Question about ASUS P5E3 Deluxe Motherboard - Intel X38, Socket 775, ATX, Audio, PCI Express 2.0, CrossFire Ready
I'm building a computer, using a p5e3 deluxe with wifi. I have the bar minimum hooked in, and when I turn on the computer, I end up with the ps fan coming on and the case fans working, but the cpu fan does not work, and i've tried another cpu fan without any luck.
  • Mike Peluso
    Mike Peluso May 11, 2010
    Hi golfin4birdi, when you installed the CPU did you add thermal grease to the top of the CPU? See pages 2-8 to 2-12 in your manual.
    President:
  • 1,179 Answers
Make sure you have the cpu fan plugged in. With Asus the plug should be right beside the RAM sockets. It will be marked with a small cpu fan and will be either a 3 or 4 pin connection. If your cpu fan has a 3 pin plug & the motherboard has a 4 pin connection you can still use it. Just leave one pin not plugged in. Hope this helps.
Posted on Dec 21, 2008
How do i turn on the radio on the macbook air
Hi Peggy, Go to your menu bar in the top-right corner of the screen. Just to the ,left of the clock you will see a little fan-shaped symbol.
If it is just an outline shape then the wifi is turned off.
Click o0n it and hold the click. A menu will appear and one of the entries will be "turn Airport on"(or turn WiFi on - they have changed the wording recently).
Select that line and wait a moment. The Fan icon will change into 3 grey bars (but still in the same fan shape). The bars will cycle through balck while the wifi looks for base stations. It will then say something like "none of your trusted networks are available, do you want to connect to any of these?" and it will show yuou a list of the base stations it can see. Those with a padlock next to them will require a password. Once you have selected a network and made the connection, the computer will remember it for the next time so you won't have to go through this again.
If the wireless doesn\t turn on and stays with the outline icon, then you need to get the Mac looked at.
Mar 13, 2012 | Apple MacBook Air
P5e3 deluxe motherboard. Computer starts ok but with nothing on the screen until the welcome logo. This means cannot get into bios or safe mode. Computer runs well otherwise
Your bios may be set for quick boot, and does not show the bios information. You can still access the bios by hitting F2(or possibly DEL) right after powering up. You can then change settings inside bios
Jun 22, 2011 | ASUS P5E3 Deluxe Motherboard - Intel X38,...
I have been using the Bible Library deluxe for several years but it seems incompatible with my new computer with windows 7. Can I downlowd a version for use with windows 7
Bible Library Deluxe Special Edition Version 5.1 System Requirements
**We can only warrant and support our products when they are run using a computer for which they are designed.
Minimum System Requirements are the *very* minimum specs that your computer needs to run the software. If you try to use the program when your computer does not meet the minimum system requirements, you will experience a wide array of unpredictable results. Operating System: Windows® 95/98/ME/XP
RAM: 16 MB
Hard Drive Space: 3MB Free
This is from their website,sorry but Win 7 is unsupported.
Jan 19, 2010 | ValuSoft The Bible Library Deluxe Special...
Hi Running WIN XP (32bit) Have just replaced the Motherboard with an ASUS P5E3 Upon boot up, Windows XP dooes not recognise the USB mouse. The mouse is plugged directly into the MoBO's USB port. I...
Method 1: Initiate recognition of the USB device by using Device Manager----To initiate recognition of the USB device by using Device Manager, follow these steps:---
  1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Managerwindow opens.
  2. Click to select your computer as the location for the scan.
  3. On the Action menu, click Scan for hardware changes.
    Windows XP recognizes the new device.
  4. Close the Device Manager window.
If this method resolves the issue, you are finished.
If this method does not resolve the issue, go to method 2. Method 2: Disable power management of the USB hub---Use this method if method 1 does not work. To disable power management of the USB hub, follow these steps:===
  2. Expand Universal Serial Bus controllers.
  3. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed.
  4. Click the Power Management tab.
  5. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
  6. Repeat steps 3 through 6 for each USB Root Hub in the list.
  7. On the Action menu, click Scan for hardware changes.
  8. Close the Device Manager window.--
If this method does not resolve the issue, go to method 3--- Method 3: Restart the computer---To initiate recognition of the USB device, first unplug the USB device and restart the computer. Then, wait five to ten seconds before you plug the USB device into the computer or hub. Windows XP recognizes the new device.
If this method does not resolve the issue, you might want to review the articles in the "Similar Problems and Solutions" section, or contact Support. For information about how to contact Support, visit the following Microsoft Web site:---- http://support.microsoft.com/contactus
--- This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 02, 2010 | ASUS P5E3 Deluxe Motherboard - Intel X38,...
