Question about Mitsubishi HC100U Multimedia Projector
I have 2 SVGA60 Projectors that are saying Temperature!!! One does it then the other about 10 minutes later
  • 36 Answers
Temperture issues are normally acquired when typically the filters are dirty.
Posted on Jul 10, 2009
    Problem Solver:
  • 6 Answers
Check the filter and clean the filter and reset the filter hours.
Posted on Jul 08, 2009
  • 205 Answers
Investigate airflow, verify air vents are clear and filters are clean. Check lamp life in menu, its possible your nearing the end of lamp life.
Posted on Jul 07, 2009
  • 22 Answers
Several reasons, it could be you havent had its 1000Hrs service and is overheating or filter needs cleaning or lamp is past its change time and is generating too much heat or sensor can sometimes come away and drop into light path causing false sensing of temp.
Marc Engineer
Posted on Jun 17, 2009
Hi i bought 2002 nissan sentra ..previous owner replaced head gasket ,water pump.thermostat was running good for a week then sudeny no hot air inside(blows but cold) and 10 minutes later...
Thermostat is the wrong temperature range for the vehicle or it is installed backwards. It is opening too soon and not allowing the vehicle engine to come up to operating temperature soon enough. Have system checked, replace thermostat with correct temperature for vehicle
Feb 12, 2015 | Nissan Cars & Trucks
Car loses power for short time after normal running and cooling down for ten minutes
sounds to be symptomatic of a CTS (coolant temperature sensor). there are two, one is for the interior temp gauge, the other is for the ECU/PCM while both are basicalty the same part, often even the same P/N, they both do extremely different things.
Feb 24, 2014 | Ford Ka Cars & Trucks
Our projector has said replace lamp for approx. 1 year. We did and it still saying to place lamp. Also it stops projecting after about 5 minutes and then 10 minutes later we are able to use it again for...
You need to reset the LAMP RUNTIME counter
1. Press the MENU button to display the menu screen
2. Press the UP and DOWN arrow buttons to select the "OPTION" menu
3. Press the ENTER button and then press the UP and DOWN button to select the LAMP RUNTIME
4. Press and hold the ENTER button for approximately 3 seconds
5. The LAMP RUNTIME screen will be displayed.
(Note: press any button other than the Power button to cancel the LAMP RUNTIME screen)
6. Press the POWER button to turn off the power
7. After the POWER button on the projector illuminates red you restart the projector
and check the LAMP RUNTIME counter it should be "0"
Nov 24, 2010 | Panasonic PT L735U Multimedia Projector
We moved our freezer model lffh21f7hwe to another location, turned it on, checked it later and it was -10, I tried to raise the temperature up, now the light says OF. What do we do?
try to unplug the unit for a few minutes.then try and adjust you temp again if you you to high with the temp you will shut it off
Oct 10, 2010 | Frigidaire Freezers
Model PJ556D will run for a few minutes and then shuts off. Once it cools down it will start back up, but shuts off again a few minutes later.
Hello, Greg.
The most common reasons are the temperature is too high or the ventilation holes are blocked.
Unplug the AC power cord, wait 5 or 10 minutes then turn back on.
There could be dust or the air filter needs to be changed.
Take the lamp cover off the bottom. It's possible that the screws holding the lamp are loose.
Hope this helps.
Apr 05, 2010 | ViewSonic PJ556D DLP Projector
Projector is brand new out of the box. Powers up displays Sim2 logo then lamp goes out power light starts to flash and turns off about 3 minutes later. Same thing every time it's turned on. Anyone had the...
the number of blinks determine the problem:
Environment Over Temperature- 1 long blink / 1 short blink
DMD Over Temperature- 1 long blink / 2 short blinks
Lamp Over Temperature- 1 long blink / 3 short blinks
Fan1 Locked- 1 long blink / 4 short blinks
Fan2 Locked- 2 long blinks / 2 short blinks
Fan3 Locked- 2 long blinks / 3 short blinks
Fan4 Locked- 2 long blinks / 4 short blinks
DMD Initial Fail- 3 long blinks / 1 short blink
Lamp Initial Fail- 3 long blinks / 2 short blinks
Ballast UART Error- 3 long blinks / 3 short blinks
Temperature Sensor Fail- 3 long blinks / 4 short blinks
Inter Lock Open- 4 long blinks / 1 short blink
any of these will result in lamp off and shutdown.
Aug 28, 2009 | SIM2 Domino D10 Home Theater Projector...
Sanyo xp-56 overheating with all air intakes clean
You have thermal protection issues.
On some projectors, once the thermal protection has been activated once, it will activate again at a lower temperature!!!
Inside your Sanyo there are several temp sensors (they are actually temperature-sensitive resistors, called thermistors). I have seen this many times as an electronic technician working on multimedia projectors. For the techs out there, they are actually NTC thermistors (NTC= negative temperature coefficient, meaning as temp goes up resistance goes down).
Once a thermistor has activated to save your machine form heat damage, it may activate again at a lower temperature. The only solution is to take your projector to an authorized Sanyo warranty repair depot, and have the thermistors replaced in your machine.
Typically, there is a thermistor to monitor lamp temperature, and a thermistor to monitor optical block temperature. Better quality machines may have more thermistors, some machines only have one to monitor the lamp temperature.
Mar 29, 2009 | Sanyo PLC-XP56 Multimedia Projector
Epson EMP-51
clean all filter carefully and apply a good room of space around it-and do not block the intake air ventilation with any object.and test your projector.
Sep 28, 2006 | Epson EMP 51 Multimedia Projector
Mitsubishi HC100U Multimedia Projector Logo
244 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
