can be updated . Google GARMIN UPDATING
Feb 05, 2018 | Garmin StreetPilot C330 GPS Receiver
My Garmin c330 has difficulty acquiring satellites in my new 2009 Camry XLE. Does it have something to do with Bluetooth? Does it interfere? Ever since we bought the 2009 Camry XLE in June, the Street...
The C330 does not have bluetooth capability. Regardless, this has nothing to do with the unit's ability to acquire satellites. Nor should the type of vehicle you purchased, unless the unit is unable to receive due to some feature, like something in the windshield, which is preventing the unit from receiving a proper signal. Does the unit work outside the vehicle?
Aug 02, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Battery
Remove front bezel by lifting just under the GARMIN name. Remove the 4 outer screws. Gently pull apart. Keep in mind the orientation of the antenna as it's a bit tricky to put back. The battery is mounted between the two speakers.
It's a round cylinder item attached to the main board by a plug. Problem is this plug also houses the connection to the speakers. If you are good at rewiring, cut the battery leads and reconnect them to the new battery. Not sure where to get the battery though.
When putting back the antenna, keep note of the tabs. The lower one remains on the outside of the shelf guide, and the upper one is on the inside of the shelf guide.b0d8aad.jpga47c0e7.jpg2a171e3.jpg
Jul 24, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330
Purchase an external antenna from Best Buy or on line from Garmin.
Jun 27, 2008 | Garmin StreetPilot C330 GPS Receiver
Pop the face plate off with your thumb nail right uner the Garmin logo. On the right side you will see a reset button. Depress it for 2 seconds. Replace face plate and power back on.
Nov 23, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin c330
Some automobiles have a metalic coating on the windshield. You will brobably need a remote antennae to use the GPS in this car.
Feb 14, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
55 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