Odd PC Build Bootup Problem:: I recently built a PC and have an odd problem when booting up. Build: MOBO: M2N32-SLI Deluxe CPU: AMD 6000+ RAM: Corsair 2 x 2048 PC6400C5 GPU: Sapphire Radeon HD 4670 1GB...
Instead of connecting you're fans to a single 4-pin molex on the power supply why not use the motherboards 3-pin molex fan connectors coming off the motherboard. See page 2.2.4 in your manual. Though I agree you should still be able to run 4-pin molex connectors to all fans off of you're PS. Allow the mother board to supply the 12v current to you're extra fans.
CHA_FAN1
CHA_FAN2
CHA_FAN3
CHA_FAN4
You're motherboard will supply the needed power. Less wiring will also allow better air flow through out the system and less strain to the fan controllers.
4-pin molex to 3-pin female; http://www.avadirect.com/product_details_parts.asp?PRID=11410
OR
http://www.microbarn.com/details.aspx?rid=101317&source=froogle
Happy New Year!
Mike
Dec 29, 2009 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
I have a ASUS Asus P5E3 Deluxe Motherboard. i installed and used for about a month and it took a **** on me. i turn it on and the MoBo turns on, but doesnt give me anything on the screen. MoBo isnt in...
i have same problem i have a ASUS P5E3 Deluxe Motherboard but everything was new but when i on allthe light is runing good but no beeps on my bord or signal on my screan?
Sep 24, 2009 | ASUS P5E3 Deluxe Motherboard - Intel X38,...
I have a new 32 gb iPod Touch and I can't figure out how to connect to any open wifi in my neighborhood. I do not have wifi hooked up to my home computer. I thought you connect to a wifi connection...
go to settings and tap on "wifi" there you can change the settings for the wifi.
P.S. The ipod touch does connect automatically you need to turn it on in the wifi settings
Sep 14, 2009 | Apple iPod touch
Asus p5e3 freezes at POST.
Hi David,
Maybe you could buy a new CMOS battery and replace the old one..
Might be worth a try..
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | ASUS MB P5E3 PREMIUM/WIFI-AP X48 RT...
I have a new P5E3 Premium WiFi-AP MB. I have fitted one new 500Gb SAT drive to SATA1 connector I am trying to load Windows XP Pro, but each time I try, I get STOP 0000007B message. I know the drive is OK...
Why do you have your SATA configuration set to IDE compatible if you're using an SATA drive? You only need to do that if you have an IDE drive in the system in most case. Try setting your BIOS to failsafe mode and see what happens.
Dec 31, 2008 | ASUS MB P5E3 PREMIUM/WIFI-AP X48 RT...
P5E3 motherboard, wn XP lagging, USB lagging
Hi csoda,
I have not come across anyone having this issue with the Asus P5E3 deluxe motherboard but have had others with same troubles as you different boards & system configurations.
No issue with Asus & the quad 9450. You can read FAQ’s for you're Asus board at this link. (Look to the left under Related Link). http://support.asus.com/download/download.aspx?modelname=P5E3%20DELUXE&SLanguage=en-us
System lag & system reboots seems more related to software issues but can also include some hardware devices including the CPU overheat. CPU overheat usually shuts down the system not restarts. (Check CPU fan. Clean fan if dusty with clean paint brush & canned air).
In pc repair finding the problem for software is often long & difficult. Suggest you update you're antivirus software. Than run full systems scan. (Just to be safe). You can disable system restarts through system properties/advanced/startup and recovery/settings. Remove the check mark next to automatically restart. If you're lucky windows will display the error for restarting windows. I would suggest format & complete fresh install of windows. All the issues have two things in common. Window & the primary hard disk drive. If you are up to it, you can download the hard disk drive's software tools/utilities & setup software from the manufacture’s web site. Most Mfg's provide software utilities to allow you to create either a bootable floppy disk or bootable CD disk so you can check the drive's stability. The software can check for error's & repair any if found. You also can setup other features that can not be done with windows or the bios. You can set up cluster size & format type just to name a couple. Since windows is still working, suggest you back up to CD (If you have a burner) or to a memory stick, you're personal data. If the Mfg's tools/utilities finds a problem it will fix it & you are sure to loose you're data.
Lastly, there are also windows systems defrag & windows disk cleanup utility. That may help with lag but not with keyboard (try swapping the keyboard). Sound skipping is more related to disk performance or corrupted song.
Good Luck csoda!
Mike
Jul 03, 2008 | ASUS P5E3 Deluxe Motherboard - Intel X38,...
ASUS P5E3 Deluxe Motherboard - Intel X38, Socket 775, ATX, Audio, PCI Express 2.0, CrossFire Ready Logo
98 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
