Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Power cord will not retract
Power cord was over extended and now will not retract
  • Anonymous Mar 25, 2014
    water hose reel
    President:
  • 2,976 Answers
It sounds like the rewinder spring either came off the retainer or broke. If it broke it must be replaced. If it just came off, it can be put back on and rewound. It is a LONG flat piece if springsteel which is VERY sharp. Be Careful.
Posted on Jan 01, 2009
Bissell momentum canister vacuum retractable electrical cord not retracting
Either the cord inside is caught on something or the retraction spring is broken.
Try to pull it out further, if you can feel any spring-back then most likely the cord is caught, maybe on itself.
Either way, the canister will probably have to be disassembled to fix the problem.
Sep 17, 2016 | Bissell Vacuums
360 manual
With all that's involved in replacing the cord and potential cord reel damage, it's more cost effective to just have the entire cord reel, complete with new cord, replaced. Less time consuming thus less costly to you. Hope it helps!
May 26, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
I have a Hoover Legacy model S3592 and the cord will not retract, it is fully extended. How can I fix this problem? Patty Lester
You may have to dis-assemble the machine to the point where you can gain access to the mechanism that retracts the cord. Then see if it can be fixed or needs replacement. Just don't lose any parts when dis-assembly, and make sure everything is put back together correctly.
Oct 14, 2013 | Hoover Elite & Legacy Vacuum Cleaner Belt...
The power cord does not retract or rewind when the button is pushed. How can I repair this?
Sometimes you can help get the springs working again, by gently pulling the cord out a little further and then let it slowly in while pushing the cord retract button.
Nov 08, 2012 | Kenmore 25512/ 25513 Progressive Canister...
The power cord is fully extended and will not retract in Miele LUNA vacuum cleaner model s4580
Keep playing with it, it will go if you are careful. The alternative is to disassemble the device and get involved with the retractor system. This is not always a simple task with springs under tansion, reassembly required about 8 hands ... which MAY be a small exageration.
Thanks for your question @ FixYa.com
Mar 23, 2011 | Vacuums
Cord has been hyper extended, will not retract
try pulling the cord a little, while holding down the cord release button. if nothing happends and it doesn't retract, suggest taking to a service center or your local vac shop for repairs.
Jul 16, 2009 | Electrolux Epic 6500 Vacuum
Electrolux EL 7001 Oxygen 3 power cord continually retracts
The button has two parts - the inner part (button) and the outer part (surrounds the button). The press the outer part to deactivate (pop out!) the inner part.
It took me a while to figure this thing out, but I was glad the vacuum wasn't broken.
May 02, 2009 | Electrolux EL7055A Bagless Canister Vacuum
Cord retraction help
if you can open it up extend the cord and wrap it around the spool.make sure its clean.spray a little wd40 on the shaft of the pully so it moves freely
Apr 04, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Power cord will not retract on my Electrolux UltraLux 2000
You will need to take the machine apart to correct this. Open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl covered strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl separates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come off relatively easily, and everything will be exposed. Now, assuming that the cordwinder isn't damaged, you should be able to wind the cord in by hand. Once it gets started it may start to retract automatically. Usually the spring just gets in a bind against the housing when it's over extended, and rolling it in by hand a little will free it up. Good Luck!!
Dec 18, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Your cordwinder is broken take it to your local Aerus Electrolux dealer. If you have any additional problems call Liz at 570-326-1731
Dec 01, 2007 | Electrolux Guardian Bagged Canister Vacuum
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
206 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
