Question about Canon EOS 400D / Rebel XTi Digital Camera
Master Reset on a Canon EOS 400d without starting the camera
My question is basically as stated in the sumary, how- if possible, do I perform a master reset/cold boot/reboot of the camera without using the on screen menu?
-Is there for example a set of buttons I should/could press at the same time when switching the camera on?
  • 1 more comment
  • Bj?rn ?rntorp Dec 18, 2008
    First of all, thanks for your response!
    I can definetely do so.
    The problem is that the camera does not start.
    Tests I've done regarding that so far are:
    1: Recharge main battery - no result
    2: Remove battery, insert battery again - no result.
    3: Try to start the camera connected to a computer via USB with, and without main battery - no result.* (Of course this has been tested using different USB-ports and different USB-controllers on both my test computers.) - no result.
    4: Try to start the camera without the smaller backup/date/time-keeping battery (cr2016). - no result.
    5: Try to start the camera without the smaller backup/date/time keeping battery (cr2016) with camera connected to computer. - no result.
    Regarding 3)* - I have tested it both on my windows xp pro 64bit workstation and my ubuntu 8.10 laptop.
    The most interresting part here (AFAIC) is that the ubuntu system log- wich usually is very very detailed gets no input at all when the camera is connected.
    Everything I use with the camera (except the cf-memory card) is standard canon-products, no third part battery/charger etc.
    Well I realized that the questions here normally hold a different standard.
    First of all I won't hold it against you and I had already figured out
    that it has to be a power-problem and contacted my local
    Canon-dealer/shop, so I also agree with you on this.
    Asking on here was basically a last resort for finding out if there was
    any way at all that I could do something I had not already tested.
    Anyways thanks for your help in the matter.
  • jcdill
    jcdill May 11, 2010
    Can you explain why you can't or don't want to use the on-screen menu? What happens when you simply start the camera normally?
    Novelist:
  • 121 Answers
First, thank you for providing such detailed information about what you have already tried! This is a refreshing change from most questions asked on this site.
Second, I have bad news. All of the symptoms you describe are consistent with a power problem within the camera. No amount of pressing different buttons or loading different software as the camera stars will help it start if it simply isn't getting power from the battery.
You can reset the firmware by loading firmware onto the CF card. As part of the boot process the camera checks to see if there is a special file on the CF card that then updates the firmware on the camera. See this link for more details.
Finally, as a new Expert on this site I'm trying very hard to only provide answers that "fix" the problem so I can get FixYa ratings and maintain my high rating. Unfortunately, this isn't a "fixable" problem if the real problem is a power problem inside the mechanics of the camera. I hope you won't hold that against me when you rate the answer I've given. Thank you.
Posted on Dec 18, 2008
Can i use a Cullmann C28 flash with Canon Eos 400d?
Doubtful. I tried similar with a different brand of flash designed for a 35mm. It worked for about 20 shots then the diodes fried. I've since bought a used Speedlight for my 400D and it works great.
Aug 19, 2014 | Cullmann Cameras
Canon eos 400d error 99, shooting not possible. turn the power swithch on off again or re-instal the battery. It has been doing this for a long time and nothing is working to fix it! Thank you,
1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 400d service manual link:
http://goo.gl/LHYVAy
it will help you to save a lot of money
Hope it helps, Thanks
Oct 22, 2010 | Canon EOS 40D Digital Camera
We have not recieved the cash back from the eos 20th anniversary.
Not sure why you would write to FIXYA The probllem is clearly one that Canon need to address. Contact Canon in your country with the details.
Please rate my help++++Thanks for using FIXYA
Nov 24, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
My canon 400d, suddenly stopped working, it does not start and no power at all. pls help
Such symptom indicate a malfunction on the DC/DC voltage converter circuitry, and the camera has two of them located in different boards.
In order to perform a correct diagnostics and repair of it, it is necessary to open such camera and perform it by a qualified camera repair technician.
If it's under warranty, I do recommend you to send it back to make valid the warranty.
If not, then you hav the options of pay for its repair, or do it yourself if you are willing tgo open it and perform some basic diagnostics of the failure. You will needtools to do it, which includes the usage of a soldering iron.
Best regards,
Jun 15, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
I would like to download a copy of a canon eos 400d manual in eng
Here's how to do it:
Go to this page: Canon Digital Rebel XTi
Click Drivers & Downloads, scroll all the way to the bottom, and click on the PDF link as shown.
EOS DIGITAL REBEL XTi / EOS 400D
DIGITAL Instruction Manual
EOSDRXTi400DIM-EN.pdf
Apr 22, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
EOS 400D "lag"
Try reformatting the card. I don't know if this camera allows you to do a low level format or not. If you can do that.
Oct 30, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon 400d
Best regards,
Sep 15, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Camera won't turn on
Try replacing the date/time battery located in the main battery compartment. Also, simultaneously remove the lens. This will be like a master reboot for the camera. Replace the date/time coin battery, the main battery (freshly charged) and lastly the lens.
If this doesn't work, send it in for service. If you are just slightly beyond your one year warranty, Canon may allow a grace period especially if you can provide a receipt. If you can't find a receipt, give them the approximate date of purchase when you send in the camera. You will need to call them or set up service online.
Hope this helps!
Apr 25, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Date on pictures taken and movie shooting on canon eos 400d
The EOS Digital Rebel, EOS Digital Rebel XT and EOS Digital Rebel XTi do not support stamping the date and time on the image.
It is not possible to record the date and time as part of the image at the time the picture is taken. However, the date and time is captured in the EXIF information of the image at the point of capture. It is possible to print the image with the date and time via printing software. Please see the documentation for the software package that you use for printing images for the proper procedure.
Apr 06, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Frustrated with learning the Canon rebel xti
I can tell you that the XTi is a very advanced DSLR camera and can't be learned overnight. I've been shooting EOS cameras since 1986 and it still took me about 2 weeks to master it. The manual that came with it is very informative and should provide a basic understanding of its functions. I'd recommend doing a Google search for free photo tips and training. I've got numerous links that I refer to from time to time when I need a refresher.
Dec 05, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon EOS 400D / Rebel XTi Digital Camera Logo
3,809 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
