The receptical for adding softener gets filled to the indicated mark and the cycle is started. when wash finishes this receptical is full of a water/softener mix. I see no blockages or other impediments after examination of the whole additive tray.
The first thing I would check is to see if the water inlet screens are blocked with sediment or calcium deposits. My tray would not empty the bleach part and gave me error code F20. Turns out the screen was filled with deposits which I cleaned out. Now it works fine. If the tray does not get enough water it will not start the siphon action necessary to drain the tray.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
