Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
Single handle moen shower not turning far enough
When taking a showing, not enough hot water was coming out. I turned the handle and it seemed to slip a bit. Now to shut it off, the handle points to about 4 on the clock face vs about 6 when normally shut off. do I need a new faucet handle or does it sound like a cartridge problem
  • 1 more comment
  • elliot347 Dec 18, 2008
    took handle off and was broken. Cartridge was fine.
  • Anonymous Dec 21, 2008
    the water won"t turn off
  • Anonymous Mar 29, 2014
    handle in shower doesn't shut the water off completely
It is your shower cartrige. ace hardware $45. hot always goes first. just check if it is a posi-temp or moan trol
Posted on Dec 19, 2008
Can you adjust hot to cold ratio on moen single handle shower faucet
Pull off the handle and there are limiters located under it. They come set with not enough hot allowed, I have found. It is an anti scalding issue.
Sep 29, 2010 | Moen & Posi-Temp Single Handle Shower Or...
I just put in a Moen single, chrome handle shower faucet in my hall bath. Got it all together and the hot water is not comming out. Cold water is fine, but, when i turn the handle to the position where the...
If this is a Moen posi temp valve you may need to adjust the temperature limit stop. It is located under the handle. Usualy a plastic peice with grooves in it so it fits in another peice in the valve. If I remember right you pull this peice out and turn it counter clockwise to get more hot water. Do this in small increments and reassemble and test. I hope this helps.
May 25, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Oct 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Hot and cold backwards on a moen shower faucet
tun off the water.
unscrew teh allen screw under neath the handle. pull out hteh handle. undo the wall plate and gain access to the cartridge in the handle body. turn the artridge around 180 degree and reisntall all parts.
Apr 06, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Replaced a moen cartidge and now the water is not hot in shower
make sure when you turn on the hot and cold shut off valves all the way and turn the moen on after that. Some times I would get that problem if I turned one(either hot or cold) off then tried the shower.
Feb 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Not enough hot water, has to do with a shower valve
Hello, first if any water supply hot or cold is turned off, you will experience trickling as you mention. You must have both cold and hot in order to adjust the temperature on your valve. if you had a plumber intall this unit you should ask him to adjust it. Otherwise here is how:
Rotate the handle counterclockwise to stop and let water run till cold water is purged, check
temperature. Rotate handle to off, remove handle parts (see Disassembly in your manual) and temperature limit stop, rotate clockwise to decrease and counterclockwise to increase maximum hot water temperature, reinstall temperature limit stop and handle (TIP: Do not screw handle in until desired maximum temperature is achieved) Repeat steps until desired maximum
Feb 21, 2009 | Moen 3175 Legend One Handle Shower Faucet...
The screws remove the handle. After the handle is removed their are little plastic like gears to limit th ehot watr. Relocate the gear ring for more hot water.
Jan 06, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
618 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
