Question about Philips Magnavox DVD/VCR Dual Player
I get error codes E25 & E26 when trying to copy to a dvd disk
I have a magnavox zv450mw8a dvd & vcr recorder. Everytime I try to copy a vhs tape to a blank dvd disk I get the error codes E25, or E26.
It will let me copy some of them,but not all. So my question is what is error codes E25, & E26. I think I know what it is,But I figure I would ask the expert.
Thanks
Rod
5 Suggested Answers
epik559
  • 44 Answers
SOURCE: Philips Magnavox MWR20V6 DVD
Its macrovision. You need a macrovision killer or a Go video. I am not promoting you to buy that but that would take care of the problem
Posted on Nov 25, 2007
  • 3 Answers
SOURCE: VHS won't play, sounds like tape will load then power shuts off.
This is similar or identical to another post, but here is an answer...
Hi, I have a solution you can try.
I had exaclty the same problem. When I tried to play a tape it would load (However, I recall I had to push hard to get the tape to be accepted, which is part of the problem) but would shut off after about 12 seconds, then when I powered back up the tape would eject. Finally I took the unit completely apart and attempted to use it with the covers off. Lo and behold, I found I could play a DVD on the unit without the unit powering off, but only if the room lights were on! If I tried to play a tape it would shut down the unit. So that led me to diagnosing the infrared loading and reel sensor circuits.
Background on that is there is an infrared LED that shines up through a plastic light pipe lens. The light from that LED (you can't see it) should shine on two photodiodes that are on either side of the tap mechanism, plus down through a gear with holes in it on to the reel sensor. When there is no tape inserted the two photodiodes will be illuminated and have about 0.2 volts across them. When a tape is installed the light will be blocked and the voltage goes up to above 2.5 volts across the diodes. You have to check this with the room lights dim as the diodes will respond to that light. When you block the light on either side of the plastic light pipe with your finger (with the unit disassembled) you should see the load motor engage, and it will back off when you take your finder away. For some reason in my unit the light from the LED was insufficient to turn on one of the diodes, and also to pulse the reel sensor when the gear turned. That could be due to component aging, or even if the light pipe started to cloud due to age, I don't know. However I was able to get the thing working...
In short I got the unit working by adding 3 resistors.
To do this you'll have to remove all the covers and remove the main PCB from the bottom chassis, unplug the power supply from the PCB, and the two ribbons going to the DVD unit. But you won't have to take off the VCR assembly, which is a pain. You just need some basic soldering skills, and remember where all those screws go...
First, I adjusted the voltage across the right-hand side load sensor diode to get the diode to switch on and off. I recall that I added 1meg across the diode. So the voltage then went from about 0.5v up to 2.8v from light to dark condition.
Second, I increased the current to the IR LED. I added a 330ohm resistor across the feeder to the LED. I recall that was R511 and was originally 220ohms. That was not quite sufficient to get the reel sensor working reliably. I didn't want to stress the LED by putting too much more current through it so looked for another idea.
Third I added 56k across the reel sensor diode to bring the voltage across it down so it would switch on and off as the reel sensor gear turned.
I now have a tape playing continuously in the unit and it seems ok for the time being. Hope that might work for you too.
Craig Townsend
Posted on May 26, 2009
  • 181 Answers
SOURCE: when I insert a video cassette into my magnavox
Try a video head cleaner first of all, OR eject the tape before turning off power.
Posted on Feb 12, 2010
SOURCE: Magnavox ZV450MW8A DVD/VCR Recorder Dubbing.
I bought a ;magnavox dvd disc and cassette recorder combo.
I am having trouble with setup items? I get nothing on the screen to select from?
Posted on Feb 27, 2010
Oct 24, 2009 | Televison & Video
I just bought a Magnavox ZV450MW8A DVD/VCR Recorder. It has recording capabilities on both the DVD and VCR components but can you tell me if I can use it to record FROM the VCR directly onto the DVD? This...
Yes, you can, I have this unit and have actually copied a dvd to a vhs and then copied back to a dvd as I wanted a dvd copy to give a friend. The directions in the book are really quite simple. They tell you how to set the vhs to the spot where you want to start copying, etc.
I have not yet tried copying my family vhs tapes, but don't see a problem, just a big project. Good luck.
Jun 13, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox dual model dvd/vcr model ZV450MW8A keeps showing error code 45 when trying to record from sat.
This is a problem with the satellite box it has copy protection for certain programs. The only way to find a solution for this problem is to call their technical help and see if they have a work around filter or release code. The error you are seeing is listed your owners manual as a copy protection error. This is on page 43 of the manual. There is no work around yet published on the internet. I hope this information helps you with your problem.
Jun 01, 2009 | Philips Magnavox DVD/VCR Dual Player
When I try dubbing from VCR to DVD the machine will only record about half of the VHS to the DVD. I get the following message...Recording Error - this program is not allowed to be recorded. The cause...
The DVD AGG (automatic gain control) is somehow being fooled into thinking the non-commercial tape has macrovision (copy protection). Is this a relatively inexpensive machine?
Mar 08, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VHS to DVD Dubbing Problem
I have the same problem. I saw a solution that said I needed to set my cable to a non-premium channel like NBC, ABC, PBS, CSPAN in order to allow the dubbing to occur without the +VR problem. At first, I thought it was a stupid solution; but guess what, It worked. I just set my cable box to from HBO to CSPAN,restarted the dubbing from VCR to DVD and it worked. Now the question is: Why do I have to change the channel when I'm dubbing from VCR to DVD?
This worked for me..still trying to figure out why it worked???
May 25, 2008 | Philips Magnavox DVD/VCR Dual Player
Magnavox ZV450MW8A can't record
Just set the channel to a non-premium channel (ABC, CBS, PBS, etc.) before starting the dubbing process.
Apr 20, 2008 | Philips Magnavox DVD/VCR Dual Player
VHS to DVD - D-VR4XSU
have u tried the seting on the vcr, you know how u can change the lenght of recording on the vhs
Mar 29, 2008 | Philips Magnavox DVD/VCR Dual Player
Sorry Gary, Forgot to put the link on: http://www.originaltrilogy.com/forum/messageview.cfm?catid=12&threadid=6530
Aug 24, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Philips Magnavox DVD/VCR Dual Player Logo
958 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
