Question about Sony PS-LX250H Turntable
SONY PS LX300H turntable works only one channel at a time
I just sent my parents an SONY PSLX300H TURNTABLE that I bought on EBay. When they plug in the right channel it works. If they plug in just the left channel it works. But if they plug in both, thge sound disappears. As far as I can tell (over the phone) they are doing everything right and it's not the amp. Is there some turntable specific issue here that I'm not thinking about?
  • Anonymous Feb 17, 2009
    Ditto. I have problems playing mine in stereo. Each speaker works separately but not together.
    Brigadier General:
  • 8,546 Answers
This sounds suspiciously like the wiring of the cartridge is wrong or something is shorted together. The cause should be visible.
Taking special care to NOT touch the stylus itself in this operation:
Turn the locking collar and remove the cartridge assembly in its shell from the tonearm.
Flip the assembly over and examine the four wires under a magnifying glass for disconnections, kinks, crimps, or metal-to-metal contact between any of them. They should each attach to a pin exiting straight out from the cartridge.
The wires are also color coded as are the terminals. If they're wrong you could have various sonic malfunctions.
Correcting miswires is delicate and I would recommend taking the turntable and stylus to a pro for that part.
Posted on Apr 06, 2009
Power supply Sony PS-LX10
Connect the RCA phono plug wires usually red and white wires with plugs to a receiver or amplifier in the back of it to phono in. New receivers will not work unless you have a phono preamp. Best to buy a vintage stereo receiver or amplifier with the correct connections. Make sure you connect the ground wire which is usually a small black wire coming from the turntable to an receiver or amplifier. Turn the stereo receiver on phono. Connect it to any screw attached to metal on back or look for a ground screw. If you do not attach it it will hum.
http://www.hardwaresecrets.com/imageview.php?image=357
Apr 18, 2014 | Audio Players & Recorders
Sony ps-lx250H loud buzzing sound
That is where the problem is, get a long insulated wire, bare both ends and attach one end to the turntable and the ground screw of the amp, use one screw on the chassis on the turntable and bare the metal for good ground connection.
Jul 20, 2012 | Sony PS-LX250H Turntable
No sound with Sony LX300usb turntable
I just received the Sony PS-LX300USB turntable but cannot play sound through the computer speakers. States to setup Playback USB Audio
CODEC which shows working and Recording it shows Microphone USB Audio CODEC which is working. How do I get sound???
Apr 07, 2012 | Sony PS-LX300USB Turntable
Sony ps5520 turntable requires a new spindle required where can i get one?
These tables are no longer serviced. You can buy a second for a parts unit, or check Ebay in case someone is parting out an old one.
Jan 07, 2011 | Sony PS-LX250H Turntable
PS-LX300USB Turntable: I have hooked up the sony turntable to laptop, but...
Have you though of using a pre-amp? You'll probably need to go turntable --> pre-amp --> soundcard input to get acceptable sound
May 11, 2010 | Sony PS-LX300USB Turntable
What size belt does a Sony PS-LX300H USB turntable use?
These replacement parts are purchased for the model turntable that they are to be installed in. They are not generic and are not bought by "size" as say a fan belt for a car would be. I googled "Sony PS-LX300H Belt" and got:
http://www.lpgear.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LG&Product_Code=STPSLX0300H
May 07, 2009 | Sony PS-LX250H Turntable
Sony PS-LX300USB Turntable, one channel not working
Have you tried swopping over the output leads from the turntable to the amp (normally one red and one white phono plug) so they are in each others socket? If you do this and you still get no sound from the right channel it is almost certain to be a faulty amp,or speaker.
If you swop and get no sound from the LEFT channel it is could be either a faulty lead or cartridge.
Apr 19, 2009 | Sony PS-LX250H Turntable
Sony ps-lx2 turntable clicks when spinning
It seems something may have come loose over time or history, but you will have to delve inside to see what it is. It sounds as though the fault should be obvious.
If you do not want to do this, a repair shop should have no problem. I assume that the deck is working ok otherwise.
Jan 01, 2009 | Audio Players & Recorders
Sony PS-T3 turntable one-speaker audio
Hey Limber, I am also experiencing that problem with my Sony PS-T3, did you find a solution?
Sep 15, 2008 | Sony CMT-CP505MD CD Shelf System
New needle for sony ps-lx250h?
Yes It's possible.You can purchase it on amazon, click here and take a look: Amazon com sony ps lx250h needle. I hope this was helpful. Cheers
Jan 24, 2008 | Sony PS-LX250H Turntable
Sony PS-LX250H Turntable Logo
632 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
